Old 24th February 2018, 15:41   #27081  |  Link
Originally Posted by DeathStalker77 View Post
I have been getting this specific error on a LOT of BDs lately. Whether it is trying to make a complete copy or shrink to ANY format
That is a "path not found" error. Are there any strange or unusual characters in the path name, maybe? Is it an exceptionally long path name?
Old 24th February 2018, 17:47   #27082  |  Link
DeathStalker77
Of the two most recent, one only had 21 characters and spaces, the other was 19 characters and the only "special" characters were [].
DeathStalker77 is offline   Reply With Quote
Old 24th February 2018, 22:16   #27083  |  Link
jfcarbel
Programmer
In order to keep Atmos audio is this correct understanding:
- TrueHD track must be selected
- Keep HD audio is selected in settings page
- Full Backup is selected
Is that correct?
jfcarbel is offline   Reply With Quote
Old 25th February 2018, 01:41   #27084  |  Link
worknstiff
@ jfcarbel RE: Too keep Atmos audio is this correct understanding:
Is that correct? Those must be checked but you don't have to do a "Full" backup, you can do a movie only, BUT it must be a BD25 backup. You can keep just the "Core" 1500k DTS if you do a DVD+R or DVD+R DL backup by leaving the "Keep HD Audio" checked. Backup to a DVD+R doesn't leave enough space to keep the ATMOS or TrueHD lossless audio.
Old 26th February 2018, 00:33   #27085  |  Link
jfcarbel
Programmer
Thanks was not sure movie only would work as I seem to see some prior posts indicating full backup. Yes, I understand the space atmos requires so a BD 25 or 50 is required.
Old 26th February 2018, 20:49   #27086  |  Link
DeathStalker77
I just got this on a path that was c:\temp\XXXXXXXX#### - 8 letters, 4 numbers, no spaces, no characters.
Old 26th February 2018, 21:15   #27087  |  Link
Sorry. I haven't a clue why you are getting it. But, the fact that I'm not getting any other similar reports leads me to believe it is something particular to your system.
Try deleting (or temporarily renaming) the BDREBUILDER.INI file and see what effect that has.
Old 26th February 2018, 21:25   #27088  |  Link
DeathStalker77
Ok, I can try that. Nothing special with my system. I don't do any encodes or anything like that, just shrink what I think doesn't need to be a BD50. FWIW, both DVDRB and DVDShrink work (and yes, I know diff codecs and diff files structures )
Old 26th February 2018, 21:47   #27089  |  Link
DeathStalker77
Even with a ONE letter path, it is still generating the same error. Deleting the INI, it is still generating the same error, and setting BDRB to not do ANY reduction results in the same error
Also, I do have Haali and ffdshow installed - and they are running when BDRB runs, if that is of any help.
Old 26th February 2018, 22:35   #27090  |  Link
DeathStalker77
FWIW, here are the 2 INIs - 1st from the BDRB main directory, the 2nd from the job directory -
[Options]
VERSION=0.50.0.24
ENCODER=0
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
TARGET_SIZE=23500
PRIORITY_CLASS=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=0
AC3_192=0
KEEP_HD_AUDIO=0
AUDIO_DRC=0
DECODER=0
AVCHD=0
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23500
[Paths]
SOURCE_PATH=C:\TEMP\M\
WORKING_PATH=C:\TEMP\M\NEW\
[Status]
LABEL=M
VERSION=v0.50.25
SOURCE_SIZE=31613603817
SOURCE_VIDEO_SIZE=31302899712
TARGET_SIZE=24641536000
REDUCTION=.777270863685282
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=3
REBUILD_COMPLETE=0
[00000]
AUDIO=111
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=23555272669
RATE=26457
SPLITS=1
NSTART=27000000
NEND=296641244
NSIZE=22893238272
FLINK=0
MLINK=0
[00045]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=290033611
RATE=13720
SPLITS=1
NSTART=27000000
NEND=33668537
NSIZE=270723072
FLINK=0
MLINK=0
[00080]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=485525615
RATE=26978
SPLITS=1
NSTART=27000000
NEND=32677547
NSIZE=446490624
FLINK=0
MLINK=0
And here is the log -
[02/26/18] BD Rebuilder v0.50.25
[15:50:19] Source:  M
  - Input BD size: 29.44 GB
  - Approximate total content: [01:45:50.594]
  - Target BD size: 22.95 GB
  - Windows Version: 6.2 [9200]
  - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448
[15:50:19] PHASE ONE, Encoding
 - [15:50:19] Processing: VID_00000 (1 of 3)
 - [15:50:19] Extracting A/V streams [VID_00000]
 - [15:53:00] Reencoding video [VID_00000]
   - Rate/Length: 23.976fps, 143,665 frames
   - Bitrate: 26,457 Kbs
 - [15:53:00] Reencoding: VID_00000, Pass 1 of 1
 - [16:20:13] Video Encode complete
