Old 23rd October 2007, 20:53   #121  |  Link
Sir Didymus
Cool...
I am very happy you feel BatchMux is suitable for the usage in AVStoDVD...
I planned to ask for such feature in the future, but you have been faster...
Please feel free to get in touch with me (in the public forum, the Italian one, or this one, or via PM) for any contribution or information I can provide on the matter...
In the meanwhile, may I ask to you to evaluate the possibility to keep BOTH authoring engines available for the users ?
I can easily provide good (objective) reasons for adopting MuxMan insted of Mplex/DvdAuth, however sometimes there are conditions where some glitches - more or less severe - in the input assets lead to fail the authoring job.
In these (rares... ) circumstances the availability af a valid authoring alternative can be useful, IMHO...
Cheers,
SD
Sir Didymus is offline   Reply With Quote
Old 27th October 2007, 08:42   #122  |  Link
DarkNite
Almost Silent Member
DarkNite's Avatar
I actually use CCE and 2-pass VBR when I feel the bitrate would be a little low for my liking. It results in higher quality, and since I paid for CCE why not have the option to use it?
Rethinking the "Why?" chromosome.
DarkNite is offline   Reply With Quote
Old 27th October 2007, 14:41   #123  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Have you made any comparison between HCenc and CCE video quality? You will be very surprised...
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 28th October 2007, 10:41   #124  |  Link
MysticE
@MysticE
Since the next release, I will replace DVDAuthor with MuxMan/BatchMux. That means multiplexing m2v+ac3 step is no more necessary. Will removing "Muxed MPEG2 Stream" choice cause you any troubles or may I do it?
Bye
Actually Muxed MPEG2 Stream is the Output choice I always use for the files I convert, but I guess I can simply rename the resultant VOB or continue to use 1.1.1.
MysticE is offline   Reply With Quote
Old 28th October 2007, 15:03   #125  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
If I may ask: what is the purpose to have one .mpg file instead of two .m2v+.ac3 files? I mean, if you play them with MPC, it will automatically append the audio; if you feed them to a DVD authoring program, you should be able to feed both video and audio.... so, why having one .mpg file only?
Bye
MrC
AVStoDVD Homepage
Old 17th November 2007, 15:18   #126  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 1.2.0 is available.
Change log:
- Sobstituted DVDAuthor package with MuxMan/BatchMux for authoring purpose
- HCenc is now the default "Very High Quality" encoder (included in installer)
- HCenc updated to 0.22
- QuEnc is the default "High and Standard Quality" encoder
- DGPulldown is now always used to upsize fps
- Removed support to CCE SP
- Removed "Muxed MPEG2 Stream" output
- Removed support to txt-based subs and added support to Scenartist/IfoEdit compatible subs.
- Revised "DC Precision" calculation routine
- Revised progress bar management in Progress Status Window
- Updtated Shutdown function: now it works from Win95 to Vista
- Added possibility to select Burning Drives not identified as "capable" to burn DVD
- Added check on Output Folder filesystem to prevent overcoming 4 GB limit
- Added Software Info (required software check) in Settings/System Window
- Moved HCenc Quant Matrix combobox to Settings Window
As usual, comments and suggestions are welcome. There are quite a lot of changes... bugs are for sure waiting to be discovered...
Bye
MrC
AVStoDVD Homepage
Old 18th November 2007, 03:25   #127  |  Link
Dkruskie
Thanks for the update MrC
Dkruskie is offline   Reply With Quote
Old 18th November 2007, 20:39   #128  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Everything's working? Any comments?
Bye
MrC
AVStoDVD Homepage
Old 18th November 2007, 22:13   #129  |  Link
buzzqw
HDConvertToX author
not my comment, but look at http://www.videohelp.com/tools/AVStoDVD , the most recent user seems have some problem
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 18th November 2007, 22:36   #130  |  Link
rendez2k
rendez2k's Avatar
I've got an issue too:
http://i68.photobucket.com/albums/i3.../AVS_error.jpg
Clicked OK and left encoding going and DVD creation fails at the end.
rendez2k is offline   Reply With Quote
Old 19th November 2007, 08:30   #131  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
BHH
That's the reason of my question...
