Old 12th October 2011, 13:18   #1901  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@jmac698
ok, I will put CC support in my ToDo list
@rendez2k
source title audio track should be DVD compliant (DTS @16bit) and AVStoDVD should have kept it without re-encoding. Instead Aften+Wavi started with 1536 kbps bitrate setting (wrong, not supported by AC3). Have you changed anything in 'Edit Title'/'Audio'?
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 12th October 2011, 13:32   #1902  |  Link
rendez2k
rendez2k's Avatar
@jmac698
@rendez2k
Bye
Nope! Just left everything as is and hit start! Tried another MKV and it worked fine. Re-tested this one and it failed :-(
rendez2k is offline   Reply With Quote
Old 12th October 2011, 16:04   #1903  |  Link
Sir Didymus
Originally Posted by jmac698 View Post
You also have to set a flag in the IFO file.
I have never gotten CC to work in DVD. IFOedit doesn't let me set the flag, and ccmux didn't seem to work.
Jmac, did you ever try using AVS2DVD (current release) and feeding it with a m2v file with the user data containing CC information?
I feel it should work!
I mean, if you make a suitable (off line) preparation of the m2v assets, by using the SCC tools, the closed caption information should be - in theory - kept unaltered by the AVS2DVD operations and by the underlying muxing engine (MuxMan). This should also take care of the VBV potential issues raised elsewhere.
Concerning the setting of the IFO flags, this operation should be also NOT NECESSARY, since the IFO files are produced directly by MuxMan, at the end of the muxing stage, in a way that makes these files consistent with the input assets. In other terms, if the m2v assets contains CC, MuxMan should detect this situation and should produce (together with the other files) also suitable IFO files.
Sir Didymus is offline   Reply With Quote
Old 13th October 2011, 00:15   #1904  |  Link
jmac698
Sir,
Thanks! That's the best answer I've had. I will try again. It sounds like if I use muxman directly I can do it. I did look at muxman but found no mention of cc or user data. I had one hope that usiing ifoedit to set the flag would only be enabled if the input stream actually had cc data, so that would make more sense.
jmac698 is offline   Reply With Quote
Old 13th October 2011, 14:09   #1905  |  Link
laserfan
Aging Video Hobbyist
@jmac698 I've not followed this thread very carefully, so maybe you have reasons for wanting to keep CC, but you do know don't you that a tool called CCextractor will readily convert closed captions to .srt files, which you can use to make conventional DVD subtitles.
Old 13th October 2011, 14:27   #1906  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@rendez2k
could you please post a screenshot of 'Edit Title'/'Audio' tab? I would like to understand how AVStoDVD has messed up the audio section of that mkv title...
@Sir Didymus
welcome back there, my friend!
Bye
MrC
AVStoDVD Homepage
Old 13th October 2011, 14:40   #1907  |  Link
rendez2k
rendez2k's Avatar
@rendez2k
Sure! Posted my settings also just in case. Could the MKV be damaged? I've run another couple of MKVs through with no issue.
http://i51.tinypic.com/35jmsld.jpg
http://i54.tinypic.com/11vr229.jpg
Old 13th October 2011, 15:57   #1908  |  Link
Sir Didymus
@MrC
Thanks for the welcome... I have been totally absorbed by some personal and professional duties in the last months/years, but I am still following - in a more or less continuous way - the AVS2DVD developments, at least as a "silent" users...
@laserfan
Your suggestion is an excellent shortcut, however IMHO there are still very valid reasons and use cases for adopting CC in the DVD production. CC can be (optionally) showed TOGETHER - I mean, simultaneously - with a given subtitle stream. For instance, for hearing impaired people the CC is an optimal solution in order to preserve the original DVD content, including the original subtitles. There are no other ways, AFAIK, to present simultaneously two streams of subtitles: one - the classical subpictures - based on bitmaps, and the second - the CC - which is based on pure textual information...
Cheers,
SD
Old 14th October 2011, 13:13   #1909  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@rendez2k
I'm trying to replicate the issue with the sample files in my library, but I cannot. Do you have the possibility to upload somewhere a portion of the mkv?
@Sir Didymus
actually no big improvements in the past months... just some more encoding options and GUI maquillage. No progresses on the authoring side. I'm waiting for BatchMux native support to nested chapters menus
Bye
MrC
AVStoDVD Homepage
Old 14th October 2011, 15:13   #1910  |  Link
Sir Didymus
Ho, ho...
Sigh... I think I have to admit very frankly that I completely missed to make whatever improvement to the BatchMux frontend...
I an not in the position to ensure anything... Please consider that the topic is much more complex than it may appear at a first glance...
However, from an old PM discussion, I remind that the pending relevant improvements, from the authoring support side, are:
1. To save the BatchMux echo into a log file instead of using the stdout
2. To add audio/subs submenus for the language selection
3. To add chapters submenus, in order to select the chapters
Is the above list still complete?
Cheers,
SD
Old 14th October 2011, 16:38   #1911  |  Link
rendez2k
rendez2k's Avatar
Whats the best way to make a sample of an MKV? And how long would you need?
Old 14th October 2011, 21:05   #1912  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Sir Didymus
I'm sure the topic is absolutely complex and I know (and appreciate) the scrupulous way you have developed BatchMux. No hurry, take your time, when the update will be ready, we will be here. And, sure, from my side the list is complete. I don't know if other users would require anything else...
@rendez2k
I would use Avidemux:
- load the mkv
- trim the first minute
- select Copy Video and Audio (default)
- select MKV as output format
- save
Avidemux could eventually fix mkv muxing errors (if any).