 - [16:20:13] Processing audio tracks
   - Track 4353 (eng): Keeping original audio
   - Track 4354 (eng): Keeping original audio
 - [16:20:13] Multiplexing M2TS
 - [16:21:39] Processing: VID_00045 (2 of 3)
 - [16:21:39] Extracting A/V streams [VID_00045]
 - [16:21:45] Reencoding video [VID_00045]
   - Rate/Length: 23.976fps, 3,553 frames
   - Bitrate: 13,720 Kbs
 - [16:21:45] Reencoding: VID_00045, Pass 1 of 1
 - [16:22:21] Video Encode complete
 - [16:22:21] Processing audio tracks
 - [16:22:21] Multiplexing M2TS
 - [16:22:25] Processing: VID_00080 (3 of 3)
 - [16:22:25] Extracting A/V streams [VID_00080]
 - [16:22:31] Reencoding video [VID_00080]
   - Rate/Length: 23.976fps, 3,025 frames
   - Bitrate: 26,978 Kbs
 - [16:22:31] Reencoding: VID_00080, Pass 1 of 1
 - [16:23:05] Video Encode complete
 - [16:23:05] Processing audio tracks
 - [16:23:05] Multiplexing M2TS
[16:23:09]PHASE ONE complete
[16:23:09]PHASE TWO - Rebuild Started
 - [16:23:09] Rebuilding BD file Structure
 - [16:23:10] CopyDirStructure() 00076  1200
 - [16:32:58] CopyDirStructure() 00076  1200
 - [16:32:59] CopyDirStructure() 00076  1200
 - [16:33:00] CopyDirStructure() 00076  1200
 - [16:33:01] CopyDirStructure() 00076  1200
 - [16:33:02] CopyDirStructure() 00076  1200
[16:33:02] - Aborted per user request
Old 28th February 2018, 17:00   #27091  |  Link
DeathStalker77
Just getting this with more & more titles, no matter what the folder name Nothing's changed on my system except adding ffmpg and Haali Splitter
Old 28th February 2018, 20:26   #27092  |  Link
Something is wrong -- and I'm confident it isn't BD-RB. Otherwise I'd have 20 or more other people reporting it as well.
Old 28th February 2018, 20:31   #27093  |  Link
DeathStalker77
So I have no clue as to how to go about troubleshooting this I'll try running it on another system for the heck of it.
Old 28th February 2018, 23:36   #27094  |  Link
DeathStalker77
Ok, I just tried one of the same titles on a clean system that has never been used for anything but web surfing, and got the same error.
Old 1st March 2018, 00:28   #27095  |  Link
worknstiff
[@ DeathStalker77 RE: I got the same error.
I have noticed that you haven't posted an (Inspect) log, which is where I ALLWAYS start when I have any problems. It may show you some problem that's not obvious. Also I don't guess it makes any difference BUT I always use a different "Source" and "Working" drive. I find it doesn't bog my CPU down as much when it's reading and writing to the same one. I don't guess you're running any VM's or network drives are you?
Old 1st March 2018, 00:42   #27096  |  Link
DeathStalker77
FWIW, this is on an X99 system 6750k, 64gb RAM, and an SSD.
No, no VMs running. I've not seen an INSPECT log file - if you mean the BD-REBUILDER.LOG file, I did post that -
Old 1st March 2018, 15:24   #27097  |  Link
Click on "Help/Inspect (Show Settings)"
It could be a hidden folder with a bad name on the disc, maybe?
Old 1st March 2018, 15:26   #27098  |  Link
DeathStalker77
[03/01/18] Checking System Settings
- BD-Rebuilder v0.50.25
- Working Path Free Space: 153.18GB
- AVISYNTH Version: 2.6.1.0, not recommended version
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 4532, not recommended version
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[03/01/18] Systems Settings Check complete
Interesting that AVISYNTH and HAALI say they aren't the recommended versions, as they are the official versions from the websites. Anything I can try?
*I'll check for hidden folders.
Nope, checked and no hidden folders, no odd named folders - just what one would normally expect
Old 1st March 2018, 15:31   #27099  |  Link
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
Yes. Read the first post of this thread... and download the correct versions. I doubt that has anything to do with your problem, though. But you never know.
CopyDirStructure() is a very simple routine consisting of 33 lines of code. It simply steps through the folder structure on the source and re-creates it on the destination. Somewhere in that process a path is presented that kicks off that error. The error isn't coming from BD-RB, it is coming from the operating system. BD-RB is only reporting it. It's possible that the path may be too long, as well as having bad characters in it. You'd have to look through the source structure to find out.
Old 1st March 2018, 17:38   #27100  |  Link
DeathStalker77
Ok, ffddshow has a lot of options to select when installing it - just take the default ones? Or are there specifics (some are not selected). Thanks!
