7th May 2010, 15:22 | #7601 | Link |
that was just an example if you haven't noticed...
7th May 2010, 16:52 | #7602 | Link | |
You've got a great program here! |
7th May 2010, 17:48 | #7604 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 7th May 2010 at 17:59. |
7th May 2010, 18:18 | #7605 | Link |
trouble with Avatar Movie
Hello I'm Maurizio from Italy, I successfully copied (it works well) with AnyDVD HD 6.6.4.0 through a protected image file of blue-ray disc, now in an attempt to create a MKV file or an AVCHD folder with RipBot264v1.15.1, after demuxing it froze and it get following error:
DirectShowSource: DirectShowSource : Graph refused to run.: Dimensioni non impostate. Impossibile allocare memoria. (C:\temp\RipBot264temp\job1\getinfo.avs, line 2) I tried to update the various RipBot tools, but the result does not change. Anyone can help me? THX |
7th May 2010, 23:02 | #7607 | Link | |
It's all good, no hard feelings on this end. |
7th May 2010, 23:21 | #7609 | Link |
Okay so instead of bothering you to add ogm support I went on a small little journey to unpack the ogm and then repack as an mkv. But for some reason the English audio picks up a delay. The Japanese audio is just fine. I'm probably just going to fix it manually with the mkvmerge delay feature. Then I'll use Ripbot, which I just want to tell you, is an excellent program, and I thank you for creating it.
Edit: Well it turned out I had to delay the audio by a full second. Odd, how it picked that up. Last edited by FellWolf; 7th May 2010 at 23:27. |
7th May 2010, 23:22 | #7610 | Link |
You should use 1080p subs because they will look better on 1920x1080 display.
8th May 2010, 00:00 | #7611 | Link |
Sorry for pestering, but for converting a 480p anime file to a psp compatible mp4 file is there a crf which produces higher quality? Or should I just leave it on 22? So far everything I've done I've just left at 22, but I'm wondering what type of difference it makes.
8th May 2010, 00:37 | #7612 | Link | |
Try this > http://forum.doom9.org/showthread.ph...09#post1387509 |
8th May 2010, 00:39 | #7613 | Link |
lower value = higher quality and larger size
higher value = lower quality and smaller size crf22 is a good tradeoff
8th May 2010, 01:14 | #7615 | Link |
hi, I have a problem: when I try to open any files, the program crash and it show me: "can't open getinfo.avs"; how can i solve that? I try with different movies, with different codec audio and video, but the problem don't disappears..
anyway congratulations for the program is truly the best I have ever tried! sin for a few crashes occasionally.. PS: sorry for my bad english, but.. I'm italian.. XD Last edited by m4r50; 8th May 2010 at 01:19. |
8th May 2010, 01:26 | #7616 | Link |
25mbps is enough for movies
23866 MB (bd-sl) = 24438784 KB 25000kbps (video) + 4608kbps (uncompressed 5.1 audio 16bit) = 29608kbps = 3701KB/s 24438784 / 3701 = 6603 s / 60 = 110 min
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 8th May 2010 at 01:28. |
8th May 2010, 05:14 | #7618 | Link |
Hi ,
I know that Ripbot 264 has included eac3to . I need to resize few files which are too large after encoding BD into 720p. Resulting 3 files : a LPCM of 2 GB , a DTS of 987 MB and an AC3 of 980 MB. I wanna convert them to maximum 200-300 MB each , doesn't matter the quality ( I know the problem ) So , in this case , can I use Ripbot ?? and how ?? If no , I must use eac3to , but I didn't found yet an interface for it... can smb help me ??? THX !! PS : One MORE question : When a movie has 4 or 5 sound tracks , how can I encode ALL of them , in the same time using Ripbot ??? Is there such a possibility ??? If there isn't , how can I encode / convert them separatelly and how can I attach them to the movie ?? Last edited by benjyv; 8th May 2010 at 05:32. |
8th May 2010, 05:37 | #7619 | Link | |
i7 920 @4.2GHz w/HT |
8th May 2010, 05:43 | #7620 | Link | |
I demuxed the movie with tsMuxer to get the audio files. I am in the process of encoding the movie without audio. When done I will add the audio to it with mkvtoolnix. The audio tracks in the movie are all AC3 2.0 with bitrate 192-224 so there is no need to recode them but if they were DTS I would just use PopCorn AudioConverter to recode them from the finished mkv. |