Could you please post/email me the log file? Have you tried with HCenc? Same problem?
Thanks for the feedback.
Bye
MrC
AVStoDVD Homepage
Old 19th November 2007, 09:43   #132  |  Link
G_M_C
Why ? I use it, and on my dual-core system i get the best results/speed with it (and i've got lots of custom matrices to use with it).
G_M_C is offline   Reply With Quote
Old 19th November 2007, 10:58   #133  |  Link
rendez2k
rendez2k's Avatar
Just testing HC now with the same source but I got no initial AviSynth error.... Heres the log from the first encode. Authoring failed.
<19/11/2007 07:50:15>
JOB START
JOB SETTINGS
Source Video file: D:\Temp\CONTROL_DVDS.avi
Source Audio file: D:\Temp\CONTROL_DVDS.avi
MPEG2 Video Encoder: QuEnc
MPEG2 Encoding Options: High Quality (Normal Encoding Speed)
MPEG2 Advanced Options: Auto GOPs - Progressive
DVD Video Format: PAL
DVD Video Aspect Ratio: 16:9
DVD Video BitRate: 4706 (4706) kbps
DVD Audio Format: AC3
DVD Audio BitRate: 192 kbps
DVD Audio Language: EN - English
DVD Chapters Interval: 5 min
DVD Label: CONTROL_DVDS
Delete temp process files: Yes
Save Log file: Yes
Output Folder: D:\Temp\CONTROL_TEST
DVD Size: 4200 MB
DVD Output Setup: ISO UDF Image
SOURCE FILES
Video: D:\Temp\CONTROL_DVDS.avi
Info: AVI (XviD) - 1456 kbps - 640x352 - 16:9 - 25 fps - PPF - 1:57:01 hours - 175538 frames
Audio: D:\Temp\CONTROL_DVDS.avi
Info: AVI (AC3) - 192 kbps - CBR - 48000Hz - 2ch - 1:57:00 hours
Subs:
AVISYNTH SCRIPT
Video = DirectShowSource("D:\Temp\CONTROL_DVDS.avi", convertfps=true, audio=false)
Audio = DirectShowSource("D:\Temp\CONTROL_DVDS.avi", video=false).Normalize()
AudioDub(Video, Audio)
ConvertToYV12
AddBorders(0,4,0,4)
Lanczos4Resize(720,576)
QuEnc Parameters: -i "C:\DOCUME~1\ROBINE~1\LOCALS~1\Temp\CONTROL_DVDS_AVStoDVD.avs" -o "D:\Temp\CONTROL_TEST\CONTROL_DVDS_AVStoDVD.m2v" -b 4706 -maxbitrate 4706 -1 -hq -novbr -scene -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 9 -priority 5 -auto -close
<19/11/2007 09:14:15>
END VIDEO ENCODING OPERATIONS
Created File: D:\Temp\CONTROL_TEST\CONTROL_DVDS_AVStoDVD.m2v (2065351294 Byte)
START AUDIO ENCODING OPERATIONS
QuEnc (Audio) Parameters: -i "C:\DOCUME~1\ROBINE~1\LOCALS~1\Temp\CONTROL_DVDS_AVStoDVD.avs" -o "D:\Temp\CONTROL_TEST\CONTROL_DVDS_AVStoDVD.ac3" -priority 5 -1 -nohq -novbr -mpeg2mux novideo -audiocodec AC3 -audiobitrate 192 -auto -close
<19/11/2007 09:26:39>
END AUDIO ENCODING OPERATIONS
Created File: D:\Temp\CONTROL_TEST\CONTROL_DVDS_AVStoDVD.ac3 (168516096 Byte)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -d "D:\Temp\CONTROL_TEST\CONTROL_DVDS_AVStoDVD\VIDEO_TS" -mxp "C:\DOCUME~1\ROBINE~1\LOCALS~1\Temp\CONTROL_DVDS_AVStoDVD.mxp" -l "C:\DOCUME~1\ROBINE~1\LOCALS~1\Temp\CONTROL_DVDS_AVStoDVD.mxp.log" -muxman "C:\Program Files\AVStoDVD\MuxMan" -v "D:\Temp\CONTROL_TEST\CONTROL_DVDS_AVStoDVD.m2v" -vidmode LB -a1 "D:\Temp\CONTROL_TEST\CONTROL_DVDS_AVStoDVD.ac3" -a1lang en -a1ext 0 -celltc "C:\DOCUME~1\ROBINE~1\LOCALS~1\Temp\CONTROL_DVDS_AVStoDVD.mxp.txt"
<19/11/2007 09:55:59>
JOB COMPLETED.
