Old 12th April 2015, 21:16   #781  |  Link
sneaker_ger
Do the 64 bit builds linked on the google page not work for you?
https://code.google.com/p/xy-vsfilter/wiki/Downloads
Old 13th April 2015, 06:55   #782  |  Link
SecurityBunny
Doh! I feel like an idiot, completely neglected to look at the x64 section. Thanks.
SecurityBunny is offline   Reply With Quote
Old 26th April 2015, 07:27   #783  |  Link
dansrfe
Is there a way to render relative to madVR's frame so that the subtitles can be rendered within the black borders when e.g. 2.4 A/R video is full-screen on a 1.78 A/R screen?
Old 26th April 2015, 08:04   #784  |  Link
cyberbeing
Broadband Junkie
Recently madshi stated he had finally started work on supporting this in madVR, so hopefully we'll see support sometime soon. The delay up to this point is mainly because madVR currently has no capability of rendering anything in the black borders within the normal render chain, which requires madshi to do a somewhat major refactor.
That problem is somewhat unique to madVR though. For other subtitle consumers like EVR-CP & MPDN, all they'd likely need to do is request the subtitles repositioned as described in SubRenderIntf.h and it should just work.
Old 7th May 2015, 03:27   #785  |  Link
Magik Mark
Can somebody help with this:
I have no problem in playing xysubtitle as along as its embedded. External ones wont just load. I'm using madvr, mpcbe & reclock. All latest versions.
Old 7th May 2015, 06:32   #786  |  Link
cyberbeing
Broadband Junkie
Someone else had an issue with like this recently, and they were able to resolve it by completely uninstalling and then re-installing ReClock with default settings.
Old 7th May 2015, 06:53   #787  |  Link
Magik Mark
I just reinstalled reclock. Same problem. Is there a particular setting? Other subfilter renderer is working fine. I just prefer xysubfilter because of its HD rendering
Old 7th May 2015, 07:18   #788  |  Link
cyberbeing
Broadband Junkie
All the user said is they removed Reclock completely, reinstalled it, and removed everything from external filters in MPC-HC and then it worked. Does it work for you with MPC-HC instead of MPC-BE? Have you tried re-installing XySubFilter? You can also try some of the troubleshooting steps I listed here, but I'm not really sure what causes this since that user was able to resolve their problem with what I mentioned.
I suspect it's probably some kind of conflict with the ReClock Helper filter who's function has been rather mysterious and unreliable in the first place.
Old 10th May 2015, 01:48   #789  |  Link
Magik Mark
Did a clean install of my system. Subtitle rendering for both embedded and external are now working. However, for the external the txt is not HD. Tried tinkering the setting, nothing happens. Any thought guys?
Old 12th May 2015, 06:41   #790  |  Link
nijiko
Hi-Fi Fans
Is this one dead?
nijiko is offline   Reply With Quote
Old 12th May 2015, 08:14   #791  |  Link
I'd stay in stasis..
Old 13th May 2015, 03:30   #792  |  Link
nijiko
Hi-Fi Fans
There're too many bugs. And not update...
Old 20th May 2015, 21:18   #793  |  Link
ashlar42
Could anybody be so kind as to explain the Speed Ratio functionality under "Timing" panel? Say I have NTSC subtitles and I'd like to use them converted to PAL timings (+4% speed). How should I proceed?
Old 24th May 2015, 00:53   #794  |  Link
Thunderbolt8
which bugs, how many?
when watching movies or TV shows with .ass subs I never really spot any.
Old 26th May 2015, 01:56   #795  |  Link
ashlar42
Any news on this?
Old 19th June 2015, 20:29   #796  |  Link
xabregas
Any news on this?
Will it happen this year?
xabregas is offline   Reply With Quote
Old 13th July 2015, 16:12   #797  |  Link
jriker1
When using x-y-vsfilter with AVISynth do you have to "install" anything or just copy the vsfilter.dll to the avisynth plugin folder and reference textsub in the script?
Also I've read with vsfilter that it has some kind of box artifact around the subtitle when hard subbing, almost like it's applying the text as an image with transparent background but it's not quite transparent. Are there any noticeable artifacts that x-y-vsfilter creates?
Lastly, is there anyway to take a subtitle file that contains forced subtitles and tell it to only output the forced ones? Not sure if this can only be done in SUP files, which guessing isn't supported by x-y-vsfilter, but perhaps I'm mistaken. If it is, any way to convert a SUP file to another format and maintain the forced flag? Or do you just have to create a separate file with just the forced content and apply that?
JR
jriker1 is offline   Reply With Quote
Old 15th July 2015, 05:11   #798  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Exactly that. Text subtitles are displayed whole or not at all; forced subtitles become separate tracks that have just the forced content.
Old 15th July 2015, 10:11   #799  |  Link
Siso
Soul Seeker
Siso's Avatar
I was wondering if it would be possible to have an option for paragraph alignment for example left aligned paragraph subtitles?
Regards.
Old 16th July 2015, 11:18   #800  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Regards.
That's always been part of the SSA specs. Set the alignment field to 1 for left-justified. Unless you mean fully-justified, where width is always the same; that's not a part of the specs.
