1st March 2015, 18:41 | #13003 | Link | |
But MeGUI doesn't support 29.970 audio ! That's why I'm looking for eac3to |
1st March 2015, 19:10 | #13004 | Link |
Of course. Converting a video from PAL (25.0 fps) to NTSC-Film (23.976 fps) does change the playing time if you use the slowdown method.
But converting a video from NTSC (29.97 fps) to NTSC-Film (23.976 fps) does not change the playing time if the video was telecined and can be reverted to progressive using IVTC. Therefore, MeGUI does not need to offer any audio conversion. The audio does not need any conversion, because the playing time won't change. But only if you can invert a telecine. |
1st March 2015, 20:05 | #13005 | Link | |
And then convert it to 23.976 ? |
7th March 2015, 22:30 | #13008 | Link |
I have a Blu-ray that causes eac3to to show only one playlist (the wrong playlist), even though playing index.bdmv plays a different one (the correct one). I've zipped the contents of the PLAYLIST folder and included a few files for debugging.. if madshi still secretly develops this.
8th March 2015, 10:37 | #13009 | Link |
With TSmuxer, check "downconvert True HD ..." in track options and choose demux as output format. Don't worry, that's an extraction, not a conversion (encoding).
10th March 2015, 22:10 | #13010 | Link | |
Anyway, are you sure that the real playlist and the one selected by eac3to are really different? Often there are multiple duplicates, and eac3to simply selects one "by random". |
10th March 2015, 22:13 | #13011 | Link |
eac3to v3.28 released
http://madshi.net/eac3to.zip Code:
* fixed: #001: different number of frames for left and right eye * fixed: #061: valid silence edit was sometimes rejected * fixed: #067: error messages were not available to GUIs * fixed: #086: left/right eye information was inverted in some 3D Blu-Rays * fixed: #131: TrueHD Atmos streams could not be demuxed or decoded * fixed: #243: ArcSoft DTS decoder crash made eac3to crash, too * downStereo: added 0.7071 factor for surround/back channels (ITU-R BS.775-3) * downStereo/Dpl: using 0.5 instead of 0.7071 factor for LFE (ITU-R BS.775-3) Last edited by madshi; 10th March 2015 at 23:10. |
11th March 2015, 09:40 | #13014 | Link |
Pig on the wing
There is something to extract, for example the latest version of mkvmerge can get the embedded AC3 track for you.
11th March 2015, 11:30 | #13016 | Link |
PgcEdit daemon
The bug #86 with the inversion of the left and right eye views when displaying the content of a 3D playlist with the MVC_Base_view_R_flag true is partially fixed.
When eac3to is launched with the BD path as the argument, or with the playlist, it works fine: Code:
C:\>eac3to.exe Y:\BDMV\PLAYLIST\00852.mpls 1) 00852.mpls, 00001.m2ts, 1:34:02 - Chapters, 20 chapters - h264/AVC (right eye), 1080p24 /1.001 (16:9) - h264/MVC (left eye), 1080p24 /1.001 (16:9) - DTS Master Audio, English, multi-channel, 48kHz - DTS, French, multi-channel, 48kHz - AC3, Spanish, multi-channel, 48kHz - AC3, Portuguese, multi-channel, 48kHz - AC3, Danish, multi-channel, 48kHz - AC3, Finnish, multi-channel, 48kHz - AC3, Norwegian, multi-channel, 48kHz - DTS, Russian, multi-channel, 48kHz - AC3, Swedish, multi-channel, 48kHz - AC3, Chinese, multi-channel, 48kHz - DTS, Japanese, multi-channel, 48kHz Code:
C:\>eac3to.exe Y:\BDMV\PLAYLIST\00852.mpls 1) M2TS, 2 video tracks, 11 audio tracks, 12 subtitle tracks, 1:34:02, 24p /1.001 1: Chapters, 20 chapters 2: h264/AVC (left eye), 1080p24 /1.001 (16:9) 3: h264/MVC (right eye), 1080p24 /1.001 (16:9) 4: DTS Master Audio, English, 7.1 (strange setup) channels, 16 bits, 48kHz, -9ms (core: DTS-ES, 5.1 channels, 1509kbps, 48kHz) 5: DTS, French, 5.1 channels, 768kbps, 48kHz, -9ms 6: AC3, Spanish, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB, -9ms 7: AC3, Portuguese, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB, -9ms 8: AC3, Danish, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB, -9ms 9: AC3, Finnish, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB, -9ms 10: AC3, Norwegian, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB, -9ms 11: DTS, Russian, 5.1 channels, 768kbps, 48kHz, -9ms 12: AC3, Swedish, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB, -9ms 13: AC3, Chinese, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB, -9ms 14: DTS, Japanese, 5.1 channels, 768kbps, 48kHz, -9ms 15: Subtitle (PGS), English 16: Subtitle (PGS), French 17: Subtitle (PGS), Spanish 18: Subtitle (PGS), Portuguese 19: Subtitle (PGS), Danish 20: Subtitle (PGS), Finnish 21: Subtitle (PGS), Norwegian 22: Subtitle (PGS), Russian 23: Subtitle (PGS), Swedish 24: Subtitle (PGS), Chinese 25: Subtitle (PGS), Japanese 26: Subtitle (PGS), Japanese
11th March 2015, 11:50 | #13018 | Link | |||
Thanks madshi!
@all users Please read ITU-R BS.775-3 to understand for what add LFE is not recommended for downmix. Use -mixlfe at your risk.
11th March 2015, 11:59 | #13019 | Link | |
47.952fps@71.928Hz
Excellent update!
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
11th March 2015, 12:05 | #13020 | Link | |
Pleasure! It was about time...
Thanks, appreciated! Quote:
Originally I mixed left, right and surround channels with 1.0, and the LFE with 0.7071. The reason for using 0.7071 for LFE was because it was originally only one channel/speaker, but I've mixed it into both the final left *and* right channels. So I had to half the volume of the LFE to not increase its final playback volume. Now ITU 775-3 suggests to use 1.0 for left/right channel, but 0.7071 for the surround channels. The ITU idea is that the left/right channels should have higher priority than the surround channels. If we accept this idea, it should also be applied to the subwoofer. Why would we lower the surround channel volume for the mix, but not the LFE volume? Because of that I've used the original matrix, but added an 0.7071 factor on all channels (including LFE) except left/right. This is how I ended up with 0.7071 for the surround channels and 0.5 for the LFE. ITU 775-3 does suggest not to mix the LFE at all, and IIRC that's eac3to's default behaviour, anyway. But *if* the user wants to mix the LFE, the volume should make sense, and since I just lowered the surround volume, I thought it would make sense to lower the LFE volume (when -mixlfe is used), accordingly. Last edited by madshi; 11th March 2015 at 12:10. |
eac3to |
