Old 15th March 2010, 02:11   #7281  |  Link
@ozmale
That means you have probably removed them with the settings in SETUP or via the streams list. My recommendation is to always keep all the subtitles. They're small enough that most of the time you don't have to worry about them -- and sometimes its hard to distinguish which you want and don't want just based on language.
Old 15th March 2010, 02:23   #7282  |  Link
ozmale
I was pretty sure I had selected all subtitles but will do it again and manually ensure all are selected.
Will let you know how I go.
Chris
Ozmale
ozmale is offline   Reply With Quote
Old 15th March 2010, 13:02   #7283  |  Link
ozmale
Ok,
Just did the bourne ultimatum again.
"Full back" mode the missing subtitles appeared
"movie only mode" the subtitles are still missing
Chris
Ozmale
Old 15th March 2010, 16:11   #7284  |  Link
DK
DK's Avatar
Originally Posted by ozmale View Post
Ok,
Chris
I experienced something similar the other day: doing district 9 movie only
The problem was my player setup.
After the player returned from service I did not check each and every setting and that was exactly the problem: I had not set languages properly so that the "forced subtitles" did not appear.
32.08 definitely was NOT to blame in my case in movie only mode (BD-25) but my player's settings - maybe you could doublecheck/change yours?
Old 15th March 2010, 21:38   #7285  |  Link
ozmale
DK, I welcome your comment but dont think that is the problem.Have two desktop players and totalmedia theatre on the PC all have not had any settings changed but all exhibit the same problem.
Ozmale
Old 15th March 2010, 21:45   #7286  |  Link
Race Guy
Ok,
Chris
Hey Chris! To get a "forced" sub to be on in movie only, you have to know:
1) Which sub that is, & once you know that:
2) You have to right click on that sub in the "streams" tab & select "Turn Subtitle ON"
Correct me if I'm wrong, jdobbs, but from my experience, I don't think that "on switch" is happening "automatically" in movie only mode.
Race Guy is offline   Reply With Quote
Old 16th March 2010, 00:15   #7287  |  Link
ozmale
Race Guy,
Thanks heaps for that. Was not aware of the "right click" option. However you are right which subtitle is it ?
It appears you can only switch one on which it obvious i guess.
Am using Bourne movie as an example there are a total of 33 subtitles and 4 English ones.
I guess i will have to use trial and error to determine which one.
Chris
Ozmale
Old 16th March 2010, 05:20   #7288  |  Link
In movie-only you have to know the sub and force it on manually.
Old 16th March 2010, 05:37   #7289  |  Link
ozmale
Jdobbs
Any ideas on how to find out which one to select manually ?
Chris
Ozmale
Old 16th March 2010, 06:45   #7290  |  Link
Race Guy
Jdobbs
Chris
On my Oppo, when you play the original & hit the info button, it'll tell me which sub is on. Something like "6/8 Eng".
In that example, it would be the sixth sub on a list of eight. That would directly correspond to the list you'd see in the BD-RB streams tab.
Old 16th March 2010, 07:16   #7291  |  Link
MorbidPenguin
Been trying this on Win7 x64. I have the Matroska Splitter and FFDshow 3133 from the first page. I ran the Video Decoder settings and set MPEG-2 to Libavcodec and have tried VC-1 on both wmv9 and disabled. Nothing seems to work.
[14:03:25] BD Rebuilder v0.32.08 (beta)
- Source: THE_DARK_KNIGHT
- Input BD size: 23.26 GB
- Approximate total content: [07:09:48.481]
- Target BD size: 7.72 GB
- Windows Version: 6.1 [7600]
[14:03:27] PHASE ONE, Encoding
- [14:03:27] Extracting A/V streams [VID_00007]
- [14:03:27] Reencoding: VID_00007 (1 of 5)
- [14:03:27] Collecting video information
- Rate/Length: 23.976fps, 218,981 frames
- Bitrate: 200 Kbs
- [14:03:28] Reencoding: VID_00007, Pass 1 of 2
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- FFDSHOW Revision: (3133)
- Win 7: VC-1 is not configured for FFDSHOW
- FFDSHOW: VC-1 not set to wmv9
[14:03:29] - Failed video encode, aborted
Could I possibly be missing a setting somewhere? I've tried changing the settings on both FFDshow and FFDshow x64, but neither seems to make much of a difference.
MorbidPenguin is offline   Reply With Quote
Old 16th March 2010, 13:01   #7292  |  Link
colinhunt
Perhaps that's your problem. I know my system started behaving a lot nicer once I uninstalled the 64-bit FFDshow.
Old 16th March 2010, 13:03   #7293  |  Link
rotty
subtitle
Jdobbs
Chris
I had the same problem with "The Mummy". The forced English subtitle I needed to make sense of the movie was NOT a standard subtitle stream. It was never resolved, may even be a Java prog giving that sub.
Tsmuxer could not see it
rotty is offline   Reply With Quote
Old 16th March 2010, 13:39   #7294  |  Link
ozmale
Rotty,
Race guy & Jobbs are correct you need to find the correct stream and select it manually. Thus I may have solved your problem and fixed mine as well.
