17th July 2010, 11:08 | #8823 | Link |
First of all: GREAT PROGRAM
I just tried to Backup Pelham_123 and BD Rebuilder failed to reencode 04999.m2ts Code:
- [10:39:16] Reencoding: VID_04999 (6 of 20) - [10:39:16] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 720 frames - Bitrate: 4.316 Kbs - [10:39:16] Reencoding: VID_04999, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. I first suspected ffdshow, so I reinstalled it, but no success. Arcsoft Mediaplayer gives me "unsupported file type" on the file and VLC player at least starts to play but without video, total length about 27:40 and stops playing at 3:35. I did several backups until now, but none had that file. Is there any strange codec, that has to be installed? Am I the only one with that problem? What am I missing? |
17th July 2010, 15:01 | #8824 | Link | |
2. Run INSPECT.EXE and post your results. 3. When posting logs -- I need to see the whole thing... |
17th July 2010, 16:03 | #8825 | Link | |
hoju3508 and jdobbs
Thank you for trying to help me but i have this problem after uninstall/install all need programs and doing all necessary operations. Before i had this problem i used a non-recommended version of Haali Media Splitter like hoju3508 but now it's everything ok in inspect.exe but i still have the same audio sync issues... Quote:
17th July 2010, 16:35 | #8826 | Link | |
17th July 2010, 19:50 | #8827 | Link |
1080i to 720
Not sure if this is a bug, or if I misundersand something.
My source is BD, 1080i, 25fps, MBAFF. (The video is actually progressive, the fields are identical i.e. no temporal shift between pairs of fields) I resize with BD-RB to 720. If my understandig is right, blu-ray spec requires 'progressive@50fps' for 720 resolution. BD-RB script: Code:
#Created by BD Rebuilder - v0.34.04 (beta) DirectshowSource("K:\......\00003.m2ts", fps=25, framecount=175445, audio=false) ConvertToYV12() LoadPlugin("C:\Program Files\VIDEO\BD_Rebuilder\tools\decomb521.dll") FieldDeinterlace() LanczosResize(1280,720).ChangeFPS(50) ConvertToYV12().AssumeFPS(25000,1000) - ChangeFPS(50) duplicates every frame to obtain the 50fps (350890 frames) for blu-ray compliancy for 720p, keeping the playback duration same as original. - AssumeFPS(25000,1000) frameserves the duplicated frames to the enocoder at 25fps. The encoded video stream (VID_00003.AVS.264) is eeventually reported as 720 progressive@25fps. Is this blue-ray compliant? Progressive is ok, but shouldn't it be 50 fps to comply with blu-ray specs? (In former versions of BD-RB the AssumeFPF(25000/1001) was not included..... IIRC.) Secondly, perhaps beyond the scope: the frame duplication as above slows the encoding process down significantly (2x). What about the alternative of just slowing down audio, video and sups to blu-ray compliant 24000/10001 in order to avoid the frame duplication? I personally wouldn't mind the slight audio pitch shift. Last edited by Sharc; 17th July 2010 at 19:57. |
17th July 2010, 20:25 | #8828 | Link | |
@cartman0208
Hi! Quote:
17th July 2010, 20:59 | #8829 | Link | ||||
- Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.4, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Quote:
[17:27:02] BD Rebuilder v0.34.02 (beta) - Source: PELHAM_123 - Input BD size: 39,88 GB - Approximate total content: [03:01:41.565] - Target BD size: 8,11 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [17:27:04] PHASE ONE, Encoding - [17:27:04] Extracting A/V streams [VID_00000] - [17:27:05] Reencoding: VID_00000 (1 of 20) - [17:27:05] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 346 frames - Bitrate: 1.905 Kbs - [17:27:05] Reencoding: VID_00000, Pass 1 of 2 - [17:27:26] Reencoding: VID_00000, Pass 2 of 2 - [17:27:53] Video Encode complete - [17:27:53] Reencoding audio tracks (if req'd) - [17:27:54] Multiplexing M2TS - [17:27:56] Extracting A/V streams [VID_00001] - [17:28:02] Reencoding: VID_00001 (2 of 20) - [17:28:02] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.176 frames - Bitrate: 862 Kbs - [17:28:02] Reencoding: VID_00001, Pass 1 of 2 - [17:29:07] Reencoding: VID_00001, Pass 2 of 2 - [17:30:41] Video Encode complete - [17:30:41] Reencoding audio tracks (if req'd) - [17:30:41] Multiplexing M2TS - [17:30:47] Extracting A/V streams [VID_00011] [17:36:42]PHASE ONE aborted by user request ----------------------- [19:47:17] BD Rebuilder v0.34.02 (beta) - Source: PELHAM_123 - Input BD size: 39,88 GB - Approximate total content: [03:01:41.565] - Target BD size: 8,11 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [19:47:18] PHASE ONE, Encoding - [19:47:18] Extracting A/V streams [VID_00011] [19:47:29]PHASE