17th August 2013, 00:13 | #17801 | Link | |
18th August 2013, 03:27 | #17802 | Link |
DGDecNV indexing issue: also present with main title (VID_00009) on Beautiful Creatures. Barcode 5412370850492
DGI file is only 3.633kb (3.54MB) for original video size of 30.203,29MB Processing of vid_00009 began at 3.58h, indexing ended and recoding started at 04.37. Extracting and indexing total time: 37min. Rather long for even my rig. Last edited by Ch3vr0n; 18th August 2013 at 04:12. |
18th August 2013, 08:41 | #17803 | Link | |
18th August 2013, 13:00 | #17804 | Link | |
Aging Video Hobbyist
I've learned this is only possible (or I should say easy) to do with BDEdit and the very simplest of disc structures. |
18th August 2013, 16:41 | #17805 | Link |
Feedback on problem
Thanks to laserfan & Amigafuture for your suggestions. I did uncheck the "AnyDVD Remove Annoying Adverts: Incompatible". Although the next attempt failed to encode as well, the AnyDVD status changed to "OK". I then uninstalled Avisynth, ffdshow, Matrska Split, and installed the updated versions. This corrected my encode failure problem. Since I did not change anything in these support programs, I can only assume that they "glitched" all by themselves! Long story short---problem solved---thanks for your support.
18th August 2013, 17:02 | #17806 | Link | |
18th August 2013, 18:00 | #17807 | Link | |
It has been suggested to uninstall and then reinstall those main three helper apps. (Avisynth, ffdshow and Haali) when a failed attempt occurs, which will usually avoid a bug report! |
18th August 2013, 18:16 | #17808 | Link | |||
20th August 2013, 09:43 | #17809 | Link |
Title: The Killing Series 3 (original Danish TV series)
job: Movie-only backup BD-RB 0.44.16 Disc 1: no problems what-so-ever. Disc 2: episodes 1-4 are fine, but audio sync is off (early) by approx. 1 second from the start in episode 5. INF Code:
[Status] LABEL=THE_KILLING_SEASON_3_DISK_2 VERSION=v0.44.16 (beta) SOURCE_SIZE=46593908736 SOURCE_VIDEO_SIZE=46593908736 TARGET_SIZE=25532825600 REDUCTION=.54798634183426 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=cat;eng;jpn;kor;spa; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=-1 INSTANCES=1 DGDECNV=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=6 REBUILD_COMPLETE=1 [00006] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5104131577 RATE=7978 SPLITS=1 NSIZE=0 FLINK=0 MLINK=0 [00007] APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4982164862 RATE=7981 SPLITS=1 AUDIO=1 NSIZE=0 FLINK=0 MLINK=0 [00008] APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5128032689 RATE=7983 SPLITS=1 AUDIO=1 NSIZE=0 FLINK=0 MLINK=0 [00009] APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5131749667 RATE=7992 SPLITS=1 AUDIO=1 NSIZE=0 FLINK=0 MLINK=0 [00010] APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5186729970 RATE=7978 SPLITS=1 AUDIO=1 NSIZE=0 FLINK=0 MLINK=0 NSTART=27000000 NEND=817376400 [00011] APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=16834 RATE=500 SPLITS=1 AUDIO= NSIZE=0 FLINK=0 MLINK=0 Code:
[08.18.13] BD Rebuilder v0.44.16 (beta) [15:02:32] Source: THE_KILLING_SEASON_3_DISK_2_00002 - Input BD size: 43,39 GB - Approximate total content: [04:52:43.959] - Target BD size: 23,78 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Ultra High Quality (Extremely Slow), Two Pass - Output folder: W:\_ENCODES\ - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Subtitle [1] is defaulted ON. [15:02:33] PHASE ONE, Encoding - [15:02:33] Processing: VID_00006 (1 of 6) - [15:02:33] Extracting A/V streams [VID_00006] - [15:17:44] Reencoding video [VID_00006] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 87*823 frames - Bitrate: 7*978 Kbs - [15:17:44] Reencoding: VID_00006, Pass 1 of 2 - [15:40:16] Reencoding: VID_00006, Pass 2 of 2 - [18:15:46] Video Encode complete - [18:15:46] Processing audio tracks - Track 4352 (dan): Keeping original audio - [18:15:46] Processing: VID_00007 (2 of 6) - [18:15:46] Extracting A/V streams [VID_00007] - [18:19:03] Reencoding video [VID_00007] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 85*692 frames - Bitrate: 7*981 Kbs - [18:19:03] Reencoding: VID_00007, Pass 1 of 2 - [18:40:38] Reencoding: VID_00007, Pass 2 of 2 - [21:22:06] Video Encode complete - [21:22:07] Processing: VID_00008 (3 of 6) - [21:22:07] Extracting A/V streams [VID_00008] - [21:25:29] Reencoding video [VID_00008] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 88*175 frames - Bitrate: 7*983 Kbs - [21:25:29] Reencoding: VID_00008, Pass 1 of 2 - [21:47:41] Reencoding: VID_00008, Pass 2 of 2 - [00:23:51] Video