For my "bourne" example, my set top players only show 15 subtitle streams yet BD_rebuilder shows 32. So how do I find the correct stream to force ? Well I found that the PC player "TotalMedia Theatre" lists in its subtitle selection menu 32 streams and it had already selected stream 28, which was the missing subtitles. I then redid "The Bourne Ultimatum" with all subtitles but with stream 28 manually selected as suggested jdobbs said in previous post and it all worked fine.
It would seem we need a tool that shows all the subtitle stream and the one that is selected by default. For me at least TotalMedia Theatre seems to do that.
Many thanks to all who have helped with this problem
Chris
Ozmale
Old 16th March 2010, 13:55   #7295  |  Link
MorbidPenguin
My bad. For some reason, I thought it was installing both x86 and x64 versions with the one installer. I've completely uninstalled both with Revo, ran CCleaner, restarted, and ran CCleaner again to make sure no remnants remained.
I still have the same problem, though. After installing FFDshow and enabling MPEG-2, I get this error:
[20:26:41] BD Rebuilder v0.32.08 (beta)
- Source: THE_DARK_KNIGHT_BDR
[20:26:43] PHASE ONE, Encoding
- [20:26:43] Extracting A/V streams [VID_00007]
- [20:26:44] Reencoding: VID_00007 (1 of 5)
- [20:26:44] Collecting video information
- Bitrate: 200 Kbs
- [20:26:44] Reencoding: VID_00007, Pass 1 of 2
[20:26:44] - Failed video encode, aborted
After going into FFDshow and setting VC-1 to wmv9, I get this error:
[20:27:07] BD Rebuilder v0.32.08 (beta)
[20:27:09] PHASE ONE, Encoding
- [20:27:09] Extracting A/V streams [VID_00007]
- [20:27:09] Reencoding: VID_00007 (1 of 5)
- [20:27:09] Collecting video information
- Bitrate: 200 Kbs
- [20:27:09] Reencoding: VID_00007, Pass 1 of 2
[20:27:10] - Failed video encode, aborted
So, I'm still back where I started. What's my next move in trying to get this to work?
Old 16th March 2010, 18:33   #7296  |  Link
e143slime8
Bourne Identity and Bourne Supremacy burning problem. Used Slysoft 6.6.2.6 along with BDRebuilder 0.32.08. Have backed up over 50 movies to BD-r 25G discs without a hitch (except for Wizard of Oz, would not compress and play). Have just found that neither of these "Bourne" backups will play on my Panasonic BD-60 beyond the "extras" sections. The extras will play fine but when I go to play the movie, the player hangs then reverts back to the Main menu. I am also not able to choose individual chapters to play. The same result occurs, hangs then back to Main menu. Same result on both of the Bourne discs mentioned above.
Any help solving this mystery (to me anyway) would be greatly appreciated.
Thanks much.
e143slime8 is offline   Reply With Quote
Old 17th March 2010, 00:12   #7297  |  Link
ibanez
Jdobbs
Chris
I normally extract all the subtitles with the relevant language with Eac3to, which will identify the number of lines of "forced" subtitles - I then include that track.
I have found there are a number of ways forced subtitles are included - either in the main subtitle track (with a number of lines marked as forced - this seems the most common) or a seperate subtitle track (that only has the forced).
I don't have time to check my previous backups at the moment, but if the forced subs are part of the main subtitle track, and you do a movie-only backup and include those subs, and you therefore have to force the sub on manually, will you see all the subtitles or just the forced ones?
It would be good if BD-RB was able to identify those tracks that contain forced subtitles to make it easier to identify which ones to include - but as far as I'm aware (from the Eac3to notes) you can only tell with Blu-ray if subs are forced after you extract the entire subtitle track (unlike hd-dvd). Even better, it would be good to be able to extract just the forced subs from the track (if they are a part of the main subtitle track) and include them (I guess this should be for the feature requests thread).
ibanez is offline   Reply With Quote
Old 17th March 2010, 01:53   #7298  |  Link
Capsbackup
Have you tried the suggestions listed here?
http://forum.doom9.org/showthread.php?t=151633
Old 17th March 2010, 01:56   #7299  |  Link
rotty
subtitles
Rotty,
Chris
Hi
The problem is that "The Mummy" has well over the 32 subtitles streams. I can see all of them on my s/w player and know which one I need to force BUT only the standard 32 are shown in tsmuxer.
The subtitle stream I need is 36 or something like that (cant remember off the top of my head).
SO either they are some kind of txt only subs that tsmuxer cannot resolve OR the extra (above 32) subs are java generated.
Its the only movie ive come across with this problem.
Old 17th March 2010, 03:58   #7300  |  Link
Data24
Sometimes BD Rebuilder removes the audio stream for the second video stream. What is the condition for BD Rebuilder to do so? Is it possible to force the audio streams to stay?
Data24 is offline   Reply With Quote
