Old 11th June 2013, 23:36   #41  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for version 4.4
* Fix for when using audio copy with ffmpeg as encoder
Old 14th June 2013, 10:17   #42  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 4.5
* Added support for deblocking when using ffmpeg as encoder. Requires latest ffmpeg from git
* Cosmetics
Old 14th June 2013, 18:00   #43  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 4.6
* Added support for setting the amount of audio channels
Old 15th June 2013, 13:01   #44  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 4.7
* Ask for audio channels when user accepts the default audio codec
Old 28th July 2013, 11:49   #45  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 4.8
* Update DTS bitrates
Old 27th October 2013, 22:39   #46  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 4.9
* Added support for the Weston 3 Field Deinterlacing Filter for ffmpeg. Requires latest ffmpeg from git
Old 20th December 2013, 23:25   #47  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.0
* Detect Opus audio
* Set ffmpeg -threads option to 0 (auto-detect)
Old 10th May 2014, 11:59   #48  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.1
* Workaround for audio copy with MEncoder by using -mc 0 -msglevel demuxer=-1
Old 14th November 2014, 14:16   #49  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.2
* Clip the video bitrate to the auto-calculated value
* Set the buffer size to 1835k
Old 15th November 2014, 12:25   #50  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.3
* Detect TrueHD audio
* Fixed potential issue with min/maxrate
* Ask for which software scaler to use
* Tunings to the presets
Old 15th November 2014, 19:56   #51  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.4
* Added support for QP-based encoding (constant quantizer)
* Added support for custom presets
* Updated the man page
Old 16th November 2014, 16:30   #52  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.5
* Make bufsize work with qp-based encoding
* Bugfix: bufsize was missing for multipass encoding
* Do not leave a stale output directory behind in case something goes wrong
Old 17th November 2014, 13:08   #53  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.5.1
* Remove the call of clean_func if dvdauthor fails for some reason as it will also delete the encoded file, thus forcing the user to start the encode all over again
Old 6th December 2014, 11:34   #54  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.6
* Improved conversion from PAL -> NTSC Video and NTSC -> PAL when using ffmpeg as encoder
Old 6th December 2014, 14:29   #55  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.7
* Fixed A/V sync issues when converting from NTSC -> PAL and PAL -> NTSC
* Improved a bit the audio filters code
* Set maxrate to 9.8 Mbps
Old 7th December 2014, 15:29   #56  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.8
* When using mencoder as encoder, only ask for soft-telecine when input is detected as NTSC Film thus skipping the question if we detect NTSC Video. For PAL content, the behavior is unchanged
* Set the default scaler to bicubic
* Set the proper DAR when forcing the aspect ratio
Old 29th September 2015, 10:16   #57  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 5.9
* Fixed an issue where bicubic scaler was always selected despite user choosing something else
Old 6th August 2019, 22:47   #58  |  Link
KamUsedia
file2dvd for Linux
We are looking into this, but unfortunately its not for certain that we will have Trine or Shadowgrounds for Linux Steam. Thank you for your support
KamUsedia is offline   Reply With Quote
dvd, ffmpeg, file2dvd, mencoder, mpeg2
