#21 | Link |
Is it only me or Youtube converts all HD resolution videos to 30 fps? This was not the case couple months ago. It accepted at least 25 fps and 23.976 fps without forced conversion.
Interlaced, 50 Hz and 60 Hz, 24 fps film. These are evil artifacts from the past which still possess modern video technology. |
#22 | Link |
While they're adding things that most people can't play back, I'd really like to see 50fps and 60fps capability. Not for 1080p - just for normal+HQ modes (and maybe 720p HD mode).
For home movies, YouTube HQ would be a good source for a DVD (or DVD-like quality) - but only if 50fps was available. Otherwise everything gets the fake-flimic stutter look of 25p. Cheers, David. |
#23 | Link |
Some people have got 50/60fps normal quality videos on YouTube via some trickery, but the resolution and bitrate are too low IMO. I don't think it's possible with HQ video.
I think a more viable option (considering bandwidth) would be to handle interlaced SD video properly, but I don't know if it would be possible to implement some form of bob deinterlacing with the Flash player. |
#25 | Link | |
Looks like that YouTube loophole is closed now - and I agree - the quality was lousy! Decent quality 60fps SD would require a lower bitrate than the 720p HD they do now, so why not provide it as an (official) option? (maybe the flash video player plug-in just can't keep up for most people? but that's also true for 1080p, and they've just launched that!) Cheers, David. |
#27 | Link |
1920x1080p60 with no chroma subsampling, quality compared to x264 CRF 18 encode and <100 ms latency. A distant dream for "crystal clear" video chatting.
#28 | Link |
Derek Prestegard IRL
![]() Join Date: Nov 2003
@Flux:
For the second time in this thread - chroma subsampling is NOT a bad thing!! It's only a bad thing during post-production, where mathematical precision is necessary. For final distribution encoding, even converting RGB to YV12 is perceptibly lossless, provided the proper process is followed to convert back to RGB (i.e. decent upsampling, correct matrix etc). ~MiSfit
These are all my personal statements, not those of my employer :) |
#29 | Link |
I think that's going a bit far. If you have super fine chroma details, RGB>YV12 certainly isn't perceptually lossless. If you're encoding the output of a PC screen, it can make quite a difference. It's not so visible on typical video from a camera - usually invisible, but not always.
Cheers, David. |
#30 | Link |
Possible, sure.
I did download the PNG sequence for Big Buck Bunny, and did some comparison on the RGB24 source vs YV12 -> RGB24, and was quite unable to spot a difference in normal viewing modes. Looking at R, G, and B components was another story, of course! I'd agree there's potential for obvious difference with screen capture. Also, it's very important to do good chroma upsampling on playback!! ~MiSfit
#32 | Link | |
Chroma-subsampling makes the chroma a little soft - not blocky or pixelated (if decoded correctly). Many encoders trash the chroma channels as they run out of bitrate, giving a blocky look on chroma edges. This isn't caused by 4:2:0 chroma, and could still happen with low bitrate 4:4:4 chroma. Cheers, David. |
#36 | Link |
Is there any quality differences between ffdshow High Quality YV12 to RGB conversion and Media Player Classic HC YV12 Chroma Upsampling shader?
#37 | Link | |
But anyways, I've been using greasemonkey and a gnome-mplayer script to replace the flash player (on linux). With that and vdpau, any hd video on there can be handled smoothly (except videos with the ad scheme, which seems to break things). Or at least it would be, but right now gtk seems to cause a bug which makes vdpau unusable on gnome-mplayer. ![]() Last edited by invisible; 8th December 2009 at 15:51. |
#38 | Link | |
For most of its life, it's been 24p. Upload 25p or 30p, and it drops frames to get it down to 24p. Not acceptable IMO. I have to slow down my 25p content (and then increase the pitch of the audio!) to make it work well on Vimeo! Cheers, David. |
#40 | Link | |
Fudge the MAFIAA
1080p, h.264, youtube |
