3rd February 2007, 03:41 | #82 | Link |
retired developer
try another output folder. Are you running on vista again?
Detritus Software |
3rd February 2007, 14:00 | #83 | Link |
Nope, regular XP Prof.
"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 29.970 -new "F:\Downloads\Temp\[#YuGiOh!]Yu-Gi-Oh!_-_001_-_The_Bloodcurdling_Blue-Eyes_White_Dragon(3696EC70).mp4 " -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4" Cannot open destination file F:\Downloads\Temp\[#YuGiOh!]Yu-Gi-Oh!_-_001_-_The_Bloodcurdling_Blue-Eyes_White_Dragon(3696EC70).mp4: I/O Error "C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "F:\Downloads\Temp\SonicX 01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4" Cannot open destination file F:\Downloads\Temp\SonicX 01.mp4: I/O Error Last edited by Eretria-chan; 4th February 2007 at 21:29. |
4th February 2007, 06:40 | #84 | Link |
retired developer
something's wrong.
try other folder or shorther filenames.
Detritus Software |
4th February 2007, 21:29 | #85 | Link |
It doesn't matter where I put it. The same thing happens.
"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "F:\SonicX 01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4" Cannot open destination file F:\SonicX 01.mp4: I/O Error |
4th February 2007, 22:37 | #86 | Link |
retired developer
how about not using F:?
Detritus Software |
5th February 2007, 14:44 | #87 | Link |
Mr. Sandman
try also removing the space in the output filename
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! |
5th February 2007, 15:59 | #88 | Link |
retired developer
writing to C: works, but it seems that using F: doesn't work so well.
Detritus Software |
5th February 2007, 16:41 | #89 | Link |
Mr. Sandman
uhm, write permissions?
5th February 2007, 19:28 | #90 | Link |
Does not work:
C:\Documents and Settings\Shizuka>"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "C:\test\SonicX 01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4" Cannot open destination file C:\test\SonicX 01.mp4: I/O Error C:\Documents and Settings\Shizuka>"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "C:\test\SonicX01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4" Cannot open destination file C:\test\SonicX01.mp4: I/O Error Does work: C:\Documents and Settings\Shizuka>"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "C:\SonicX01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4" C:\Documents and Settings\Shizuka>"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "C:\SonicX 01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4" Now that's just stupid. I don't want to output to C:\. C:\ is write protected anyway. File permissions are correct (using NTFS). |
5th February 2007, 19:31 | #91 | Link |
retired developer
Seems to be a file permission problem. Nothing we can fix on our side
Detritus Software |
5th February 2007, 21:37 | #93 | Link |
retired developer
Bencos only launch mp4box, and mp4box fails on your system. File a bug report to gpac team, since it has issues only for you on your machine. Nothing we can do.
Detritus Software |
5th February 2007, 21:45 | #94 | Link |
Mr. Sandman
as sirber said the error comes from mp4box, so it has nothing to do with bencos code.
theres no way we cant fix it.
5th February 2007, 21:54 | #95 | Link |
Mp4box, huh?
OK, so I have no idea where to report that error, but maybe you do? Oh and, I think I need to know what version you're using also? It might help. Maybe. Last edited by Eretria-chan; 5th February 2007 at 22:01. |
5th February 2007, 21:57 | #96 | Link |
retired developer
Detritus Software |
6th February 2007, 01:33 | #97 | Link |
retired developer
Detritus Software |
6th February 2007, 22:22 | #98 | Link |
retired developer
new version again. Celtic Druid made some discoveries on drop duplicate frames.
So, I posted a new build reflecting this new approach. Please test and feedback!
Detritus Software |
7th February 2007, 14:54 | #99 | Link |
Mr. Sandman
Just a warning. The Debug profile is very fast but has a VERY LOW quality.
Dont use it unless for debugging...
7th February 2007, 14:57 | #100 | Link | |
retired developer
On my todo list: * Add MPEG4 ASP * Add AAC HE * Add AAC LC * Add MP3 * Add AVI, if MP3 is selected
Detritus Software |
aac, bencos, gui, webm, x264 |
