28th November 2010, 23:33 | #4021 | Link | |
Are you sure of the quality of your source files? Do you have a look at the preview window of starip? Bye... Last edited by Famille_CB; 28th November 2010 at 23:48. |
29th November 2010, 07:34 | #4022 | Link |
I have the same issue, staxrip don't like ts with avc+aac or mpeg2+aac but i don't have issue with ts mpeg2+mp2. I have the same bug with avc, bad decoding like your screenshot. And with aac audio, staxrip don't demux audio or it demux audio but can't cut it or it cut it but there no sound in aac... Try to demux before with tsMuxeR GUI, don't often to apply the delay for audio. I realy love staxrip, but that was a big problem for encoding ts files. See ya Last edited by tasslehoff44; 29th November 2010 at 07:48. |
29th November 2010, 21:58 | #4023 | Link | |
Yeah it's happens with all of my H264 TS recordings from two different Satellite receiveres (Dreambox DM800 + Vu+ Duo). It happens at 38 seconds everytime also. |
8th December 2010, 17:32 | #4024 | Link |
The Lazy One
Location: The TurokZone. Next Door are the heavens, hells, and on the backside the void
looking at above how do ya load up .ts files? loading it directly into staxrip or doing an avs for it then load the avs in? ive worked with .ts files before and i never got problems with them. mostly becuz i do an avs for it first.
and ftr my ts files if i recall were mpeg2 and aac
Decided this quote only lol. "Always try to understand the perspective of not only yourself but others as well" Am a fanboy of StaxRip Last edited by turok; 8th December 2010 at 17:34. |
9th December 2010, 12:59 | #4026 | Link |
hi, i have ripped Avatar, everything is fine, but how do i get staxrip to rip the subs,
staxrip 1.1.7.0 does not rip the subs, vsrip doesn't even run, i click on the sub bit, it asks me where the subs are, but there are no subs anywhere because staxrip didn't rip them, could some one offer any advice concerning the Subtitle section in staxrip, subtitles seem quite hidden in staxrip, there's no mention of it in the interface, considering the importance of Forces subs, the subtitles features in staxrip are quite hidden away for the casual user i ran VSRip manually and ripped the subs, then told staxrip where the subs were, all was fine, why didn't staxrip do this itself? i have noticed that Staxrip wants me to point to the VOB files, but VSRip wants me to point to the IFO, seems there is a missing step somewhere, once staxrip reads the VOB files, for example VST_05_1 - 5_8, should it not then process the VST_5 IFO file, and automatically check for subtitle pointers and references, and then demux them and ask user what to do with them, or am i missing something, i remembered that AutoGK asked for the IFO file, then demuxed the relevant VOB files connected to that IFO file and also the Subs and did it's DGIndex thingy as well as asked what PGC to use (seamless branching) am i doing something wrong (most likely) all i want is the Forced subs in Avatar film to show, i tried manually VSRip (but the forced subs are not showing, ALL Subs are on) but i only want forced subs also i want soft subs, as i'm doing MKV container, don't want them burnt in to output file, hard subs is a thing of the past now right? AVI limitations are long gone (about time) Last edited by Pulp Catalyst; 9th December 2010 at 13:31. |
10th December 2010, 11:35 | #4027 | Link |
Practising Schemer
Hi Stax I wanted to build a version of staxrip with updated DGindexNV and X264. I can build staxrip from svn just fine however I cannot seem to find where to define which version of x264 i want to use so I end up with the staxrip unknown version warning.
Edit: update the help.txt and versions.txt looking in applications.vb and x264.vb but unable to build it successfully. Last edited by flebber; 10th December 2010 at 12:04. |
12th December 2010, 19:17 | #4028 | Link |
@flebber
You can press F1 in the applications dialog, tells you about some hidden on purpose features. @all I'm still taking a time out but I'll be back sooner or later.
12th December 2010, 21:09 | #4029 | Link |
x264-autoupdate
Due to x264.nl change way to store revisions - i remake autoupdate scripts for x264 in staxrip.
