5th September 2019, 17:23 | #121 | Link | |
@VoodooFX I'll probably add that to the SysInfo() plugin.
Groucho's Avisynth Stuff |
5th September 2019, 20:36 | #122 | Link |
Banana User
I was thinking about some trick without external plugin.
I have seen on other forums newbies have problems with standalone MeGUI's avs+ not auto-loading ImageSeq.dll, error is not very clear what is wrong. I'll just catch that and assert with more clear msg then. Requesting them to get more plugins not good idea. Last edited by VoodooFX; 5th September 2019 at 20:43. |
5th September 2019, 22:06 | #123 | Link | |
As for megui's "portable" mode and plugins that were externalized in AVSPlus - I don't understand how this is even a problem, it seems ridiculous.
7th October 2019, 04:39 | #124 | Link | |
16th October 2019, 02:50 | #126 | Link |
Its up now.
21st November 2019, 10:58 | #128 | Link |
Where's my loot?
24th December 2019, 14:06 | #130 | Link |
i would like to ask can avisynth increase video quality or 240p video to 720p with some scripts?
https://tune.pk/video/7484297/hatim-episode-1 |
24th December 2019, 17:16 | #131 | Link | |
Broadcast Encoder
Anyway, there are good upscaling kernels that can upscale a source quite nicely like Spline64 which you can use together with NNEDI. Please note that - as I said - although you are gonna have more pixels, you won't have more definition as those new pixels are just gonna be "fake". Some argue that upscaling doesn't bring any benefit at all and it's just a waste of space, but on the other hand some other people argue that sometimes it's worth upscaling as it's better to do it with Avisynth than to let the TV or the player do it with something crappy like a FastBilinear. As to your source, it seems to be starved which basically means that whoever encoded it did it at a very low bitrate thus removing important details. With a source like this, upscaling is the LAST thing I would do. If you really wanna re-encode it, just do deblocking with Deblock_QED() or the built-in deblocker of x264/x265 if you're planning to re-encode it in H.264/H.265 and a bit of denoise with dfttest(). It will look flat, but at least you won't have macroblocks and ringing everywhere. By the way... You linked a streaming website that I don't know, but I highly doubt that it's legal, so if it isn't, moderators will remove your link and you won't receive any further help as piracy is forbidden! I just did a google search of the series and the first thing I found is a website with the DVDs of the series you linked. I strongly suggest you to get the official DVDs which are gonna be a relatively high bitrate MPEG-2 encodes at 720x480i which are far better than the crappy starved 240p source you linked. Last edited by FranceBB; 24th December 2019 at 17:19. |
24th December 2019, 18:07 | #132 | Link |
+1 for what FranceBB said, tis truly garbage.
24th December 2019, 19:06 | #133 | Link | |
24th December 2019, 20:36 | #134 | Link | |||
On Amazon, Currently Unavailable:- https://www.amazon.in/Hatim-Star-Plu.../dp/B07RNCKZP5
Given prev quotes, might also be rubbish. Google Search "Hatim DVD" https://www.google.com/search?ei=QmY...4dUDCAo&uact=5 Good Luck. EDIT: @ 1 Rupee = £0.011, I make it about £55.00 on Snapdeal, for a garbage DVD [assuming previous quotes also apply to SnapDeal DVD]. Suggest dont waste your money.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 25th December 2019 at 16:42. |
25th December 2019, 16:51 | #135 | Link | |
26th December 2019, 02:57 | #136 | Link |
Imsrk48,
Below is auto generated from a much bigger script. Source has a weird ripple effect, I think may have been in XVID/DIVX at some point. Also sections have duplicates where seems to be about 2/3 framerate of the source 24FPS, this messes with motion compensation stuff. Could stand getting rid of the logos at bottom [see InPaintDelogo thread]. About as much time as I would be prepared to spend on it [although many have spent a long time trying to repair worse clips] Code:
V=LSmashVideoSource(".\Hatim Episode 1 - Tunepk.mp4") # LSmash Plugin A=LSmashAudioSource(".\Hatim Episode 1 - Tunepk.mp4") AudioDub(V,A) ORG=Last # Below auto generated from Manual settings Deblock(28) # Plugin (might want to adjust this value) Cropped=Crop(0,0,0,0,align=true) # AutoLevels from my MediaFire account, v0.12Beta3_20190711 Cropped.AutoLevels( \ FilterRadius=12, \ gamma=UnDefined, \ AutoGamma=False, \ midpoint=0.500000, \ input_low=UnDefined, \ input_high=UnDefined, \ ignore_low=0.001953, \ ignore_high=0.001953, \ border_l=0, \ border_r=0, \ border_t=0, \ border_b=0, \ Debug=False, \ sc2Th=8, \ sc2Perc=33.333332, \ gammax=1.500000, \ gammin=0.666667, \ MinRng=100) McDegrainSharp(frames=2,csharp=0.333000,Precise=False) # http://forum.doom9.org/showthread.php?p=1737045#post1737045 [Might want to adjust frames (1->3)] nnedi3_rpow2(rfactor=4,cshift="Spline36Resize",fwidth=960,fheight=720) # Plugin (960x720=4:3) Limiter(16,235,16,240) AudioDub(Last,MergeChannels(GetChannel(1),GetChannel(1))) # Make 2 channel ResampleAudio(44100) # from 22.50 KHz MeGUI_DarX=4 MeGUI_DarY=3 # Auto set Megui DAR : SnapDeal says DAR is 16:10, looks more like 4:3 to me. Trim(0,0) # chop/pad audio to match video length Return Last Return StackHorizontal(ORG.Spline36Resize(960,720),Last) # Original on left, Doctored on right. # COMMENT OUT Above Return Last EDITED as per later post.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 26th December 2019 at 04:23. |
26th December 2019, 04:03 | #137 | Link | |
26th December 2019, 04:14 | #138 | Link |
imsrk48,
There is not a huge difference, but there is some. Can compare with simple Spline36Resize using below. After AudioDub line add Code:
ORG=Last Code:
Return StackHorizontal(ORG.Spline36Resize(960,720),Last) # Original on left, Doctored on right. [EDIT: See my prev post, marked in Blue] Could use above to adjust eg Deblock() arg whilst seeing before and after frames. MysteryX did some supposed SuperRez thing [EDIT: in devs forum] , dont know if would produce any great improvement [never used it]. EDIT: Also, in future, might be better to start your own thread [its quite easy], this thread is really about eg changes in avisynth itself [or questions about avisynth], rather than processing video. People may be more reluctant to answer video processing questions when posted in the wrong thread. EDIT: You might want to try with deblock() lowered or completely removed, see what it looks like (DeBlock can fix some types of blocking, but can also cause damage, its a balancing act). Also, it may be that some of the blocking is from before 1 or more resizes to the source, if so then using deblock cannot help for that blocking, its burned in. The Baby Face, near beginning does benefit from deblock , maybe use those frames to get best setting, try not to go too high, I think max is about 30 or 32. csharp adjusts sharpness in McDegrainSharp [McDegrainSharp(frames=2,csharp=0.333000,Precise=False)], default is 0.6 but I tend to use 0.3 or thereabouts for MY default, suggest dont go above 0.6. EDIT: Another version to try. Switched on NonLinUSM in script generator, & slight mods to script generator defaults. Code:
V=LSmashVideoSource(".\Hatim Episode 1 - Tunepk.mp4") # LSmash Plugin A=LSmashAudioSource(".\Hatim Episode 1 - Tunepk.mp4") AudioDub(V,A) ORG=Last # Below auto generated from Manual/Auto_detected, settings Deblock(20) # Reduced from 24 Cropped=Crop(0,0,0,0,align=true) # QueryBorderCropped And/Or Remove Padding for prev DeBlock filter Cropped.AutoLevels( \ FilterRadius=12, \ gamma=UnDefined, \ AutoGamma=False, \ midpoint=0.500000, \ input_low=UnDefined, \ input_high=UnDefined, \ ignore_low=0.001000, \ ignore_high=0.001000, \ border_l=0, \ border_r=0, \ border_t=0, \ border_b=0, \ Debug=False, \ sc2Th=8, \ sc2Perc=33.333332, \ gammax=1.100000, \ gammin=0.909091, \ MinRng=100) McDegrainSharp(2,csharp=0.300000,Precise=False) # Pre-Upsize # have reduced (a little) to 0.3, sharpness csharp, 0.0 -> 0.6 nnedi3_rpow2(rfactor=4,cshift="Spline36Resize",fwidth=960,fheight=720) # Upsize NonlinUSM(z=3, pow=1.100000, str=0.250000, rad=9) # ADDED: Search NonlinUSM script : Can Mod local contrast, suggest str 0.2 - 0.33 Limiter(16,235,16,240) # Limit to TV_Levels range AudioDub(Last,MergeChannels(GetChannel(1),GetChannel(1))) # Matching to required output, 2 audio channels ResampleAudio(44100) # Match to required Audio SampleRate MeGUI_DarX=4 MeGUI_DarY=3 Trim(0,0) # chop/pad audio to match video length #Return Last # End of Generated Script Return StackHorizontal(ORG.Spline36Resize(960,720),Last) most evident in eg hair. If I use it, I usually use 0.25 or 0.33. Can just comment out that line if you dont like it. EDIT: From the clip, seems to be a Hindi, "Lord Of The Rings" clone. EDIT: Added some comments in script generator, marked above in RED
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 27th December 2019 at 00:37. |
27th December 2019, 06:15 | #140 | Link |
See Wiki [see everything on wiki homepage] :- http://avisynth.nl/index.php/Main_Page
Internal filters:- http://avisynth.nl/index.php/Internal_filters External Filters:- http://avisynth.nl/index.php/External_filters
avisynth, faq |
