Old 4th January 2017, 22:22   #2781  |  Link
Could you please avoid quoting entire posts when there's no reason to? Also your post is directly after pinterf's post which makes it even worse.
Thanks for the new build pinterf!
ryrynz is offline
Old 4th January 2017, 23:28   #2782  |  Link
Wilbert
new script function:
bool IsPackedRGB(clip)
returns true when clip is RGB24/32/48/64
This function is redundant. Please use IsInterleaved(clip) and IsRGB(clip) instead. (There is no IsPackedYUV(clip) either.)
and similarly IsPlanar(clip) and IsRGB(clip) / IsYUV(clip).
With respect to this post: http://forum.doom9.org/showthread.ph...46#post1791946
I think it would be great if (at least) the formats RGB64, YUV422P10 and YUV422P16 would be exposed through the VfW interface. Then we can open such scripts in Virtualdub and encode straight to MagicYUV (without any color conversion).
Wilbert is offline
Old 6th January 2017, 12:47   #2783  |  Link
pinterf
I think you are right, IsYUV does not follow this logic, as it applies to YUY2, too.
BGR[48] and BRA[64] is already available, ignus2 has done it
https://github.com/pinterf/AviSynthP...c6ee125243c82c
pinterf is offline
Old 6th January 2017, 14:10   #2784  |  Link
shekh
But is this patch for source (not for output)?
VirtualDub2
shekh is offline
Old 6th January 2017, 14:23   #2785  |  Link
gaak
Error msg with x86 builds
Hello all,
When trying to encode a clip I get the following error:
avs [info]: AviSynth+ 0.1 (r2359, MT, i386)
avs [info]: Video colorspace: YV12
avs [info]: Video resolution: 988x720
avs [info]: Video framerate: 24000/1001
avs [info]: Video framecount: 121878
avs4x26x [info]: "C:\MKVideo Encoder\EXEs\x264_x64.exe" - --preset medium --tune
film --crf 18 --profile high --level 4.1 --open-gop --quiet --threads 0 --threa
d-input -o Output_Video_File.h264 --frames 121878 --fps 24000/1001 --input-res
988x720 --input-csp i420
avs [error]: Filter Error: Filter attempted to break alignment of VideoFrame. occurred while reading frame 0
I've tried earlier builds, only r1858 works for me.
The script follows:
SetFilterMTMode("DEFAULT_MT_MODE", 2)
SetFilterMTMode("DGDecodeNV", 3)
LoadPlugin("C:\MKVideo Encoder\FFMS2\ffms2.dll")
Import("C:\MKVideo Encoder\AVS Scripts\LoadPlugins.avs")
FFVideoSource(source = "C:\MKVideo Files\Input_Video_File.mkv")
Spline144Resize(1280, 720)
RoboCrop(Laced=False)
LSFmod(defaults="slow", preblur="DeGrainMedian(limitY=4, limitUV=6, mode=1, interlaced=false)")
Prefetch(3)
Thanks for any help.
gaak is offline
Old 6th January 2017, 14:36   #2786  |  Link
pinterf
Yes. Avisource and DirectShowSource.
pinterf is offline
Old 6th January 2017, 14:36   #2787  |  Link
BakaProxy
Originally Posted by gaak View Post
Hello all,
The script follows:
Prefetch(3)
First off try without MT before you start complaining online.
Verstuurd vanaf mijn SM-A500FU met Tapatalk
BakaProxy is offline
Old 6th January 2017, 14:57   #2788  |  Link
pinterf
The script follows:
Prefetch(3)
One of the filters used SubFrame or SubframePlanar and specified plane offsets and/or pitches that are incompatible with recent versions of Avisynth+. This prevention was introduced because Avisynth+ core and filters in general assume proper alignment for processing the frame. Avisynth plus' default alignment is 32 bytes. One of the filter is using the subframe function with frame properties that are aligned for less than 32 bytes.
I suspect the RoboCrop function in the script, try to use it with align=true
Internally Avisynth+'s Crop is alignment-safe. It checks whether alignment is o.k. for the fast SubFrame. If not, it creates a new frame instead (guaranteed to have proper alignment) and copies the cropped area there.
pinterf is offline
Old 6th January 2017, 16:08   #2789  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Hey folks, I haven't been around for a while (been busy with other things), and I'm glad the development has progressed.
Converting my auto-generated scripts to native 16-bit is something I'd like to do (and adapting AviSynthShader to support conversion to/from native 16-bit), but where I have hesitation is in compromising quality in doing so. Is there now a way of performing these 2 operations without DitherTools?
- Dithering with Floyd-Steinberg
- Resizing with NoRinging (Dither_resize16nr)
Actually, as I'm writing this, I'm remembering that NoRinging resize is simply a script-based wrapper around the standard resizer so it probably can be used just the same (would have to try to confirm). Still that leaves dithering which requires custom coding.
Have I missed any other major update that either impact quality of performance since I last interacted here, or was it mostly new features?
