14th January 2017, 20:26 | #1641 | Link |
Software Developer
For anybody getting this error with latest release, please try the new "hotfix" build below:
x264_launcher.2017-01-14.exe
23rd January 2017, 00:23 | #1642 | Link |
I have a question: Is a good idea for Bluray ripping use makemkv and later use Simplex264 for definitive coding (video only, of course)?
The quality of image is still good? |
23rd January 2017, 10:04 | #1644 | Link | |
Verstuurd vanaf mijn SM-A500FU met Tapatalk |
24th January 2017, 00:56 | #1646 | Link |
Software Developer
Quality-wise, the Simple x264 Launcher is as good (or bad) as any other x264 front-end. But yes, x264 should be able to reduce the bitrate of a BluRay source quite a bit without much quality loss.
As far as MKV input is concerned, x264 can read MKV files directly, thanks to built-in FFmpegSource support. x265 is still lacking a feature like that, but of course you can always frame-serve your MKV files via Avisynth or VapurSynth...
24th January 2017, 01:31 | #1647 | Link |
Thanks, I was worried for the quality input of makemkv video, not for the performance of your program. In short Makemkv and Simplex264 are a good combo for ripping!
24th January 2017, 07:25 | #1648 | Link | |
User of free A/V tools
MakeMKV is a ripping tool, not encoder which means that the visual quality of output MKV file is exactly the same as that of original BD stream, the data are just repacked in different container = mkv (Matroska) instead of ts (MPEG transport stream). |
2nd February 2017, 08:13 | #1650 | Link |
PgcEdit daemon
In toolset/common, netc.exe is detected as a virus by many antivirus programs (VirusTotal score: 10/56). It's probably a false positive, but who know? What is its usage, and can we safely add it to the white list of our antivirus?
2nd February 2017, 23:47 | #1651 | Link | |
Software Developer
It's used by my auto-update feature, for fast connectivity tests. It only runs when you let auto-updater check for new updates. Don't worry: Netcat is a 100% legitimate. All you have to do is getting rid of buggy "anti-virus" software. Recommended reading: http://robert.ocallahan.org/2017/01/...re-except.html
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd February 2017 at 00:03. |
3rd February 2017, 10:06 | #1652 | Link |
PgcEdit daemon
OK, thanks. But note that it's not a single antivirus that is "buggy". As I wrote, 10 different antivirus consider the exe as dangerous, and it's too much to suspect a simple false positive. However, most of them flag it simply as suspect (or Potentially Unwanted Application) rather than as a real virus, probably because the exe can be used to communicate private information over the internet. Of course, I don't suspect your program to use it that way, but it remains that the exe might really be potentially dangerous if it is used by a malicious app, and that it will certainly be quarantined by the anti-virus of many users. Some peoples may be scared and refuse to use your program any more. Perhaps you should consider to use another solution, or integrate the version check within the program itself rather than using an external exe?
Anyway, on my side, I'll simply add it to the white list of my antivirus.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 3rd February 2017 at 10:12. |
5th February 2017, 02:14 | #1653 | Link | ||
Software Developer
The big problem with so-called "anti-virus" software is that they do not clearly distinguish these cases! In case (1) the "anti-virus" software should trigger an alert, yes. In case (2) the "anti-virus" software may still show a warning to the user, but it must be made very clear (not hidden somewhere in the details!) that such heuristic detections are only a very vague assumption and, most likely, the file is 100% legitimate. And, in case (3), the "anti-virus" software should not show anything to the user, with default settings. That's because, if you think about it, pretty much any software belongs into that category! Show me one (non-trivial) legitimate software that couldn't be used to cause harm, in one way or another, if you really want to. It doesn't exist. So, what software they call "potentially dangerous", or not, is a completely arbitrary decision... Microsoft Word, for example, is by far more "potentially dangerous" than NC will every be - c.f. macro virus. But, of course, they wouldn't dare to block Microsoft Word, because Microsoft has an army of lawyers... (Tomorrow they'll try to tell you that x264 itself is "dangerous" program that needs to be blocked, because terrorists may use it to encode their propaganda videos!) Quote:
(BTW: There is an important philosophy in software designed that says: Don't stuff too many features into a single program; write programs that do one thing, and do it properly; write programs that cooperate! So, if there already exists a well-established tool that does exactly what you need - as is the case here - it is always much preferable to just call that tool, rather than trying to re-invent the wheel)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th February 2017 at 02:43. |
6th February 2017, 08:37 | #1654 | Link |
PgcEdit daemon
I agree, especially on the difficulty to identify clearly if an exe is a real virus or just a PUA. And it's the major problem with VirusTotal, since when an antivirus doesn't give the green light, VirusTotal counts it as positive, even if it's only a PUA. But the fact remains that a score of 10/56 is scaring for many users, and that may have a bad effect on the reputation of your program. It's why I suggested to integrate the version check within the main exe, but of course it's not mandatory. I hope that your program will not be affected.
Anyway, thanks for your long reply.
21st February 2017, 21:28 | #1656 | Link | |
Software Developer
There currently is no option to turn it off. And I'm not sure I want (yet another) option for this. If you don't care about the timestamps, you can just ignore them, right? (it seems you are the first person to even notice ^^)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st February 2017 at 21:31. |
21st February 2017, 21:47 | #1657 | Link | |
23rd February 2017, 07:11 | #1658 | Link |
Gud day LoRd_MuldeR:
First of all, I would like to thank you for this wonderful software that you've shared to us. Today, I am glad to share my experience that I've discovered by using this software in all of my video encodes. For the past days, I am using Simple x264/x265 Launcher with Avisynth script in resizing my videos (from 1080p to 720p) using Avisynth's spline64 resizer. I am not into lanczos cause for me it creates more banding on my encodes. By the way my encode settings are 2pass @1500kbps and I am using the medium preset with the following changes: level 4.1, deblock -1:-1, ref=4, subme=8, umh, merange=64, rc-lookahead=96, b-adapt=2 and no p-fast skip. The encodes are good (if not best), but I think it is a little smooth because I think of the spline method. What I've discovered lately is that, when I put directly the video into the job without using Avisynth script and add a --video-filter resize:1280,XXX as additional command, the resulting encode was superb using the same settings as above. The encode is a little crispier but not so much of having banding effects created. Also, I observe that it saves about an hour of time in first-pass and also save more minutes for the second-pass (since only the x264 executable is only running and no Avs2yuv is running). Now, what I am wondering is that, is there any possibility that x264 can add an "add-border" function in its video filters cause as of this moment I can add only borders to my encodes using Avisynth's add border command. If you are wondering why, re-encoding videos (i.e. cropped movies) into full 1920x1080p in just single or dual-layer dvd discs and mux them as AVCHD format is beautiful to watch since blu-ray players will play the video in full-1080p/24-frames signal unlike the cropped videos which is converted to 60-frames. More power and thanks once again. |
24th February 2017, 05:34 | #1660 | Link | |
About the add-border, of my knowledge, there is one application - uncropmkv, but this is an old tool, and i think it uses avisynths too. If x264 can do this internally I think we can save time to encode videos. I am wondering if LorR_MuldeR can channel this concern to the developers of x264 since he has authority in using their binaries. Anyway, thanks for the reply. |
