Old 3rd November 2020, 18:29   #1101  |  Link
clsid
ISR could be made compatible with that as well in future. Or madVR could adjust the colors of the subs itself. Or blend them before it applies LUT.
Old 3rd November 2020, 18:55   #1102  |  Link
what's wrong with the new interface it works with EVR, mpcVR and madVR?
the new interface has support for HDR subs too(at least on a technical level).
Old 11th November 2020, 07:18   #1103  |  Link
gfxnow
gfxnow is offline   Reply With Quote
Old 6th March 2021, 00:31   #1104  |  Link
pinterf
Dear all,
I made a new build, took the rc5 branch which was finally vs2019 friendly. I was so happy upon that that I put some effort into implementing new color spaces in the core. (after having my Avisynth filter work again on this new codebase)
https://github.com/pinterf/xy-VSFilt.../tag/3.2.0.804
Tested only from Avisynth TextSub filter, as my primary goal was this. Supports native YV16, YV24, and 10 and 16 bit 4:2:2 formats (internally P210 and P216). What ever it does outside Avisynth, I don't know.
pinterf is offline   Reply With Quote
Old 6th March 2021, 14:01   #1105  |  Link
Warlock
Dear all,
Warlock is offline   Reply With Quote
Old 3rd April 2021, 20:56   #1106  |  Link
Sunspark
Does the possibility exist that a checkbox could be implemented to disallow transparency?
I.e. if one likes all the other pre-defined subtitle fonts, colors, etc. in the file, just not the transparency which shows on subtitle borders, etc.
The benefit of this would be to visually make everything nice and crisp, and potentially might even improve performance slightly as it wouldn't have to blend anything since at that point it would just be an overlay.
Sunspark is offline   Reply With Quote
Old 13th April 2021, 00:35   #1107  |  Link
kedautinh12
New ver of xy-VSFilter
https://github.com/pinterf/xy-VSFilter
Old 22nd April 2021, 12:05   #1108  |  Link
gfxnow
Originally Posted by kedautinh12 View Post
Is there an official doom9 thread for this new fork of xy by pinterf
Old 23rd May 2021, 16:02   #1109  |  Link
GMJCZP
GMJCZP's Avatar
Hi, I have used the .bat file to install it but I can't use it with Wmp on w7 x86, what should I do?
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 24th May 2021, 15:41   #1110  |  Link
clsid
Best thing to do is use MPC-HC instead of the terrible WMP.
To use (xy-)VSFilter with WMP you need to do two things:
1) Use Codec Tweak Tool to adjust preferred DirectShow decoders in Windows. The required setting for VSFilter is "Use merit". Anything else will not work.
2a) You need to disable Media Foundation to force WMP to use DirectShow. On Windows 7 that is needed for .mp4/.mov. On Windows 10 it is also needed for .mkv.
2b) Instead of disabling MF, you can also rename your files to an uncommon extension (such as .video). This will bypass the MF codecs. This method is actually preferred, because disabling MF can cause problems with apps/games that need it.
Long story short: don't use WMP.
MPC-HC 2.2.1
Old 24th May 2021, 22:15   #1111  |  Link
GMJCZP
GMJCZP's Avatar
Thanks for the bad news
It's curious that in the past i used directvobsub in w xp and Now in W7 with a new program I can't easily
By law and justice!
GMJCZP's Arsenal
Old 3rd June 2021, 14:20   #1112  |  Link
GMJCZP
GMJCZP's Avatar
I was testing VSFilter 3.2.0.806 as a plugin for Avs+ and I noticed that an "é" (third line of subtitles) is showing it to me as an Asian character, if I use version 3.0.0.306 it does show up correctly, here I leave the file of Subtitle :
Here
And this is the script:
textsub("PruebaSSA.ssa")
By law and justice!
GMJCZP's Arsenal
Old 16th July 2021, 14:54   #1113  |  Link
v0lt
Is it possible to modify the XySubFilter code (c++17) to avoid using boost?
I found the following dependencies:
boost::scoped_ptr
boost::shared_ptr
boost::flyweights
boost::shared_array
boost::dynamic_pointer_cast
Old 16th July 2021, 15:42   #1114  |  Link
菜姬
boost::scoped_ptr
boost::shared_ptr
boost::flyweights
boost::shared_array
As far as I know, there is no substitute for flyweight in C++ 's standard library.
菜姬 is offline   Reply With Quote
Old 17th July 2021, 11:36   #1115  |  Link
nokicheru
Hi! Recently, i've found some mkv files with .ass subtitles that clearly don't work as intended with xySubFilter in MPC-BE and madvr (i've also tried playing them using EVR, no changes). When playing them, I experience huge framedrops, and I can see on the OSD of madVR, that the subtitle queue and all other rendering queues momentarily go to 0 when some new lines come on screen. This mostly happens with scripts with many effects and when a new line comes on to the screen and the problem is isolated to very few files. I have tried playing those files with mpv (which uses libass, i believe) and they worked just fine, no framedrops. I have also tried reinstalling xySubfilter, resetting its' settings and installing the new build recently posted here (https://github.com/pinterf/xy-VSFilter), sadly with no success. Does anyone have any suggestions?
nokicheru is offline   Reply With Quote
Old 17th July 2021, 11:50   #1116  |  Link
you can try the option "more" -> "render to original video size" if you are on UHD or QHD.
in general vsfilter has started to fall behind in terms of high res rendering performance.
Old 17th July 2021, 15:46   #1117  |  Link
nokicheru
I actually tried that too, but it weirdly seemed to make almost no difference.
It really seems as if the problem isn't the rendering of the subtitles, but the parsing of some specific effects. I might try to tinker with the subtitle files and try to find if there's any specific effects that mess with xySubfilter.
If anyone wants to try it themselves, I've attached a sample subtitle file that causes the problems that I've described (They start at around second 43). Maybe some of you guys can replicate the problem and figure something out. Would appreciate the help!
Old 17th July 2021, 17:57   #1118  |  Link
clsid
Please use an external file host. It can take a long time before attachments are approved.
Slow rendering can also be due to a font that is used. A couple months ago I discovered that issue for a font called "Splatter". As a fix in MPC-HC internal subtitle renderer, I now use Arial as a replacement when that specific font is used in a style.
The splatter font is the only one so far that is known to me to cause this issue.
MPC-HC 2.2.1
Old 17th July 2021, 18:08   #1119  |  Link
nokicheru
Thanks for the tip! Here are the files: https://files.catbox.moe/qy6ijn.zip
Old 20th July 2021, 21:20   #1120  |  Link
ikarad
I have found a bug with subtitles.
At the left, sub renderer by vlc.
At the right, same problem with mpc-hc sub renderer and xysubfilter
ikarad is offline   Reply With Quote
