6th November 2016, 16:19 | #1621 | Link |
Software Developer
New TEST build with latest x265 encoder:
https://sourceforge.net/projects/mul...6.exe/download
11th November 2016, 14:02 | #1622 | Link |
PgcEdit daemon
Is it possible to use the x264 launcher with VapourSynth installed in portable mode?
I haven't found a way to tell it where VapourSynth and Python are located, and the launcher tells me that VapourSynth is NOT currently installed. I understand that it cannot find it automatically since by definition the portable installation is not tied to the system, but IMO it should be possible to specify the directory somehow, with the preferences dialog or by editing a configuration file. Is it currently possible? If not, can you add that possibility?
26th November 2016, 17:31 | #1623 | Link |
LoRd_MuldeR would it be possible to add a feature in which you can set a custom deadlock value or even fully disable it? Because some scripts have long initialization times which exceed the default 60 seconds, which makes batch encoding quite irritating to handle within your GUI.
Thanks in advance. |
27th November 2016, 00:46 | #1624 | Link | |
Software Developer
https://github.com/lordmulder/Simple...nd-line-syntax
27th November 2016, 03:07 | #1625 | Link | |
Verstuurd vanaf mijn SM-A500FU met Tapatalk |
27th November 2016, 09:47 | #1626 | Link |
PgcEdit daemon
Since I haven't received an answer to that question, should I assume that it's impossible?
27th November 2016, 22:52 | #1627 | Link | |
Software Developer
It should be possible now, with the very latest version. But you have to follow instructions exactly: https://github.com/lordmulder/Simple...md#vapoursynth
28th November 2016, 10:42 | #1628 | Link |
PgcEdit daemon
OK, thanks! I have already "installed" VS Portable elsewhere, but I suppose that I can do an hard or soft link to duplicate it within the extra folder. But IMO, it would be better to have the possibility to specify the path manually, perhaps with a command line argument, or within the preferences.ini file. Just a suggestion.
[EDIT] Using an hard link (called Junction in Windows terminology) works fine, but a soft link doesn't work. So, the directories with the Simple Launcher and with VapourSynth must be on the same physical partition. An additional reason to provide a way to specify the path. ;-)
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 28th November 2016 at 10:54. |
9th December 2016, 23:12 | #1629 | Link |
Software Developer
New TEST build available:
https://sourceforge.net/projects/mul...9.exe/download Updated x264 and x265 to the latest versions.
14th December 2016, 00:10 | #1630 | Link | |
Software Developer
Simple x264 Launcher v2.77
https://github.com/lordmulder/Simple...ases/tag/v2.77 Quote:
14th December 2016, 03:42 | #1631 | Link |
I have a weird feature request.
I currently do my encoding on a computer that I only have access to on the weekend. I'm usually doing Home Videos for archiving so I only care about quality, I use QTGMC as my de-interlacer and because of this my encodes average around 0.3fps and can take up for 3 weeks to complete. I use Simple x264 Launcher as my GUI and it works well, I usually have up to 6 Job running at a time as I only use the Single Threaded Avisynth to do the work. What I would like is a way to see the status of the encode remotely since I only have access to actually be in front of the encoding computer on the weekend. What I do have access to though is the file system. Is there a chance you can add a feature to allow a log file to be written with the status of the encode while the encode is happening? I could then check this file at any time to see where the encodes are up to. I believe it can be done by piping the output to a text file but I don't have anyway in the software to add that command line from what I can see. |
14th December 2016, 15:15 | #1632 | Link | |
Software Developer
Really, instead of messing up one tool with too many (unrelated) features, you should use the right tool for each job - and combine them as needed (cf. Unix philosophy). Having said that, there already is a feature in Simple x264 Launcher to automatically generate a log file for each encoding task. But this won't be very helpful for you, I guess, because the log file is saved when the encoding task has been completed. The log file is not written (or updated) in "realtime" while the encoding is still running. And even if the log file was updated in "realtime", it still wouldn't allow you to see the current progress by looking at the file. That's because: (a) progress lines are not written to the log, because it would completely flood the log. Except for warnings that might pop up throughout the encode, most long lines are either created right at the beginning or at the very end; (b) even if we wrote all output the the log file in an "unfiltered" way, including progress lines, you still couldn't see progress in "realtime", because the file I/O buffering of the operating system will delay file writes.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th December 2016 at 15:24. |
2nd January 2017, 19:34 | #1633 | Link |
I've been using Simple Launcher for over a year now, thanks for that great piece of software.
I have three small pet peeves: 1. it's not possible to edit the paths and filenames in source/output directly (the field is not editable, you need to click [...] and edit it there, then click Save again) 2. there is no way to disable custom parameter validation, e.g. I'd often like to use tmod's --aq2-strength and Simple Launcher will not let me do that ("custom parameters are invalid and will be discarded") 3. my templates quickly grow into a rat's nest, some kind of system with categories for templates (DVD/HDTV/BD, or SD/720p/1080p for example, preferably user-editable) would be nice |
7th January 2017, 03:31 | #1635 | Link | ||||
Software Developer
However, there was (yet another) small issue in the parameter validation code. Should be fixed in latest TEST version: https://sourceforge.net/projects/mul...7.exe/download Quote:
If you want to use those deinterlacing filters without frame-serving your source from Avisynth or VapourSynth: Nope, that's not possible
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 7th January 2017 at 03:39. |
7th January 2017, 22:43 | #1636 | Link | |
Software Developer
Simple x264 Launcher v2.78
https://github.com/lordmulder/Simple...ases/tag/v2.78 Quote:
10th January 2017, 12:06 | #1637 | Link |
AviSynth not detected
I don't know why, but Launcher cannot detect my Avisynth 2.6. Is there a way to write a path to Avisynth? I tried with AviSynth+ and works only with 64-bit plugins... Launcher and avisynth are installed on system partition. I tried reinstalling and nothing. Windows 10 64-bit Education. I checked 2 last versions of Launcher. I tried with "portable version", changing name and copying standalone avisynth to Launcher folder. And still the same.
10th January 2017, 20:34 | #1638 | Link | |
Software Developer
The only difference in "portable" mode is that Simple x264 Launcher will add "<InstallPath>\Avisynth\{x86,x64}" to the PATH environment variable before launching the encoder process, so that the encoder process will be able to load Avisynth.DLL from that directory too. Still, programs prefer loading DLL's from the "System32" (or "SysWow64") directory, before they fall back to the directories listed in PATH. Anyway, you can try running "toolset\x86\avs_check_x86.exe" or "toolset\x64\avs_check_x64.exe" manually and look at the output, in order to check for the availability of 32-Bit or 64-Bit Avisynth, respectively.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th January 2017 at 20:38. |
14th January 2017, 10:39 | #1639 | Link |
Is it possible to add aomenc for testing, please? With your GUI it could be easier to test this new encoder with logs and statistics.
daily nightly builds: http://forum.doom9.org/showthread.ph...44#post1778544 |
14th January 2017, 17:38 | #1640 | Link | |
Software Developer
If it could work a drop-in replacement for x264 or x265 (i.e. it has similar command-line syntax, it has similar input/output capabilities, and it writes similar status messages to the STDOUT), then integration would probably be straight-forward. Otherwise, I don't know if integration could be done with reasonable efforts. But, in any case, I won't guarantee anything
