Old 15th April 2011, 15:55   #1  |  Link
africanmarty
Help me w/ my compliant BD disk settings in x264
i am setting out some x264 settings to make BD disk, but since i will be encoding some out of standard BD disk (720x576p25, 1280x720p25 & 1920x1080p25 ).
here are my standard encoding settings for encoding to the computer :
1080p bluray :
--crf 20.0 --preset medium --profile high --level 4.0 --ref 4 --deblock -2:-2 --merange 24 --b-adapt 2 --b-pyramid strict --trellis 2 --no-fast-pskip --aud --nal-hrd vbr --psy-rd 1.0:0.2 --partitions all --subme 9 --me umh --slow-firstpass --rc-lookahead 60 --open-gop bluray --colorprim bt709 --transfer bt709 --colormatrix bt709 --extra:
720p bluray :
--crf 18.0 --preset medium --profile high --level 4.0 --ref 6 --deblock -2:-2 --merange 24 --b-adapt 2 --b-pyramid strict --trellis 2 --no-fast-pskip --aud --nal-hrd vbr --psy-rd 1.0:0.2 --partitions all --subme 9 --me umh --slow-firstpass --rc-lookahead 60 --open-gop bluray --colorprim bt709 --transfer bt709 --colormatrix bt709 --extra:
SD :
--crf 19.5 --preset medium --profile high --level 3.0 --ref 6 --deblock -2:-2 --bframes 5 --b-adapt 2 --b-pyramid strict --trellis 2 --no-fast-pskip --aud --nal-hrd vbr --psy-rd 1.0:0.2 --partitions all --subme 9 --me umh --slow-firstpass --rc-lookahead 60 --extra:
add the following to the above settings for BD compliance :
How to make the following SD resolutions for x264 blu-ray compliant (is this correct?) :
you must add --sar 16:11 (for 16:9) PAL & --sar 40:33 (for 16:9) NTSC
or --sar 12:11 (for 4:3) PAL & --sar 10:11 (for 4:3) NTSC
because that is allowed sar's for 576p/480p video mode.
PAL = 720×576 & 704×576. NTSC = 720×480 & 704×480
If encoding interlaced than that is all, if encoding progressive see blelow :
add "--fake-interlaced --pic-struct" when encoding as 25p progresive (which allows encoding progressively but flags the content as interlaced) so the BD player will read it.
add " --pulldown 32 --fake-interlaced" when encoding as 23.976p progresive (which allows encoding progressively but flags the content as interlaced) so the BD player will read it.
How to make 1080p25 and 1080p29.97 Bluray compliant (is this correct?) :
1080p25 and 1080p29.97 [encoded using fake-interlaced mode. This allows the stream to be encoded progressively yet flagged as interlaced]:
add "--fake-interlaced --pic-struct" when encoding as 25p and 29.97p progresive. So the BD player will read it.
How to make 720p25 and 720p29.97 Bluray compliant (is this correct?) [use frame doubling to comply with the Blu-Ray specification] :
add "--pulldown double" when encoding as 25p and 29.97p progresive. So the BD player will read it.
africanmarty is offline   Reply With Quote
Old 15th April 2011, 16:06   #2  |  Link
sneaker_ger
If you have not already seen it, the following site has examples for all combinations:
http://www.x264bluray.com/
Old 15th April 2011, 16:13   #3  |  Link
detmek
--slow-firstpass with CRF?!
Also, VBV and keyint are missing.
detmek is offline   Reply With Quote
Old 15th April 2011, 16:19   #4  |  Link
poisondeathray
add --sar 1:1 for the 1080p, 720p
you need to specify vbv values
you should start reading the guides
http://sites.google.com/site/x264bluray/home
http://forum.doom9.org/showthread.php?t=154533
Old 15th April 2011, 16:30   #5  |  Link
sneaker_ger
Oh, yes. I mainly looked at the buttom and falsely assumed the top settings were just copied. vbv settings are missing.
Maybe you should really wait for kierank and shon3i to update their guides to account for the recent x264 changes.
/edit: kierank already did.
Old 15th April 2011, 16:36   #6  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Updated :P btw is not kierank it's me
ChapterGen - manipulate with chapters in various i/o formats, with CLI support
Official website or Doom9 thread
shon3i is offline   Reply With Quote
Old 15th April 2011, 16:49   #7  |  Link
sneaker_ger
I'm talking about www.x264bluray.com which I thought is maintained by kierank - or is it also your work?
Old 15th April 2011, 16:57   #8  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
I just do maintenance...
Old 15th April 2011, 17:11   #9  |  Link
sneaker_ger
I see.
Old 16th April 2011, 03:32   #10  |  Link
africanmarty
thankyou very much guys.
bluray, compliance, compliant, encode, x264
