Old 17th November 2017, 14:51   #3761  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Sigh, I was actually about to do some proper avx2 speed tests. Then I saw that there's no installer and I'm going to go eat cookies instead. That is all.
Old 17th November 2017, 15:37   #3762  |  Link
real.finder
put the Avisynth dll in same folder as avsmeter and it will work
iirc avsmeter allow you to use Avisynth dll from specific path too
My Avisynth Stuff
Old 17th November 2017, 16:00   #3763  |  Link
Also there is the Universal Avisynth Installer which is just as regularly updated as the github releases. Just check at least twice how to set up the batch file with custom installation directories before use, especially when the path may contain spaces.
Old 17th November 2017, 16:11   #3764  |  Link
Groucho2004
There's no problem with spaces. However, some special characters such as parentheses and ampersands need an escape character.
Groucho's Avisynth Stuff
Old 26th November 2017, 02:48   #3765  |  Link
jinkazuya
Just get a question for pinterf or anybody else who has experience with avisynth+ MT. Just wonder if it is ok to add support for using more than 10 threads in the next avisynth+ MT build. In other word, will CPU like intel Intel® Core™ i9 series or AMD Ryzen or Threadripper be fully taken advantages of all their cores? Cuz right now whenever I use more than 10 or 11 threads, then MEGUI or the x264 will crash or freeze and cannot use over 10 threads.
jinkazuya is offline   Reply With Quote
Old 26th November 2017, 05:26   #3766  |  Link
DJATOM
DJATOM's Avatar
jinkazuya
Just set reasonable Prefetch() and SetMemoryMax() and you will have near 100% CPU usage.
DJATOM is offline   Reply With Quote
Old 27th November 2017, 10:19   #3767  |  Link
pinterf
Yes, as the memory usage (cache) is somewhat linear to the number of Prefetch threads, you are probably experiencing memory full issues. You can try AvsMeter with your script to see whether the memory usage is the bottleneck.
As DJATOM said you can experiment with SetMemoryMax and Prefetch count to see where it saturates your available memory. x64 version is recommended however (I don't know which version you are using)
pinterf is offline   Reply With Quote
Old 29th November 2017, 16:55   #3768  |  Link
sneaker_ger
Question.
Script:
ffVideoSource("cut.mkv")
mask=MaskHS(160,180, 100,80).mt_expand().BilinearResize(last.width, last.height)
overlay(last, GreyScale().ColorYUV(cont_y=50), 0, 0, mask)
Sample: https://mega.nz/#!tpUhhSZR!6g1OSKRzZ...eQwTRxU2dkuTbo
AviSynth 2.6.0:
AvisynthPlus-r2544-MT:
Why does it become grey?
Old 29th November 2017, 17:21   #3769  |  Link
pinterf
Question.
Script:
AviSynth 2.6.0:
MaskHS is giving a black clip for me on classic avs, and white on current avs+. And the whiteish mask makes the greyscale clip dominant.
Checked: r2173 was still o.k.
Edit: fixed on github. MaskHS was giving the inverse mask.
Old 29th November 2017, 18:22   #3770  |  Link
sneaker_ger
Thank you.
Old 30th November 2017, 01:21   #3771  |  Link
jinkazuya
Ok, What do you guys suggest I do for the prefetch and setMemoryMax?
I have 32GB of ram and 16 cores? Even if I boost the setMemoryMax to higher number, checking and monitoring the RAM, the computer uses only about 3GB or 5GB most. But if I set prefetch over 10 to 11, then MEGUI crashes.
I uses x86 version cuz if I use the x64, most of the older plugins won't work.
Old 30th November 2017, 01:30   #3772  |  Link
DJATOM
DJATOM's Avatar
I'm using setmemorymax(32000) and prefetch(24) on dual socket Xeon 5675 server with ~50 GB RAM, average load near 99%.
Just forget about high prefetch values with 32 bit avisynth. You will hit 32 bit app memory limit.
Me on GitHub
PC Specs: Ryzen 3900X, 32 GB RAM, RTX 2070
Old 1st December 2017, 01:04   #3773  |  Link
jinkazuya
Then I guess you must encode 4k or 1080 bluray videos then. Is there a way for the 32bit plugins work with the x64 avisynth+? Or a way to make them backward compatible?
Old 1st December 2017, 01:23   #3774  |  Link
real.finder
that already discussed https://forum.doom9.org/showthread.p...30#post1824330
My Avisynth Stuff
Old 1st December 2017, 06:01   #3775  |  Link
edcrfv94
MP_Pipeline
But if you direct export or pass 9-32 bit clip will has green line on top, So need ConvertToStacked first.
edcrfv94 is offline   Reply With Quote
Old 1st December 2017, 06:20   #3776  |  Link
real.finder
Originally Posted by edcrfv94 View Post
MP_Pipeline
ConvertToDoubleWidth ConvertFromDoubleWidth will be faster
My Avisynth Stuff
Old 3rd December 2017, 06:10   #3777  |  Link
jinkazuya
Just wonder how to use the universal batch to set up avisynth+ x64...It is so confusing. Cuz whenever I used the regular avisynth+ installer, it always install avisynth+ into the "C:\Program Files (x86)", even I chose the x64 for avisynth+ installation. Then when I loaded the plugins for x64, the pop up appeared saying "cannot load x64 bit plugins dll into x86 avisynth+" something like that.
Old 3rd December 2017, 07:19   #3778  |  Link
^ You already asked that in the UAI thread where it belongs. This is an installer (usage) issue, not an AviSynth+ issue (the installer is not maintained primarily by AviSynth+ developers).
Old 3rd December 2017, 21:02   #3779  |  Link
jinkazuya
Not sure if somebody could port RedAverage plugin or some other plugins to x64. It would be awesome if somebody could maintain or port most of the old 32 avisynth or avisynth+ plugins to x64. Thanks.
Old 3rd December 2017, 22:28   #3780  |  Link
This may be impossible in all the cases where the original authors did not provide sources of their plugins, or did not document their algorithms detailed enough to reprogram them. But where it is possible, a lot of efforts were already invested to implement them. The AviSynth Wiki lists many successful attempts. If you know some missing ones, always provide links to their original location, optimally with sources. A few special plugins may even be easily resembled using very generic tools like convolution or LUT functions.
Specifically regarding "RedAverage", Average is reported to do the same, just faster.