Encode complete - [00:23:52] Processing: VID_00009 (4 of 6) - [00:23:52] Extracting A/V streams [VID_00009] - [00:27:50] Reencoding video [VID_00009] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 88*142 frames - Bitrate: 7*992 Kbs - [00:27:50] Reencoding: VID_00009, Pass 1 of 2 - [00:49:48] Reencoding: VID_00009, Pass 2 of 2 - [03:25:09] Video Encode complete - [03:25:10] Processing: VID_00010 (5 of 6) - [03:25:10] Extracting A/V streams [VID_00010] - [03:28:32] Reencoding video [VID_00010] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 89*242 frames - Bitrate: 7*978 Kbs - [03:28:32] Reencoding: VID_00010, Pass 1 of 2 - [03:51:07] Reencoding: VID_00010, Pass 2 of 2 - [06:25:28] Video Encode complete - [06:25:29] Processing: VID_00011 (6 of 6) - [06:25:29] Extracting A/V streams [VID_00011] - [06:25:42] Reencoding video [VID_00011] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 25 frames - Bitrate: 500 Kbs - [06:25:42] Reencoding: VID_00011, Pass 1 of 2 - [06:25:43] Reencoding: VID_00011, Pass 2 of 2 - [06:25:43] Video Encode complete [06:25:43]PHASE ONE complete [06:25:43]PHASE TWO - Rebuild Started - [06:25:43] Rebuilding BD file Structure [06:30:55] - Encode and Rebuild complete - Computer SHUTDOWN initiated. Last edited by colinhunt; 20th August 2013 at 09:53. |
20th August 2013, 15:28 | #17810 | Link |
Well I follow all the instructions to installed BD_Rebuilder v0.44.16 but when I run it I have always the same error that FFDSHOW is not well configured.
Some months ago on an old version of the BD REbuilder I tried it and I never have any of this problem, the problem is that I don’t have any more that version and I don’t know what it was. Somebody can help me? |
20th August 2013, 15:40 | #17811 | Link | ||
21st August 2013, 10:05 | #17812 | Link | |
But It seems that I resolved the problem, when I installed AVCHDcoder, I didn’t have any more this problem. The only thing that I have now is, before compress my home Blu-ray movie made with Powerdirector to fit on a BD-9, with BD Rebuilter, I open it without problems with Nero Blu-ray player, and after compress it’s impossible to open it with Nero Blu-ray player. PS: BD Rebuilter didn’t gave me any error to compress this Blu-ray movie. Like I said, in old BD Rebuilter I never have this kind of problems, unfortunable I don’t remember what the version it was ok for me. I already try to run some old versions to see if I find it, but they are not anymore running. |
21st August 2013, 11:37 | #17813 | Link |
I ran a Quick-Play backup of The Killing season 3 disc 2 to see whether audio sync of last episode is affected. The audio sync is fine!
So, there's something going wrong when Movie-only process combines several m2ts files into a single one. That's when the audio sync of the last episode got messed up. Quick-Play does not combine files, so the last episode is an .m2ts of its own and the audio sync is fine. Unfortunately the Quick-Play backup is unplayable, because: [12:39:06]PHASE ONE complete [12:39:06]PHASE TWO - Rebuild Started - [12:39:06] Rebuilding BD file Structure [12:43:06]ERROR: Failed quick menu creation. No menus. [12:43:06] - Encode and Rebuild complete I must have tried Quick-Play a dozen times on a dozen different discs, and that's been the outcome every time: quick menu cannot be created. |
21st August 2013, 13:59 | #17814 | Link | |
21st August 2013, 14:04 | #17815 | Link | |
That error only occurs when X264 fails in an attempt to encode the menu. By the way, the Quick authoring still works when you get it -- it just doesn't show a pop-up indicating what is playing next. Last edited by jdobbs; 21st August 2013 at 14:31. |
21st August 2013, 17:31 | #17816 | Link |
This one wouldn't play on any software players or hardware media players (e.g. Popcorn Hour); tested on 4 software players and 3 hardware players. They start loading the data but give up, as if someone had pressed Stop. Usually that means it won't work on a stand-alone player either so I saved the BD-R for something else.
21st August 2013, 18:38 | #17817 | Link | |
21st August 2013, 18:52 | #17818 | Link |
I almost ran a quick-play backup last night. But decided since Disc 1, of a series of backups had already been done via Multiavchd, and a particular image was used for a background, I should stick with it. But I may have a job coming up, where it will be ideal.
I'll probably be using BD-Rebuilder more. It's becoming clear that Dean may not be supporting Multiavchd anymore. He doesn't reply to his threads, and there are clearly bugs in his program.
21st August 2013, 21:51 | #17819 | Link | |