MysteryX is offline
Old 6th January 2017, 16:55   #2790  |  Link
Motenai Yoda
Motenai Yoda's Avatar
dithering is possible with convertto8bits or convertbits, but IIRC there is only dither or not dither (truncate, round?)
as you can see from the wrapper function nr resize it's just a repair between the chosen one and gauss
Function Dither_resize16nr (clip src, int width, int height,
\	float  "src_left",
\	float  "src_top",
\	float  "src_width",
\	float  "src_height",
\	string "kernel",
\	float  "fh",
\	float  "fv",
\	int    "taps",
\	float  "a1",
\	float  "a2",
\	float  "a3",
\	int    "kovrspl",
\	bool   "cnorm",
\	bool   "center",
\	string "cplace",
\	int    "y",
\	int    "u",
\	int    "v",
\	string "kernelh",
\	string "kernelv",
\	float  "totalh",
\	float  "totalv",
\	bool   "invks",
\	bool   "invksh",
\	bool   "invksv",
\	int    "invkstaps",
\	string "cplaces",
\	string "cplaced",
\	string "csp",
\	bool   "noring")
	noring = Default (noring, true)
	Assert (width > 0 && height > 0, "Dither_resize16nr: width and height must be > 0.")
	sr_h  = Float (width ) / Float (src.width () )
	sr_v  = Float (height) / Float (src.height ())
	sr_up =       Dither_max (sr_h, sr_v)
	sr_dw = 1.0 / Dither_min (sr_h, sr_v)
	sr    = Dither_max (sr_up, sr_dw)
	Assert (sr >= 1.0)
	# Depending on the scale ratio, we may blend or totally disable
	# the ringing cancellation
	thr = 2.5
	nrb = (sr > thr)
	nrf = (sr < thr + 1.0 && noring)
	nrr = (nrb) ? Dither_min (sr - thr, 1.0) : 1.0
	nrv = (nrb) ? Round ((1.0 - nrr) * 255) * $010101 : 0
	main = src.Dither_resize16 (width, height,
\		src_left  =src_left,
\		src_top   =src_top,
\		src_width =src_width,
\		src_height=src_height,
\		kernel    =kernel,
\		fh        =fh,
\		fv        =fv,
\		taps      =taps,
\		a1        =a1,
\		a2        =a2,
\		a3        =a3,
\		kovrspl   =kovrspl,
\		cnorm     =cnorm,
\		center    =center,
\		cplace    =cplace,
\		y         =y,
\		u         =u,
\		v         =v,
\		kernelh   =kernelh,
\		kernelv   =kernelv,
\		totalh    =totalh,
\		totalv    =totalv,
\		invks     =invks,
\		invksh    =invksh,
\		invksv    =invksv,
\		invkstaps =invkstaps,
\		cplaces   =cplaces,
\		cplaced   =cplaced,
\		csp       =csp
	nrng = (nrf) ? src.Dither_resize16 (width, height,
\		src_top   =src_top,
\		kernel    ="gauss",
\		a1        =100,
\		center    =center,
\		cplace    =cplace,
\		cplaces   =cplaces,
\		cplaced   =cplaced,
\		csp       =csp,
\		y         =y,
\		u         =u,
\		v         =v
\	) : main
	nrm = (nrb && nrf) ? main.BlankClip (color_yuv=nrv, height=main.Height()/2) : main
	# To do: use a simple frame blending instead of Dither_merge16
	rgm = 1
	rgc = (nrb) ? -1 : 0
	rgy = Defined (y) ? ((y == 3) ? rgm : rgc) : rgm
	rgu = Defined (u) ? ((u == 3) ? rgm : rgc) : rgm
	rgv = Defined (v) ? ((v == 3) ? rgm : rgc) : rgm
	rguv = Dither_max (rgu, rgv)
	(nrf       ) ? main.Dither_repair16 (nrng, rgy, rguv)            : main
	(nrf && nrb) ? Dither_merge16_8 (main, last, nrm, y=y, u=u, v=v) : last
}Function Dither_resize16nr (clip src, int width, int height,
\	float  "src_left",
\	float  "src_top",
\	string "kernel",
\	float  "fh",
\	float  "fv",
\	int    "taps",
\	float  "a1",
\	float  "a2",
\	float  "a3",
\	int    "kovrspl",
\	bool   "cnorm",
\	bool   "center",
\	string "cplace",
\	int    "y",
\	int    "u",
\	int    "v",
\	string "kernelh",
\	string "kernelv",
\	float  "totalh",
\	float  "totalv",
\	bool   "invks",
\	bool   "invksh",
\	bool   "invksv",
\	int    "invkstaps",
\	string "cplaces",
\	string "cplaced",
\	string "csp",
\	bool   "noring")
	Assert (sr >= 1.0)
	thr = 2.5
	nrb = (sr > thr)
\		src_top   =src_top,
\		kernel    =kernel,
\		fh        =fh,
\		fv        =fv,
\		taps      =taps,
\		a1        =a1,
\		a2        =a2,
\		a3        =a3,
\		kovrspl   =kovrspl,
\		cnorm     =cnorm,
\		center    =center,
\		cplace    =cplace,
\		y         =y,
\		u         =u,
\		v         =v,
\		kernelh   =kernelh,
\		kernelv   =kernelv,
\		totalh    =totalh,
\		totalv    =totalv,
\		invks     =invks,
\		invksh    =invksh,
\		invksv    =invksv,
\		cplaces   =cplaces,
\		cplaced   =cplaced,
\		csp       =csp
\		src_top   =src_top,
\		kernel    ="gauss",
\		a1        =100,
\		center    =center,
\		cplace    =cplace,
\		cplaces   =cplaces,
\		cplaced   =cplaced,
\		csp       =csp,
\		y         =y,
\		u         =u,
\		v         =v
\	) : main
	rgm = 1
as rgtools and merge(luma/chroma) now works in 16bit it can be adapted
powered by Google Translator
Motenai Yoda is offline
Old 6th January 2017, 17:16   #2791  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
If someone wants to do that adaptation, it would then work for both 8-bit and 16-bit with the same code.
