Old 16th May 2020, 09:00   #29401  |  Link
ChuckUFarley
Has "OUTPUT_FOLDER=" been removed as an option in the Config or is it now "OUTPUT_PATH=" like SOURCE_PATH and WORKING_PATH?
I have OUTPUT_FOLDER set and the folder exists, but the final disc still gets dropped in the working folder.
ChuckUFarley is offline   Reply With Quote
Old 16th May 2020, 11:50   #29402  |  Link
Ch3vr0n
Not that i know of, but the output folder needs to exist PRIOR to beginning the encode. BDRB checks for valid paths before encoding.
Old 16th May 2020, 19:29   #29403  |  Link
ChuckUFarley
As I said, the folder does exist. It's just ignored.
Old 19th May 2020, 05:11   #29404  |  Link
AmigaFuture
AmigaFuture's Avatar
Originally Posted by gamete View Post
One question
Is it possible to read a guide for every option ?
Because bdrebuilder is a wonderful software but i have fear that i dont use it in the best way because i dont know the effects if a set all the option on or off
Thanks guys
Yup, this is it..we're it. Along with DJ commenting. Don't have fear when using it, just practice. Depends what you want to do. Most times I don't rerender my BDs to BD25 anymore, I'm keeping backups on Hard Drives. There isn't really a "best way". Sometimes with some discs that only have the movie, I copy them to portable Hard Drives...then I'm able to use my TV, BD Player, or whatever..in Lossless quality. Which beats the digital junk (haha) they offer with my originals.
Practice, play around, report bugs. Ask...but don't forget logs.
How does a program "drop" it in a folder? Haha!
"OUTPUT_FOLDER=p p = Path to a folder to be used for output. e.g. OUTPUT_FOLDER=D:\OUTPUT (it must exist)"
I don't recall it being removed or disabled.
Old 19th May 2020, 10:49   #29405  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by AmigaFuture View Post
in Lossless quality
Sorry, but all blu-ray and UHD video releases are lossy.
Old 21st May 2020, 12:09   #29406  |  Link
Tyrell63
BD Rebuilder Error
v0.61.05
Trying to "rebuild" a whole BD-50 to a BD-25
Here is the error:
[05.21.20] BD Rebuilder v0.61.05
[14:42:16] Source: UNDERWATER
- Input BD size: 39,63 GB
- Approximate total content: [03:02:06.073]
- Target BD size: 22,95 GB
- Windows Version: 6.2 [9200]
- Auto Quality: Very Good (Very Fast), ABR
[14:42:20] PHASE ONE, Encoding
- [14:42:20] Processing: VID_00800 (1 of 14)
- [14:42:20] Extracting A/V streams [VID_00800]
- Extracting video streams [VID_00800]
- Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information.
- Error in attempt to extract video.
[14:42:27] - Failed to retrieve audio, aborted
Tyrell63 is offline   Reply With Quote
Old 22nd May 2020, 03:22   #29407  |  Link
MrVideo
MrVideo's Avatar
The disc has been decrypted, right?
Old 22nd May 2020, 04:13   #29408  |  Link
ChuckUFarley
I pulled out a backup INI file and discovered that the "OUTPUT_FOLDER=" needs to be in the [Options] section not [Paths]. I'll test that later tonight.
Is there a setting for imported video files to have subtitles on by default?
Old 22nd May 2020, 23:27   #29409  |  Link
You can right click on it after an import and default a subtitle on when you do the encode and/or build.
Old 23rd May 2020, 04:31   #29410  |  Link
ChuckUFarley
That's weird. I kept trying that and it wasn't working. Now it is. I feel stupid.
And yes, "OUTPUT_FOLDER=" needs to be in the [Options] section. That worked fine.
Old 26th May 2020, 21:53   #29411  |  Link
AmigaFuture
This has all been discussed for many years now. Blu-ray/UHD are made with lossy quality, they are compressed (lossy). When you're making a backup of a BD and not reencoding anything, you're making a Lossless copy...just getting rid of extras you don't want.
Old 2nd June 2020, 21:34   #29412  |  Link
TheIceman
I hope there's an easy answer to this question. And no, I didn't read all 1471 pages in this forum to try and find it.
How do I enable video card (CUDA) acceleration in BDRB? I'm currently using v0.61.05, Win10.
Yes, my PC can handle 4K. Yes, my CUDA acceleration works with other programs like Adobe & FAB. So, what setting do I need to modify in BDRB or its' supporting programs to get this performance advantage???
Using a 2hr 4K file, and encoding to a high quality 25G output: FAB takes about 90mins, BDRB takes 19hrs. I really like BDRB, but the encoding time difference is Huge.
Any advice would be appreciated. Thanks in advance!!
TheIceman is offline   Reply With Quote
Old 3rd June 2020, 16:20   #29413  |  Link
SquallMX
Special SeeD
BD Rebuilder does not uses CUDA Hardware Acceleration, software encoding provides better quality but is always slower.
SquallMX is offline   Reply With Quote
Old 3rd June 2020, 21:30   #29414  |  Link
Ch3vr0n
BDRB doesn't no, because it's basically just a GUI for the command line tools like x264/x265 which DO use the CUDA/NVENC cores
Old 3rd June 2020, 23:15   #29415  |  Link
MrVideo
MrVideo's Avatar
I've never seen the x264 encoder use my nVidia CUDA GPU. I need a newer card for H.265 encoding.
Old 4th June 2020, 13:21   #29416  |  Link
That is absolutely false. BD-RB is much, much more than that. But the actual encoding itself is done by X264/X265/FRIM.
Old 4th June 2020, 13:23   #29417  |  Link
The decoding may (if set properly) uses the CUDA core, but not encoding.
I still have NVIDIA's NVENC on my "to do" list.
Old 4th June 2020, 14:24   #29418  |  Link
Ch3vr0n
Oh I know it is. No offense meant, I was just simplifying it. That's all. It does a everything but encoding
Sent from my Pixel 3 XL using Tapatalk
Old 4th June 2020, 16:31   #29419  |  Link
MrVideo
MrVideo's Avatar
Yep, it does indeed. The discussion was about encoding. Plus x264 isn't used for decoding.
Old 4th June 2020, 17:40   #29420  |  Link
Ch3vr0n
This isn't meant as advertising by any means. Just as a reference, i have many tools in my video processing library (BDRB still being used, before this one even was released, my alternative (Elaborate Byte's "CloneBD" does full hw acc decoding and encoding. Shrinking a full size BD50 to BD25 on my GTX1080 takes me under 15 minutes with it. Though for my 3D discs, nothin beats BDRB (yet )
@jdobbs if you believe this post is violating your topic in any way. Feel free to edit/remove it.
