Old 7th December 2016, 02:24   #2641  |  Link
mp3dom
I'm getting some problems loading a transparent PNG (a logo) and add it on a video using overlay.
The alpha from the PNG seems to be read just fine, but it's the "24bit" of the full 32bit PNG itself that are read with lots of artefacts (mainly "blocks" not available in the original image).
ImageSource and ImageReader both gives the same output.
With regular AVS 2.6 the same PNG/overlay works as expected.
Syntax:
logo=imagesource("logo.png",pixel_type="rgb32")
overlay(video,logo,mask=logo.showalpha())
mp3dom is offline
Old 7th December 2016, 08:23   #2642  |  Link
Of course, for most input formats they are just aliases of one single function. A difference might exist if you change the decoder, e.g. using DevIL or not.
Do you have samples of such wrong results (original image + wrong overlay result in a script)? I wonder where such issues appear, I could imagine in areas which should be completely transparent: Here the alpha channel may hide the fact that there are areas of full transparent color A next to full transparent color B, which would appear visibly if the transparency is incomplete by mistake. But then it may be rather in Overlay than in ImageSource.
Just a wild guess: Alpha channels are usual rather in RGB formats and should not have coring applied, even when the overlay result is in YUV format.
LigH is offline
Old 7th December 2016, 09:14   #2643  |  Link
pinterf
Syntax:
Tried it with a sample png from here and I can see no garbage.
Which Avisynth Plus version are you using?
pinterf is offline
Old 7th December 2016, 09:23   #2644  |  Link
pinterf
How much faster could "benchmark" scripts like QTGMC be when optimized for all these new features? Just starting with support of planar YUV with fine chroma subsampling...
I don't expect speed gain, unless the heavily used filters are optimized further. Maybe you can omit some YUY2<->YV16 conversions.
pinterf is offline
Old 7th December 2016, 09:46   #2645  |  Link
mp3dom
I'm using r2294.
Original image:
https://www.sendspace.com/file/ad7xdd
This is the alpha (correct):
http://116.imagebam.com/download/hau...2355/Alpha.png
This is the image without alpha (wrong):
http://115.imagebam.com/download/QWD...2359/Image.png
Final result with overlay (wrong):
http://116.imagebam.com/download/4mo...66/Overlay.png
mp3dom is offline
Old 7th December 2016, 10:00   #2646  |  Link
pinterf
I'm using r2294.
Original image:
Thanks, this PNG fails.
pinterf is offline
Old 7th December 2016, 13:48   #2647  |  Link
pinterf
mp3dom, thank you for the bug report.
New build, r2333 with Overlay fix:
http://www.mediafire.com/file/u44zj6...splus-r2333.7z
pinterf is offline
Old 7th December 2016, 14:06   #2648  |  Link
mp3dom
Thank you pinterf for the quick check, but I'm still getting the same result
mp3dom is offline
Old 7th December 2016, 14:49   #2649  |  Link
pinterf
Try with pc_range=true
Last edited by pinterf; 7th December 2016 at 20:14. Reason: remove tapatalk autosig
pinterf is offline
Old 7th December 2016, 15:27   #2650  |  Link
mp3dom
Setting pc_range=true, indeed, fixed the output in the right way, thanks!
Just asking: Is it right that when opening the png (either 32bit or forcing 24bit) with imagesource (without applying any overlay), the image is still blocky like in my previous example?
mp3dom is offline
Old 7th December 2016, 16:34   #2651  |  Link
shekh
png must be multiplied by alpha, this is normal
shekh is offline
Old 7th December 2016, 16:34   #2652  |  Link
pinterf
Yes, this png have only 0 and 255 values in rgb, the greyshades are only in the mask , alpha channel.
pinterf is offline
Old 7th December 2016, 17:29   #2653  |  Link
mp3dom
Ok! Thanks again for the quick fix
mp3dom is offline
Old 8th December 2016, 01:14   #2654  |  Link
Motenai Yoda
Motenai Yoda's Avatar
still get nothing than circle cursor and nothing else after launching avspmod x86 or x64 (same r452 ver)
with avsmeter it seems to work
powered by Google Translator
Motenai Yoda is offline
Old 8th December 2016, 01:52   #2655  |  Link
Groucho2004
AVSMeter does not use the C interface.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 8th December 2016, 02:30   #2656  |  Link
ajp_anton
ajp_anton's Avatar
fadein/fadeout don't work:
"BlankClip: color count 13 does not match to component count 3"
ajp_anton is offline
Old 8th December 2016, 02:40   #2657  |  Link
burfadel
Yes, I've come across that as well when trying to use LSFmod.
burfadel is offline
Old 8th December 2016, 03:59   #2658  |  Link
ajp_anton
ajp_anton's Avatar
Suggestion to CombinePlanes: if source clip only has a Y plane and "source_planes" is not set, use the Y plane.
Also, if "planes" is set, why do we need "pixel_type"? Can't "pixel_type" be figured out automatically, or am I missing some case when it can't?
Old 8th December 2016, 16:05   #2659  |  Link
fAy01
Ok, let's try this one:
http://www.mediafire.com/file/90d7qa...splus-r2331.7z
Changes since r2294: see above. Last change:
20161206 r2331dev
  • YUY2 PlaneToY
  • C interface compatible array-type AVSValue handling (avspmod issue)
I updated to the latest r3333 build. Avspmod is still not working.
Error parsing ArrayGet plugin parameters: unknown character 'a'
Error parsing ArraySize plugin parameters: unknown character 'a'
Error parsing BlankClip plugin parameters: unknown character 'a'
fAy01 is offline
Old 8th December 2016, 16:48   #2660  |  Link
pinterf
These are not fatal errors.
I have just tried 64 bit avspmod and it was producing me an exception and exited before start and was able to debug avisynth. After one more modification it works for me, those error-like warnings are still there of course.
pinterf is offline