MysteryX is offline
Old 6th January 2017, 18:00   #2792  |  Link
real.finder
Originally Posted by Foja View Post
Hello,
since long time I am a silent reader in this discussion. I am using the plug-in RemoveDirt in the 8-bit version of avisynth for many years. I am very satisfied with this plug-in.
Now I am starting to use avisynth+ for my cleaning script, all plugins which i normaly use in the 8-bit version are already available exept "RemoveDirt".
RemoveDirt is for me a important plugin which I don't want to miss in my cleaning script for avisynth+.
Is there the plan to convert the plugin "RemoveDirt" to the new version avisynth+?
yes its important for many
and if someone add it to rgtools I wish that he/she add the others mode of RemoveGrain too (more than 24) as there are some scripts use them, and there are RemoveGrainHD and RemoveGrainT too
See My Avisynth Stuff
real.finder is offline
Old 6th January 2017, 18:11   #2793  |  Link
gaak
@pinterf Thank you very much for the answer, that worked!
gaak is offline
Old 6th January 2017, 21:27   #2794  |  Link
ajp_anton
ajp_anton's Avatar
I'd also like to be able to do linear-light resizing in 16-bit. Dither tools has "Dither_y_gamma_to_linear" and "Dither_y_linear_to_gamma". But for these to work you need to convert to and from stacked as well. And also use "dither_resize16" unless you really want to go to and from stacked a lot of times.
Is there another way to convert between linear and gamma light? mt_lut could do it if it worked in 16 bits.
ajp_anton is offline
Old 7th January 2017, 00:30   #2795  |  Link
Wilbert
Was asking about the output. Apperantly the code is in main.cpp (*), but i don't know that part well enough to tell what and how it should be updated.
(*) see CAVIStreamSynth::Info, CAVIFileSynth::ImageSize, CAVIStreamSynth::ReadFrame and CAVIStreamSynth::ReadFormat.
Wilbert is offline
Old 8th January 2017, 14:59   #2796  |  Link
StainlessS
StainlessS's Avatar
One of the filters used SubFrame or SubframePlanar and specified plane offsets and/or pitches that are incompatible with Avisynth.
Pinterf, you really should use the term Avisynth+ or similar when talking about such, RoboCrop is totally compatible with Avisynth, it's Avs+ where
the problem arises.
Also might be related:- I wrote a plugin a few weeks/months ago with optional clip which produced some kind of access Violation when NULL clip,
(with avs+ I think), I suspect that the code that causes/detects above SubFrame error in avs+ was accessing the NULL clip at some point and causing the
access violation, (I'm not sure about that being the cause, but if internal avs+ is gonna mess with clips it should make sure not to mess with optional
NULL ones, I think that problem only appeared in avs+ and not avs standard, but am not completely sure).
Also, can you tell me how to reliably detect Avs+ in most recent versions (at least), without basing it on Version or VersionString, I'll have a go at doing modified RoboCrop behaviour only for avs+ and the default avs+ cropping alignment of 32.
Thanx very much
I sometimes post sober.
StainlessS is offline
Old 8th January 2017, 16:29   #2797  |  Link
Groucho2004
See here. As for newer builds, just test for newly introduced functions.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 8th January 2017, 17:00   #2798  |  Link
StainlessS
StainlessS's Avatar
Thanx G2K4, think i'll use "AddAutoloadDir()".
Any body aware of bulletproof way to call GScript() code in both avs+ and avs standard ?
(GScript does not appear in list of builtin functions in avs+, nor does eg GImport, GEval, for, if, else, etc.)
EDIT: I guess that easiest way is to still use GScript plugin even in avs+.
GScript() really should have been incorporated into avs many moons ago, then we would not have current nonsense.
EDIT: Maybe have to force Eval/GEval into use with some kind of string replace to select plus or standard.
Old 9th January 2017, 09:55   #2799  |  Link
dipje
Isn't it possible and an idea to port fmtconv from vapoursynth to avs+? Would give you all the resizers, kernels, chroma conversion, matrix conversion, gamma space conversion and dithering tools you would I guess.
dipje is offline
Old 9th January 2017, 11:43   #2800  |  Link
real.finder
or just update dither tools to read all avs+ features
