Old 30th September 2019, 12:20   #57481  |  Link
mclingo
ok no probs, i'll have a look tonight then when I get home.
Old 30th September 2019, 12:34   #57482  |  Link
mclingo
when you watch it yourself does it look anything like this or is it more washed out?
https://1drv.ms/u/s!AgvFafeelEBii5t3...QgLCQ?e=OpI01j
This is how it looks for me using MPC-BE with HDR-SDR conversion (viewed on a none HDR monitor from work)
https://1drv.ms/u/s!AgvFafeelEBii5t4...OGZMg?e=tyjvy3
Old 30th September 2019, 13:24   #57483  |  Link
DMU
More like a 2nd screenshot. Please download my photos
1 - AMD HDR
2 - Windows HDR (Movies & TV)
3 - TV HDR
and you will see how it looks.
1 - AMD HDR colors are not saturated than others.
DMU is offline   Reply With Quote
Old 30th September 2019, 13:44   #57484  |  Link
mclingo
those links werent working for me initially, they are now.
Allowing for differences in exposure they are all quite similar, there are some differencies in colour though, the MADVR image has more blue, or the other images have too much red, its hard to know. They all look too light but that could just be the photo exposure.
Does you TV have info message that tells you its going into HDR mode as MADVR maybe the only player thats actually going into HDR mode, the other two might be converting to SDR, if this is the case the preset your TV is envoking for HDR material might set wrong which is why SDR looks ok.
Update your sig with the kit / setup you are using.
Old 30th September 2019, 14:17   #57485  |  Link
mrmojo666
1 - AMD HDR
3 - TV HDR
IMHO your screenshot from amd hdr looks perfect, no oversaturated skin. maybe there is just a bit green shift (as i can see on hair).
but with compressed image and my laptop monitor could make me wrong.
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
Old 30th September 2019, 14:21   #57486  |  Link
DMU
Exactly. Especially visible by skin tone.
In all three cases the TV was in HDR mode.
My setup:
Win10 Pro 1903, 19.9.2 AMD driver, MPC-HC v1.8.7, madVR v0.92.17.
Ryzen 3 2200G with Vega8 iGPU.
Samsung UE40NU7100.
Old 30th September 2019, 15:03   #57487  |  Link
ashlar42
Originally Posted by wushantao View Post
i want to upgrade my graphics card
now i use sony 900f,maybe I will buy another 950g
rx590,rx5700,rtx2060,which one is better for madvr only?
Due to RTX series cards being included in the Envy hardware solution that madshi is working on, there is the possibility (not certainty, mind) that the RTX 2060 could allow you in the future to access more features.
Old 30th September 2019, 15:38   #57488  |  Link
mclingo
My setup:
Samsung UE40NU7100.
you may actually find that you TV is envoking a different preset for MADVR vs your windows desktop, some TV's use different presets for playback resolutions and refresh rates, the MADVR playback looks like mine would if I had my TV set to COOL instead of the correct setting of WARM2.
Do you have anything set it MADVR for calibration?, mine is set to off.
One more quick test to do, this will tell us whether its a driver or MADVR issue, play it with MPC-BE latest version using the standard EVR renderer, it converts HDR to SDR and its a very close approximation colour wise, if this looks ok (make sure you are refresh rate switching to 23,976) it must be an issue with your MADVR setup.
Old 30th September 2019, 16:51   #57489  |  Link
janos666
Excuse me for my bad english. I just wanted to say that AMD is still not so good. A problem such as this is still not resolved. I would be grateful if you download that "source" and check with yourself.
My theory is that AMD tries to do the smart thing and dynamically pick the metadata (Rec2020, DCI-P3, Rec709, etc) to be sent to the display (in HDR mode), so that the display's built-in processor becomes responsible for any kind of gamut mapping if necessary (from the color space indicated in the metadata to the native display panel colors) which eliminates all the potential performance overhead and/or quality degradation on the PC's CPU/GPU side (the original default behavior since Windows 10 1703 seems to be a conversion of the SDR Windows GUI and all SDR application window's content to Rec2020 [from Rec709] and constantly feeding the HDR mode display with Rec2020 colors whenever Windows is set to HDR desktop mode --- in the early days this clogged the CPU, then it started punishing the GPU with notable performance and quality loss [think about video games when considering the performance] --- now it might becomes a job of the display's processor which is theoretically the ideal choice in all respects). But it looks like it doesn't always work as expected (the display might gets Rec2020 colors with Rec709 metadata, or vice versa with gamut mapping might or might not happening on the PC's side). But it could also be a random bug. I am not sure if Microsoft and/or AMD really trusts the displays to handle this properly (for example, my LG TV seems to handle these kind of metadata changes without blinking into black screens and such but others might not and need to re-initialize).
janos666 is offline   Reply With Quote
Old 30th September 2019, 17:04   #57490  |  Link
mclingo
if it was an AMD problem wouldnt that show in MADVR and in the windows "film and TV" player,? there only seems to be an issue with MADVR playback.
Old 30th September 2019, 18:23   #57491  |  Link
madVR uses the an amd API while windows movie does not.
Old 30th September 2019, 18:33   #57492  |  Link
DMU
huhn, you seem to be the owner of a RX 5700 XT, can you check it?
Old 30th September 2019, 18:36   #57493  |  Link
nope no HDR display.
Old 30th September 2019, 19:06   #57494  |  Link
oldpainlesskodi
Yep, I know I'm gonna get a whole lot of pain on this one...gone back to madVR09209.zip....to my eyes, in a real life environment, nnedi3 wins hands down over NGU.
Yep, gonna get flamed, I know.
Old 30th September 2019, 19:10   #57495  |  Link
mclingo
My setup:
Samsung UE40NU7100.
Top one is MPC-BE with HDRF to SDR conversion, below are MADVR and Windows 10 film and TV player, all three looked identical, ignore the reddish tint to these, thats just my camera, in person all three looked spot on.
https://1drv.ms/u/s!AgvFafeelEBii5w3...-Mpgw?e=dCeMbk
Old 30th September 2019, 22:14   #57496  |  Link
Asmodian
Which NGU did you compare it to? NGU AA looks very similar to NNEDI3 to me in a "real life environment" (what do you mean by that?).
madVR options explained
Old 30th September 2019, 23:16   #57497  |  Link
DMU
Thank you so much! Does your sig fit this test?
Old 1st October 2019, 00:03   #57498  |  Link
mclingo
yes my sig is accurate, i'm not using MADVR .17 as i had issues with 3D with it which I reported to MADSHI as a bug, i havent tested that version for a while though so I might give it another go at some point, I was just going to wait for v 1.0 though.
Old 1st October 2019, 06:39   #57499  |  Link
oldpainlesskodi
I must admit, never really tried AA. only standard and sharp (on 1080p material), but NEDDI3 just seems more natural, and seems to bring out different details (to be expected).
Will take a closer look at AA though.
Old 1st October 2019, 15:31   #57500  |  Link
Harumi
Harumi's Avatar
50fps issue
I have an issue with one movie (ripped Blu-ray in 1080p), the source material is 50fps.
I have no idea why all other videos are working fine (typical 24fps look great, and no dropped frames), but I struggle with 50fps, the video seems choppy, every sec I am loosing over 15 frames.
I tried to tinker with all settings and display modes, but I must have overseen something.
Can you please help, I have a good machine, so hardware is not an issue, and the video is similarly choppy with Cubic and NHU very sharp?
Harumi is offline   Reply With Quote
