Old 26th September 2018, 17:58   #27761  |  Link
@ripem2011
I saw that error the other day... if you attempt to do the TSMUXER build manually you'll probably see a buffer underrun error. I haven't put my finger on the cause yet.
Just for s&g -- try editing the X265.BAT file in the WORKFILES folder, remove the "--no-b-pyramid" from the command line, and then execute the BAT. After it is done, run BD-RB again and continue the rebuild. Let me know if it finishes the build.
BTW: An encode that finished in 1 1/2 hours! What kind of processor are you using? Even a single pass ABR at "Very Fast" is taking me about 10 hours for a movie that size.
Old 26th September 2018, 18:02   #27762  |  Link
BD Rebuilder v0.60.02
I have updated the first link of this thread with a link to the newest version of BD Rebuilder (v0.60.02). Changes for this release:
- Added code to correctly handle 50/60fps
  sources when outputting to DVD.
- Updated the included version of
  X265-64.EXE to v2.8.69 10 bit version.
- Corrected an build error in v0.60.01 that
  could cause BD-RB to fail. Noticable when
  selecting multiple streams into the batch
  list -- may also possibly happen under
  other circumstances.
Old 26th September 2018, 18:19   #27763  |  Link
musiclover
The download link for v0.60.02 is not working correctly
Old 26th September 2018, 18:31   #27764  |  Link
AmigaFuture
AmigaFuture's Avatar
Confirmed not working here also.
Old 26th September 2018, 20:12   #27765  |  Link
Sorry. I misspelled it on the server! I fixed it.
Note to self: Test everything.
Old 26th September 2018, 20:13   #27766  |  Link
meadrocks
http://www.jdobbs.net/Freeware/BD-RBV06002.zip
meadrocks is offline   Reply With Quote
Old 26th September 2018, 20:38   #27767  |  Link
ripem2011
@ripem2011
lol i think it said that 1 1/2 hours because the first time it started to remux the power went out here so i had to restart it but i wish it took 1 1/2 hours it took 40hr my pc is rampage 4 extreme but i will do as you said and get back so see you in 3 days lol
ripem2011 is offline   Reply With Quote
Old 26th September 2018, 21:53   #27768  |  Link
musiclover
Thanks for the updated version. Making a dvd from a 50 fps source now works. Both in PAL and NTSC.
Old 26th September 2018, 23:30   #27769  |  Link
??? If you restarted, that would show in the log (like you can see in the other logs). I'm confused... unless, of course it ended at that time 2-3 days later.
Old 27th September 2018, 00:59   #27770  |  Link
spotswood
Windows 10 error
Hello... have just installed a fresh Windows 10 v1803 w/all updates and no other software, other than BDRB v60.02 (located in Downloads/BD_Rebuilder), AviSynth_260.exe and LAVFilters-0.65.exe. When running BDRB for the first time (Run as Administrator) Windows Defender flagged it as an unsafe program, which I chose open anyway, then get the error in the 1st pic attached. Tried running REG_MSCOMCTL.BAT as Administrator as well and get the error cannot find the specified module. What's going on? Thanks for any help...
spotswood is offline   Reply With Quote
Old 27th September 2018, 01:44   #27771  |  Link
MrVideo
MrVideo's Avatar
Where are you getting 50 frames/sec sources?
Old 27th September 2018, 09:17   #27772  |  Link
musiclover
BBC iPlayer webcast
Old 27th September 2018, 10:19   #27773  |  Link
Ch3vr0n
All EU dvd's are 50fps (that's the pal standard), speedup from 23.97(6) to 25 and then doubled.
Verstuurd vanaf mijn Nexus 6P met Tapatalk
Old 27th September 2018, 13:26   #27774  |  Link
Originally Posted by spotswood View Post
Hello... have just installed a fresh Windows 10 v1803 w/all updates and no other software, other than BDRB v60.02 (located in Downloads/BD_Rebuilder), AviSynth_260.exe and LAVFilters-0.65.exe. When running BDRB for the first time (Run as Administrator) Windows Defender flagged it as an unsafe program, which I chose open anyway, then get the error in the 1st pic attached. Tried running REG_MSCOMCTL.BAT and get the error cannot find the specified module. What's going on? Thanks for any help...
The first error has nothing to do with BD Rebuilder, since it isn't using the installer.
Did you run the .BAT file as administrator? Also, make sure you are running it from within that folder.
Old 27th September 2018, 13:27   #27775  |  Link
musiclover
That's not correct. All PAL dvd's are 25fps
Old 27th September 2018, 13:29   #27776  |  Link
PAL is 50 fields per second... 25 frames per second. The sources he's using are 720p/50fps (frames per second). You don't see a lot of that, even though they are part of the BD standard. That's probably why the bug went unreported for so long.
Old 27th September 2018, 17:18   #27777  |  Link
Ch3vr0n
@jdobbs just a heads-up, SPECIAL_3D_MUX isn't documented in changes.txt
Old 27th September 2018, 17:43   #27778  |  Link
Sharc
Some TV stations in Europe broadcast HD as 720p50 rather than 1080i25. I remember the hot debates about what is better when HD TV was introduced.
Secondly, many home videocams have the option to select 720p50 or 1080i25 (or now even 1080p50).
Given the fact that the true resolution (details) of home videocams came hardly ever close to 1920x1080 due the real-time compression artifacts, 720p50 has been a very reasonable compromise with no visible loss in true spatial resolution. Moreover, 720p50 needs not to be deinterlaced by the player/TV, avoiding deinterlacing artifacts.
Old 27th September 2018, 18:06   #27779  |  Link
Mark_Venture
@spotswood its outlined in step 3.1 in the OP instructions...
But to be honest, when I right click on the bat file and select "run as admin", It seems to fail because it always seems to try and run from C:\windows\system32 instead of the BD Rebuilder folder so it fails (because the OCX isn't in the win\system32 folder).
So its probably better to open an Administrative CMD prompt (Start -> Windows System -> right click on CMD Prompt -> More -> Run As Administrator)... When it launches, while in the window change to the BD-Rebuilder directory, and run the batch file from there (that is where the BAT file and the OCX file reside).... OR edit the BAT file, specify the path to the OCX file... then save/run it.
Old 27th September 2018, 18:18   #27780  |  Link
Ch3vr0n
@jdobbs SPECIAL_3D_MUX no change in PowerDVD 17, pixellation still present BUT reduced IMO using FRIM_SW_DECODE=0 and FRIM_SW_ENCODE=0 (and thus using hardware encoding), commenting out both lines (and pulling dummy display hdmi display plug) and running a 2nd test
