Old 27th June 2016, 21:22   #14001  |  Link
tebasuna51
tebasuna51's Avatar
The eac3to normalize make impossible any clip, even if the decoder output have float values over 0dB the normalize function correct these values.
tebasuna51 is offline
Old 29th June 2016, 04:09   #14002  |  Link
canuckerfan
Does anyone know the command to extract a TrueHD stream from an Atmos stream? Excuse me if it's already been mentioned in this thread, I tried searching but couldn't find it and I don't want to sift through so many pages.
canuckerfan is offline
Old 29th June 2016, 14:57   #14003  |  Link
Nico8583
A little question : is eac3to a good choice to just demux a BD (2D or 3D) ? Thank you.
Nico8583 is offline
Old 29th June 2016, 15:18   #14004  |  Link
To mainly obtain the audio streams: Yes. But it won't care much about all other streams, I believe...
LigH is offline
Old 29th June 2016, 15:25   #14005  |  Link
tebasuna51
tebasuna51's Avatar
Atmos or not you can extract the standard TrueHD (without Atmos info) with:
eac3to stream.thd+ac3 stream.thd
if the stream is already extracted, or from the BD, if TrueHD is track 3:
eac3to movie.mpls 3: stream.thd
Old 29th June 2016, 15:26   #14006  |  Link
tebasuna51
tebasuna51's Avatar
Yes for 2D BD, I'm never try a 3D if you want recover 3D info (3D planes for 3D sups, etc.)
Old 29th June 2016, 15:27   #14007  |  Link
Groucho2004
I use eac3to for de-multiplexing audio and video streams from BDs on a regular basis. I'm surely not alone.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 29th June 2016, 15:32   #14008  |  Link
^ OK, practical experience.
LigH is offline
Old 29th June 2016, 16:17   #14009  |  Link
Ripman
I test, with eac3to, wav files with extra chunks after the data chunk without problems. For instance cue points created with GoldWave editor.
But, maybe, the eac3to behaviour can change with wav files greater than 2 GB, like here. Is know than there are soft than don't support this limit.
I can't understand how eac3to show a duration of 0:06:29 when seems (by size, channels, bitdepth and samplerate) the correct duration is 00:22:09.205 like show MediaInfo.
Thanks for your observations. Regarding the differing durations, please note the info I posted was for two different tracks in the same set (album).
I'll clean up that info for consistency, and post the wav when I get back tomorrow night. The sample is actually about 1.6gb, but I also put a 176 eac3to down sample log that shows the command line, and a pic of the static I get.
Perhaps in this case, the issue is related both to the embedded artwork and expanding to 32bit to apply gain.
Ripman is offline
Old 29th June 2016, 16:25   #14010  |  Link
Ripman
Originally Posted by Ripman View Post
Thanks. I tried SoX 14.4.2 and it works just fine. Here is the sox command line I used to replicate the one I used with eac3to.
sox -V4 352.wav --rate 176400 176.wav gain -3.5 2>sox_log.txt
Just to reiterate that sox approach worked without issue.
And I'll post some additional info as described in my previous post related to a 352-176 down sample issue I had with eac3to. The hotel wifi never lets me upload something that big.
Ripman is offline
Old 29th June 2016, 17:40   #14011  |  Link
Nico8583
Thank you ! BD 3D info is not a problem, I can extract it from MPLS file. I will try if MVC file extracted keeps 3D planes info.
