Old 14th February 2020, 23:07   #58641  |  Link
Yog_Sothoth
when you click on the mhz number it self you change the logging of this field the max gives me a better idea of what is really happening.
here is an example:
https://abload.de/img/hd40007yk0q.png
your video shows serious issue with DXVA processing.
this 50i file that you are playing there is far far harder to handle then a 1080p23 file.
this is BTW. a totally normal file just a standard pal DVD.
Here: https://imgur.com/1H6SG1G
System: i5 3570k; 8 Gb ddr3; SW: Windows 10 x64, latest updates; k-lite codec pack mega, latest updates; Monitor: HP x2301, Receiver: YAMAHA RX-V371
Yog_Sothoth is offline   Reply With Quote
Old 14th February 2020, 23:42   #58642  |  Link
now it getting strange the rendertimes are totally fine now that you are using yadif. your iGPU even boost to it proper boost clock for a very short time now.
i test my HD 4000 tomorrow i have to connect it first.
Old 15th February 2020, 08:33   #58643  |  Link
madjock
But its also not deinterlacing now and its 50 FPS both.
Windows 10-1909 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Yamaha RX-V377 | Philips 65PUS6703 - 65"
Old 15th February 2020, 09:35   #58644  |  Link
yadif deinterlaced the source to 50 FPS so everything is correct.
Old 16th February 2020, 16:54   #58645  |  Link
Mike-uk
Hi, hoping someone can help, ive just upgraded from a gtx1060 to a rtx 2070 super, but now when playing a UHD movie it stutters every 1 or 2 seconds, never had this with the 1060 it ran smooth, the gpu usage of the 2070 is showing 28% ive tried turning everything to low in madvr, render time is 6ms, thanks
hmm ok so I have 3 displays connected same as when I had the 1060, movies don't stutter on the other 2 displays only on the TV, the tv is connected via hdmi and the other 2 display port
Mike-uk is offline   Reply With Quote
Old 16th February 2020, 17:43   #58646  |  Link
can you make a screen of the OSD sounds like a composition mismatch.
@Yog_Sothoth
didn't forget you i just had less time then expected i will test my hd4000 soon.
edit:my HD 4000 goes crazy when d3d11 is used for presentation.
i fixed it by doing this:
rendering -> general -> uncheck "use direct3d 11..."
rendering -> general -> check "enable windowed overlay..."
make sure everything else is not checked on this page.
leave the GPU and CPU queue sizes at default.
windows installed driver version 10.18.10.4358 from 2015 i just took it and didn't put it into question.
Old 16th February 2020, 21:03   #58647  |  Link
Mike-uk
Hi heres a screen shot of the stats
https://ibb.co/3v0dpcJ
Old 16th February 2020, 21:36   #58648  |  Link
is this screen with the other screen on or off?
d3d9 overlay could fix this too this could be the RTX bug too try present at advanced at 3 or lower.
other things.
DXVA2 native is no recommended use a different decoder.
the refreshrate is not correct this file needs 23p.
Old 16th February 2020, 22:08   #58649  |  Link
Mike-uk
ok cheers, ill have a look later, yes I changed from 23 to 24 cos I thought it was that but haven't changed the forced modes back,
Update
Thanks huhn your a life saver
all 3 screens are on
D3D9 just made the screen strobe like mad
exclusive mode "frames shall be presented in advance" set to 1 any higher and I get the stuttering
im now using LAV
and now back to 23 fps
Old 16th February 2020, 23:50   #58650  |  Link
Yog_Sothoth
Wow! I can't believe it actually works! After so much pain! And I thought I had tried every possible option, but, of course, it would have been difficult to determine that exact combination. Thank you so much! Do you have any idea why this happens?
Old 17th February 2020, 02:45   #58651  |  Link
i guess very bad d3d11 support from intel and how overlay works it ignores everything related to the OS so it's still the "same" since windows 7 and not as much affected by the changes in windows 10.
it's not like overlay is perfect you shouldn't be able to make screenshoots anymore.