Bye
MrC
AVStoDVD Homepage
Old 14th October 2011, 21:31   #1913  |  Link
rendez2k
rendez2k's Avatar
@Sir Didymus
@rendez2k
- load the mkv
- save
Bye
Well, Avidemux also failed (just an unspecified error when saving). So, I used mkvmerge and that worked OK. I retested the sample and that still failed with AVStoDVD.....
http://www.mediafire.com/?98hq976w3bwugn2
Old 15th October 2011, 03:05   #1914  |  Link
8ternity
8ternity's Avatar
Im Back after two weeks.
Just change all my pc!
Hope to continue and see differences! Back with a 6 cores, new motherboard, 16gb ddr3!
Old 16th October 2011, 03:33   #1915  |  Link
shreeit
Aspect ratio
I got .mkv file made from BD. The DAR is 2.353. When I convert to DVD program change DAR to 16:9. Is it possible to keep DAR 2.353?
Thanks,
Shreeit
shreeit is offline   Reply With Quote
Old 16th October 2011, 19:35   #1916  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@rendez2k
thanks, I will test the sample ASAP
@shreeit
2.353 DAR is not DVD compliant.
Bye
MrC
AVStoDVD Homepage
Old 18th October 2011, 15:20   #1917  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@rendez2k
bug found, it is releated to the combination of PAL-SpeedUp and DTS track. Next release will fix it. Now, as workaround, go to 'Preferences'/'Audio' and toggle off 'Keep AC3/DTS/MP2 DVD Compliant Audio', save as default and restart your project.
Bye
MrC
AVStoDVD Homepage
Old 18th October 2011, 17:40   #1918  |  Link
rendez2k
rendez2k's Avatar
@rendez2k
Bye
Thanks!
Old 22nd October 2011, 14:15   #1919  |  Link
jmac698
@laserfan
I have no interest in reading the CC whatsoever I wanted to create a known test signal for experimenting with VBI capture...
Old 28th October 2011, 22:28   #1920  |  Link
Shablagoo
Hello there. I'm frustrated. I keep getting the "output video duration shorter than expected" error and I don't know why. As soon as I get the error, I choose not to continue, who would?, and I click 'no' which aborts the whole thing. I'm working with an MKV file, but I've also gotten the error with an mp4 video. Here's the log.
<10/28/2011 11:05:19 AM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 8100/8100 MB (100%)
DVD Output Setup: Burn DVD
DVD Label: Biutiful
DVD Menu: No Menu
Output Folder: C:\Users\Alex\Desktop\AVStoDVD\OUTPUT
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: E: HL-DT-ST DVDRAM GSA-T20L NC08
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 0
TITLE 1 SOURCE FILES
Video: F:\Cinematic Adventures\Biutiful 2010 720p BRRip x264 RmD (HDScene Release)\Biutiful 2010 720p BRRip x264 RmD (HDScene Release).mkv
Info: AVC - 2010 kbps - 1280x696 - DAR 1.839 - 23.976 fps (CFR) - Progressive - 2:28:09 hours - 213124 frames
Audio 1: F:\Cinematic Adventures\Biutiful 2010 720p BRRip x264 RmD (HDScene Release)\Biutiful 2010 720p BRRip x264 RmD (HDScene Release).mkv
Info: AAC LC - 0 kbps - CBR - 6 ch - 48000 Hz - 2:28:09 hours (0 ms delay) - Internal
[MediaInfoLib - v0.7.47]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("F:\Cinematic Adventures\Biutiful 2010 720p BRRip x264 RmD (HDScene Release)\Biutiful 2010 720p BRRip x264 RmD (HDScene Release).mkv", CacheFolder="C:\Users\Alex\Desktop\AVStoDVD\TEMP", FrameRate=23.976, VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("F:\Cinematic Adventures\Biutiful 2010 720p BRRip x264 RmD (HDScene Release)\Biutiful 2010 720p BRRip x264 RmD (HDScene Release).mkv", CacheFolder="C:\Users\Alex\Desktop\AVStoDVD\TEMP")
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.AddBorders(0,12,0,12)
Video = Video.Spline64Resize(720,480)
AudioDub(Video, Audio)
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 7384.7 MB
QuEnc Parameters: -i "C:\Users\Alex\Desktop\AVStoDVD\TEMP\Biutiful_0_Biutiful 2010 720p BRRip x264 RmD (HDScene Release)_1.avs" -o "F:\Cinematic Adventures\Biutiful_0_Biutiful 2010 720p BRRip x264 RmD (HDScene Release).m2v" -b 6969 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<10/28/2011 3:01:32 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: FFmpegSource2 (cache off)
Created File: F:\Cinematic Adventures\Biutiful_0_Biutiful 2010 720p BRRip x264 RmD (HDScene Release).m2v (4096 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 7027 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:22:05 hours - 118095 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "F:\Cinematic Adventures\Biutiful_0_Biutiful 2010 720p BRRip x264 RmD (HDScene Release).m2v" -srcfps 23.976 -destfps 29.97 -inplace -tff
<10/28/2011 3:10:01 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: F:\Cinematic Adventures\Biutiful_0_Biutiful 2010 720p BRRip x264 RmD (HDScene Release).m2v (4096 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 7020 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:22:10 hours - 118211 frames
<10/28/2011 4:11:28 PM>
CHECK LOG FILE <C:\USERS\ALEX\DESKTOP\AVSTODVD\OUTPUT\BIUTIFUL_0.LOG> FOR MORE INFO.
<10/28/2011 4:11:33 PM>
Log file created by AVStoDVD Release 2.4.1
Shablagoo is offline   Reply With Quote
[IMG] code is Off