Nico8583 is offline
Old 30th June 2016, 07:07   #14012  |  Link
canuckerfan
I'm trying something like this but I'm still getting an outputted Atmos track:
eac3to.exe "source.mkv" 2:aud2.thd
Old 30th June 2016, 08:35   #14013  |  Link
kypec
User of free A/V tools
kypec's Avatar
Please post your full output eac3to log.
kypec is offline
Old 30th June 2016, 10:47   #14014  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
No for the subtitles of most 3D BDs. If the same subtitles are present in the AVC M2TS and in the MVC M2TS (and it's frequent), eac3to fails completely, and you have to unselect the subtitle streams and retry. AFAIK, for everything else, eac3to works fine as a demuxer.
r0lZ
r0lZ is offline
Old 30th June 2016, 21:17   #14015  |  Link
canuckerfan
Hope this is the one.
eac3to v3.31
command line: eac3to.exe "source.mkv" 2:aud2.thd
MKV, 1 video track, 1 audio track, 1 subtitle track, 0:03:40, 24p
1: h264/AVC, Hindi, 1920x804 24p (160:67)
"Mohe Rang Do Laal"
2: TrueHD (Atmos), Hindi, 7.1 channels, 48kHz
"7.1 TrueHD Audio"
3: Subtitle (SRT), English, "English Subtitles"
[v01] The video framerate is correct, but rather unusual. <WARNING>
[a02] Extracting audio track number 2...
[a02] Creating file "aud2.thd"...
Video track 1 contains 5288 frames.
eac3to processing took 2 seconds.
Done.
Last edited by tebasuna51; 1st July 2016 at 10:52. Reason: Replace attachement by text
Old 1st July 2016, 10:57   #14016  |  Link
tebasuna51
tebasuna51's Avatar
@canuckerfan
What is the problem?
The <WARNING> is related to 24 fps, but the "aud2.thd" seems extracted fine.
Old 7th July 2016, 08:11   #14017  |  Link
junior_l3oss
@canuckerfan
hi...i have netflix dolby digital plus audio.
dd+ audio not detected
eac3to v3.31
command line: "C:\eac3to\eac3to.exe"  s1e01.ac3 \s1e01.ac3~n.wavs
The format of the source file could not be detected.  <ERROR>
Audio #0 : E-AC-3 at 192 Kbps
Infos : 6 kanal, 48.0 KHz
how can i decode wavs and etc.
junior_l3oss is offline
Old 7th July 2016, 09:02   #14018  |  Link
tebasuna51
tebasuna51's Avatar
@junior_l3oss
When your command line don't work can be:
1) eac3to don't support this kind of eac3
2) Or the eac3 stream is buggy because:
2-1) A bad capture of video from Netflix
2-2) Or a bad stream extraction from video
We can't know the problem without a sample of your video.
Old 8th July 2016, 18:53   #14019  |  Link
TheLastOfUs
Seems the creator of this program 'madshi' "doesn't have the resources" for this insanely difficult problem I face....which is ridiculous.
90 google results pretty much end up in this question never getting answered. 3 times it has been asked here and never answered..but here goes yet again.
I have Nero 7 installed and I have the HD/BluRay plugin installed and registered yet EAC3TO still seems to crap on me. It keeps saying cannot find Nero Audio Decoder 2..which is BS.
eac3to.exe -test
eac3to (v3.31) is up to date
Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed
http://www.nero.com/eng/store-blu-ray.html
CAUTION: You need Nero 7. Nero 8 won't work with eac3to. (errr wrong Nero 7.8.5.0 ..its installed and registered ALONG with the BLURAY plugin!!)
ArcSoft DTS Decoder doesn't seem to be installed
http://www.arcsoft.com/products/totalmediatheatre
Sonic Audio Decoder (3.31.0.0) doesn't seem to be installed
Haali Matroska Muxer (2013-04-14) is installed
Nero AAC Encoder (1.5.4.0) is installed
Surcode DTS Encoder (1.0.29.0) is installed
TL;DR
I think program is dead when trying to do AAC to AAC/M4A
TheLastOfUs is offline
Old 8th July 2016, 21:18   #14020  |  Link
tebasuna51
tebasuna51's Avatar
I have Nero 7.11.10.0, and Blu-Ray/HD DVD Video Plug-in, and work in W 7 without problems:
Nero Audio Decoder (Nero 7) works fine
ArcSoft DTS Decoder (1.1.0.0) works fine
Surcode DTS Encoder doesn't seem to be installed
eac3to