ONE aborted by user request ----------------------- [20:14:40] BD Rebuilder v0.34.02 (beta) - Source: PELHAM_123 - Input BD size: 39,88 GB - Approximate total content: [03:01:41.565] - Target BD size: 8,11 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [20:14:42] PHASE ONE, Encoding - [20:14:42] Extracting A/V streams [VID_00011] - [20:24:45] Reencoding: VID_00011 (3 of 20) - [20:24:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 152.376 frames - Bitrate: 5.391 Kbs - [20:24:45] Reencoding: VID_00011, Pass 1 of 2 - [22:43:43] Reencoding: VID_00011, Pass 2 of 2 [22:56:31]PHASE ONE aborted by user request ----------------------- [16:45:07] BD Rebuilder v0.34.02 (beta) - Source: PELHAM_123 - Input BD size: 39,88 GB - Approximate total content: [03:01:41.565] - Target BD size: 8,11 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [16:45:08] PHASE ONE, Encoding - [16:45:08] Reencoding: VID_00011 (3 of 20) - [16:45:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 152.376 frames - Bitrate: 5.391 Kbs - [16:45:08] Reencoding: VID_00011, Pass 2 of 2 - [21:05:57] Video Encode complete - [21:05:57] Reencoding audio tracks (if req'd) - [21:14:16] Multiplexing M2TS - [21:18:14] Extracting A/V streams [VID_00081] - [21:18:17] Reencoding: VID_00081 (4 of 20) - [21:18:17] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.440 frames - Bitrate: 2.955 Kbs - [21:18:17] Reencoding: VID_00081, Pass 1 of 2 ----------------------- [10:36:51] BD Rebuilder v0.34.04 (beta) - Source: PELHAM_123 - Input BD size: 39,88 GB - Approximate total content: [03:01:41.565] - Target BD size: 8,11 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [10:36:52] PHASE ONE, Encoding - [10:36:52] Reencoding: VID_00081 (4 of 20) - [10:36:52] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.440 frames - Bitrate: 2.955 Kbs - [10:36:52] Reencoding: VID_00081, Pass 1 of 2 - [10:37:55] Reencoding: VID_00081, Pass 2 of 2 - [10:38:59] Video Encode complete - [10:38:59] Reencoding audio tracks (if req'd) - [10:38:59] Multiplexing M2TS - [10:39:00] Extracting A/V streams [VID_00205] - [10:39:01] Reencoding: VID_00205 (5 of 20) - [10:39:01] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.554 Kbs - [10:39:01] Reencoding: VID_00205, Pass 1 of 2 - [10:39:08] Reencoding: VID_00205, Pass 2 of 2 - [10:39:15] Video Encode complete - [10:39:15] Reencoding audio tracks (if req'd) - [10:39:15] Multiplexing M2TS - [10:39:15] Extracting A/V streams [VID_04999] - [10:39:16] Reencoding: VID_04999 (6 of 20) - [10:39:16] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 720 frames - Bitrate: 4.316 Kbs - [10:39:16] Reencoding: VID_04999, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.34.04 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [10:39:20] - Failed video encode, aborted Quote:
18th July 2010, 02:18 | #8831 | Link |
Not sure what changed from 33.02 to 33.04 but what ever it was the disc's no longer play in my Sharp player but they still play in my Panasonic player. I just purchased the sharp player and all disc's that were compressed up to v33.02 play in the Sharp but none play that were done with 33.04. I even tried the strick option and re-compressed and burned and its a no go. Any ideas let me know? These are movie only and DVD9.
18th July 2010, 02:46 | #8832 | Link | |
18th July 2010, 02:50 | #8833 | Link | |
When I say "Update" it means the newest version. The full install is an "update" as well, only to everything, the zip file just contains the files that changed (those that were updated) that's why it is called "updates only". |
18th July 2010, 08:27 | #8834 | Link | |
Your new proposal sounds promising as it will also reduce the encoding time accordingly, I presume. I will be glad to test it |
18th July 2010, 18:44 | #8837 | Link | |
--pulldown double seems to be the perfect solution in this case (1080i@25fps -> 720p@50 fps). I just have to finalize the running encode, burn it and play it on the standalone for verification. |
18th July 2010, 18:55 | #8838 | Link |
jdobbs, any idea what has changed from 33.02 to 33.04 all movies done in movie only no longer play on my Sharp player. I was going to try it again with 33.02 but it no longer works. Any ideas I even selected strict in the setup but it did not work either. Thanks.
18th July 2010, 19:20 | #8839 | Link | |
18th July 2010, 21:46 | #8840 | Link |
I will re-run it again with the GOP unselected. Nothing has changed they just stopped working with 33.04 they do still work on the Panasonic so they are good but the Sharp does not like something it is seeing. I will let you know after it gets done and I test it. Thanks.