Old 17th February 2020, 09:13   #58652  |  Link
Yog_Sothoth
I see. Now I remember that I wasn't able to make screenshots with madvr before, until I could at some point. I guess that's when it all started. Not a big loss.
Old 17th February 2020, 11:25   #58653  |  Link
zeus0r
hey there,
i have a pretty weird phenomenon lately... i'm not 100% sure but i think it started with the latest nvidia driver update.
following setup:
- win 10
- gtx 980
- latest mpc-hc / lavfilters / madvr
- philips 55pos901 oled
i've been using this setup for quite some time without any problems but i recently noticed wrong black levels for HDR content while SDR content is fine. (madvr hdr passthrough enabled)
rgb full range (0-255) is enabled in madvr settings and it currently gives me correct black levels for SDR content but i need to change it to 16-235 in order to get correct black levels for HDR content. (otherwise blacks are grey)
i checked this with some black level test files where 0-16 should be black and 17-25 flash.
0-255: correct SDR black levels but greyish blacks for HDR content
16-235: correct HDR black levels but bad black crush for SDR content
could this be a nvidia bug? or is there someting i am missing here?
zeus0r is offline   Reply With Quote
Old 17th February 2020, 15:53   #58654  |  Link
mclingo
when you say the colour space is wrong, is it too Dark which is why you have to set it 16-235, and do you set this in MADVR?
Does your TV envoke a seperate preset for HDR, if it does it may have somehow got changed to LOW instead of HIGH where it should be if you running a FULL RGB 444 chain.
OLED 4k HDR EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 1909 444 RGB -MD RX 5700 8GB 20.1.3 KODI DS - MAD/LAV 92.17+ 113 beta - 0.74.1 - 3D MVC / FSE:off / MADVR 10bit
Old 17th February 2020, 16:22   #58655  |  Link
Klaus1189
See also the dedicated driver thread here on doom9
AMD, Intel and Nvidia driver issues and last recommended version
Old 17th February 2020, 23:25   #58656  |  Link
tp4tissue
tp4tissue's Avatar
Guys did they recently change how the Highlight recovery works in the new beta versions.
I think i was on build 86 before updating today to 113, and toggling the highlight recovery doesn't seem to do anything now.
Ghetto | 2500k 5Ghz
Old 18th February 2020, 20:50   #58657  |  Link
SirMaster
Madshi hasn't mentioned any change to it.
It's working the same for me in 113.
SirMaster is offline   Reply With Quote
Old 18th February 2020, 22:25   #58658  |  Link
mclingo
Guys did they recently change how the Highlight recovery works .
it still works very well for me on 113, perfect scene to test it on is harry potter goblet of fire and the end when he's fighting Voldemort, on my 400 nit OLED there is virtually no detail in the ghost faces without using this.
https://1drv.ms/u/s!AgvFafeelEBij8k4...EE_-Q?e=HGjBrV
Old 18th February 2020, 23:30   #58659  |  Link
tp4tissue
tp4tissue's Avatar
Thanks guys, i rebooted the pc and it seems to be working now.
Ghetto | 2500k 5Ghz
Old 19th February 2020, 07:57   #58660  |  Link
madjock
I guess it is still quite hard to do at the moment, although we are at 113 revision wise.
But it would be nice to have an LCD/OLED section on what settings people are using. I as many probably use Neo-XPs settings.
I know like everything madVR a lot boils down to personal taste, but even at this late stage the settings for HDR are mind boggling and they always have been.
I am still not sure if I prefer HDR to tone mapping, I feel a bit stupid saying that as I should be able to tell, and from what I have read unless you have a really good HDR set which I do not have, the tone mapping will always be better.
@mclingo
Don't think thats 113 mate. this is
https://imgur.com/a/wQjETu3
