Old 15th May 2019, 08:50   #56241  |  Link
Who actually has the latest Nvidia drivers actually change timings for them? I can't get anything over 1 frame repeat I think it was every 13 odd mins. It's like the drivers themselves are just preventing changes.
Nothing I select makes a difference. With 385.28, no problems at all..Seems that quite a few people are in the same boat. Narrowing down what's allowing people to get results vs not might be useful in improving this?
Old 15th May 2019, 10:30   #56242  |  Link
tp4tissue
tp4tissue's Avatar
I have a slight fear in the back of my mind that with streaming, the flock has moved away from media collection, and concurrently away from Good'ol PC playback.
With less users overall, the worst iteration of this play out is non-support down the road for our beloved hobby.
Ghetto | 2500k 5Ghz
Old 15th May 2019, 11:46   #56243  |  Link
chros
chros's Avatar
I'm pretty sure it doesn't work for anybody, they just haven't noticed it.
Old 15th May 2019, 12:02   #56244  |  Link
I guess the best solution will be to use Smooth Motion @ 120Hz to avoid this situation altogether. Is Smooth Motion @ 120Hz better than 24Hz with no frame drops/repeats? Anyone done any comparisons? Huhn?
I could hold with a 1080 and 385.28 until I upgrade to a HDMI 2.1 setup.. real shame it hasn't eventuated this year, although with the LG 9 series OLED you could manage 1440 at 120Hz.
Old 15th May 2019, 14:21   #56245  |  Link
chros
chros's Avatar
I could hold with a 1080 and 385.28 until ...
For me the best is to use 23p for 23fps content. And you can do it with 385.28 as you've said. But everybody favours something different ...
Old 15th May 2019, 16:10   #56246  |  Link
el Filou
el Filou's Avatar
You still need good timings in order to avoid frame drops/repeats even with streaming. People move away from PC to Android boxes or players integrated to their TV even for local media playback.
Surprinsingly, PC playback may actually be saved by streaming, with a lot of people watching from their laptops.
Old 15th May 2019, 17:48   #56247  |  Link
cremor
I'm not on the latest version, but with 430.53 (hotfix) I can use the custom modes from madVR without problems. Although I have to say that I only ever tried to optimize the pixel clock because that already bringt me multiple hours between expected frame drops/repeats.
RTX 2070 with a gaming monitor. Custom modes for 100 and 119 Hz.
cremor is offline   Reply With Quote
Old 15th May 2019, 18:07   #56248  |  Link
Klaus1189
cremor
Do you use a 23 Hz mode of any kind (standard or optimized)? Other refresh rates than 23 Hz don't have problems in short intervalls of frame drops or repeats, as far as I know.
Old 16th May 2019, 08:56   #56249  |  Link
alps006
My projector is BenQ TK-800. When I tried to lower target peak nits below 100 nits, madVR defaults back to 200 nits but anything above 100 nits is settable. Anyone had this type of issue or just me? BTW, I get perfect picture quality at 100 nits, just wanted to do more experimenting.Thanks!
alps006 is offline   Reply With Quote
Old 16th May 2019, 09:17   #56250  |  Link
Asmodian
Below 100 nits is not very reasonable, 100 nits is SDR's peak so trying to map to a peak below that gets odd. This behavior is by design, notice that when you type in a number below 100 it is red, while at 100+ it is green.
madVR options explained
Old 16th May 2019, 10:44   #56251  |  Link
cremor
Originally Posted by Klaus1189 View Post
cremor
No, I just use 100 (25*4) and 119 Hz (23,976*5). Since this is a PC monitor, I don't like lower refresh rates because of sluggish mouse movement etc.
Old 16th May 2019, 17:46   #56252  |  Link
Siso
Soul Seeker
Siso's Avatar
Guys, for scaling factor 1.3 what do you recommend? Image upscaling: Jinc+upscaling refinement (crispen edges or adaptive sharpening), or image doubling: NGU Sharp medium or high?
Old 16th May 2019, 17:55   #56253  |  Link
zaemon
Go for NGU if you can afford it.
zaemon is offline   Reply With Quote
Old 16th May 2019, 18:50   #56254  |  Link
Siso
Soul Seeker
Siso's Avatar
I can afford NGU Sharp High, but my thought is - is it worth the gpu load...
Old 16th May 2019, 20:17   #56255  |  Link
tp4tissue
tp4tissue's Avatar
I'm a huge NGU fan.
For < 1080p files, NGU makes a huge difference even at a distance.
For >= 1080p files, If you're sitting < 5 feet from the monitor/ tv . NGU still looks sharper.
However, for > 5 feet, It's almost impossible to tell NGU vs Nearest neighbor (1080 to 4K) unless you're running a test pattern.
And I tested myself for NGU vs Lanc (1080 to 4K) @ 5 feet, I got it wrong 50% of the time, So I definitely can not tell at that distance for 1080p files. ESPECIALLY for moving image,
Overall, my point is, DO consider being green when possible. Lanc looks very good at 5+ feet.
Ghetto | 2500k 5Ghz
Old 16th May 2019, 20:42   #56256  |  Link
Asmodian
I agree for a ratio of 1.3x. At that low of an upscale NGU+SSIM100 v.s. Jinc or Lanczos is very subtle in almost all viewing conditions. NGU is only useful for ratios below 1.5x when you use electric heat anyway.
Old 16th May 2019, 20:46   #56257  |  Link
nussman
@Siso was asking for scaling factor 1.3, Nearest neighbor for integer scaling is a complete different story.
Anyway if you have to ask here then NGU is probably not worth it? You have to test it, because differences depend on your content and then decide on your own.
nussman is offline   Reply With Quote
Old 16th May 2019, 20:49   #56258  |  Link
Siso
Soul Seeker
Siso's Avatar
I'm watching 1080p good encodes on the monitor which is 21:9 (2560x1080p) I can manage NGU Sharp High with my GTX 1050ti, but I was wondering if I can use image upscaling settings instead of image doubling. The visual difference is not that obvious between them.
Old 16th May 2019, 20:58   #56259  |  Link
nussman
Of course you can. I am using Jinc/DXVA upscaling most of the time and „NGU high quality settings“ for a special movies night.
Old 16th May 2019, 21:02   #56260  |  Link
Siso
Soul Seeker
Siso's Avatar
NGU High is good, but does it really need the ~24 ms rendering time on my card...