Old 19th November 2007, 12:39   #134  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@rendez2k
Thanks for the log file.
One question: have you installed on your system .NET Framework? The issue seems to come from MultiCoreEnc (wrapping QuEnc) which is written in VB NET....
@G_M_C
Yes CCE SP support ended. As said before, I would push AVStoDVD users to switch to HCenc for very high quality encoding. Give a try to HCenc, you will be surprised by speed and quality. Or stay with AVStoDVD 1.1.3.
Bye
MrC
AVStoDVD Homepage
Old 19th November 2007, 12:43   #135  |  Link
rendez2k
rendez2k's Avatar
Pretty sure I have .NET Framework 2 or 3
Old 19th November 2007, 14:07   #136  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Ok, let's move ahead, if you will.
1. What Avisynth release do you have installed?
2. Did you have same error using release 1.1.3 (with multicore enabled - remember to rename file \AVStoDVD\Plugins\MultiCoreEnc_.exe to \AVStoDVD\Plugins\MultiCoreEnc.exe)?
3. Release 1.2.0: open AVS Script Window, uncheck "Automatic Script", and delete ".Normalize()" from end of line 2. Start encoding.
Thanks for the debug.
Bye
MrC
AVStoDVD Homepage
Old 19th November 2007, 15:29   #137  |  Link
Filbert
I've got probs with 120 too. After installation it refuses to start with an (in my case german) error message (rough translation): "Run-time Error 481: Invalid picture".
Previous versions worked ok, the error appears on 3 different PCs.
Thanks in advance, Filbert
[Edit] Just found out that windows wants to replace some files in the Windows directory with the ones from the original XP-CD (after installation of AVS120). Then it works ok. So some ".dll" or other files you install there seem to be incompatible with some XP installations.
Filbert is offline   Reply With Quote
Old 19th November 2007, 15:48   #138  |  Link
rendez2k
rendez2k's Avatar
[Edit] Just found out that windows wants to replace some files in the Windows directory with the ones from the original XP-CD (after installation of AVS120). Then it works ok. So some ".dll" or other files you install there seem to be incompatible with some XP installations.[/QUOTE]
I had that issue too on a UK English XP SP2 install
Old 19th November 2007, 21:39   #139  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by Filbert View Post
I[Edit] Just found out that windows wants to replace some files in the Windows directory with the ones from the original XP-CD (after installation of AVS120). Then it works ok. So some ".dll" or other files you install there seem to be incompatible with some XP installations.
Could be 2 old VB6 ActiveX (OCX). In the next release I will add the "Overwrite only if newer" check to the installer package for those files.
In the meanwhile I have removed 1.2.0 installer package from SourceForge page. There is still the No_Install package available for testing. Very, very sorry...
Bye
MrC
AVStoDVD Homepage
Old 30th November 2007, 10:41   #140  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Back on the topic. Some more troubleshooting
Did you try changing AVS Source method? Go to Settings/Encoding/AVS Source Filter and select "AVISource".
Same error?
Another (mayve silly) question: do you have DirectX 9 installed?
:wink:
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
