25th April 2018, 09:33 | #5282 | Link |
Yes - when ffmpeg write normal decoder and encoder(for sample files).
25th April 2018, 15:58 | #5284 | Link |
Do not hurry. The specification has not been approved yet.
26th April 2018, 20:50 | #5285 | Link |
Problem with DVD
I got the problem, that the sound crackles and the image is terrible (artifacts, wrong colors...) after I get into the mainmenu of the DVD.
I havent tested something else, but it occured with all game of thrones-DVDs. The problem is "fixed" after closing mpcbe and starting again. After 2-4 times doing that it will work. Its a great player and thats the only thing that could be better at the moment! Maybe you can fix this? |
26th April 2018, 23:14 | #5286 | Link |
Upload problem DVD - i check.
27th April 2018, 15:55 | #5287 | Link |
Acid fr0g
I have a strange behaviour with MPCBE. When I close it, the window doesn't disappear immediately.
The frame remains and so the frame of the windows below. After a time from half a second to 3-4 seconds it disappears. I can accelerate the thing by clicking on desktop or another window. Any idea?
@turment on Telegram |
27th April 2018, 18:46 | #5288 | Link |
tormento
What version of the player do you use? What external filters do you use?
27th April 2018, 21:13 | #5289 | Link |
DVD problem
Here I made a video about the issue (read description) https://youtu.be/lo-as1Kp52c
I hope this helps you and as a result of that it helps me! |
28th April 2018, 00:14 | #5290 | Link | |
28th April 2018, 08:45 | #5292 | Link |
@Felixjots
1.) update to latest nightly and see if it still happens -> https://yadi.sk/d/hlf1lfC8mKU58/!_last 2.) show us external filters list in options, like LAV Filters, ... -> disable/block all external filters -> does it still happen then? 3.) tried to reset settings and set up MPC-BE new? 4.) upload sample somewhere like Google drive |
28th April 2018, 09:33 | #5293 | Link |
Newest Version, without LAV Filters and madVR: https://youtu.be/WRdUwohjEQg (Bad Video Quality, I know)
28th April 2018, 10:14 | #5294 | Link | |
Acid fr0g
Seems a rendering issue, not a filter one. VLC, Media Player NET and others works perfectly.
28th April 2018, 15:16 | #5296 | Link | |
28th April 2018, 18:39 | #5298 | Link |
@Felixjots
MPC-BE does not use hardware acceleration when playing a DVD. You have an external video decoder.
28th April 2018, 21:31 | #5299 | Link |
Well, after resetting the settings it seems to work now. (With external filters also). There is one ressetted setting that made the problem. I try to find out which one it is.