You must paste it as vbscript in edit dialog of menu-items. You need wget(for download) and winmerge(for visual control of changes) installed in applications folder. Manual update from menu item: (tools->edit menu) Code:
Dim o, HelpNow,HelpNew Set o = createobject("WScript.Shell") o.run "%COMSPEC% /c %application_dir:x264%..\wget\bin\wget.exe -N -P %application_dir:x264%new\ http://x264.nl/x264/32bit/8bit_depth/",0,true Set index = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%new\index.html", 1) Set regEx = New RegExp regEx.Pattern = "\/(revision\d*\d\d\d\d)\""" Set Matches = regEx.Execute(index.ReadAll) o.run "%COMSPEC% /c %application_dir:x264%..\wget\bin\wget.exe -N -P %application_dir:x264%new\ http://mirror01.x264.nl/x264/32bit/8bit_depth/"+Matches(0).SubMatches(0)+"/x264.exe",0,true o.run "%COMSPEC% /c %application:x264% --fullhelp > %application_dir:x264%help.now",0,true o.run "%COMSPEC% /c %application_dir:x264%new\x264.exe --fullhelp > %application_dir:x264%help.new",0,true Set HelpNow = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%help.now", 1) Set HelpNew = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%help.new", 1) IF (HelpNow.ReadLine <> HelpNew.ReadLine) then str1=str Do While (HelpNow.AtEndOfStream <> True) and (str1=str) and (HelpNew.AtEndOfStream <> True) str = HelpNow.ReadLine str=replace(str," ","") str=replace(str,"-","") str=replace(str,".","") str=replace(str,":","") str=replace(str,",","") str=replace(str," ","") str1 = HelpNew.ReadLine str1=replace(str1," ","") str1=replace(str1,"-","") str1=replace(str1,".","") str1=replace(str1,":","") str1=replace(str1,",","") str1=replace(str1," ","") Loop If (HelpNew.AtEndOfStream <> True) or (str1<>str) or (HelpNow.AtEndOfStream <> True) then o.run "%application_dir:x264%..\Winmerge\WinmergeU.exe %application_dir:x264%help.now %application_dir:x264%help.new",3,true if msgbox (" Update?",4+32,"Staxrip update: x264") = vbYes then o.run "%COMSPEC% /c COPY /V /Y %application:x264% %application:x264%.old",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%new\x264.exe %application:x264%",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%help.now %application_dir:x264%help.old",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%help.new %application_dir:x264%help.now",0,true end if Else o.run "%COMSPEC% /c COPY /V /Y %application:x264% %application:x264%.old",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%new\x264.exe %application:x264%",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%help.now %application_dir:x264%help.old",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%help.new %application_dir:x264%help.now",0,true o.Popup "Done.",1,"Staxrip update: x264",64 End If Else o.Popup "You have last version. - "+Matches(0).SubMatches(0),1,"Staxrip update: x264",64 END IF HelpNow.close HelpNew.close (tools->event commands) Code:
Dim o, HelpNow,HelpNew Set o = createobject("WScript.Shell") o.run "%COMSPEC% /c %application_dir:x264%..\wget\bin\wget.exe -N -P %application_dir:x264%new\ http://x264.nl/x264/32bit/8bit_depth/",0,true Set index = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%new\index.html", 1) Set regEx = New RegExp regEx.Pattern = "\/(revision\d\d\d\d)\""" Set Matches = regEx.Execute(index.ReadAll) o.run "%COMSPEC% /c %application_dir:x264%..\wget\bin\wget.exe -N -P %application_dir:x264%new\ http://mirror01.x264.nl/x264/32bit/8bit_depth/"+Matches(0).SubMatches(0)+"/x264.exe",0,true o.run "%COMSPEC% /c %application:x264% --fullhelp > %application_dir:x264%help.now",0,true o.run "%COMSPEC% /c %application_dir:x264%new\x264.exe --fullhelp > %application_dir:x264%help.new",0,true Set HelpNow = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%help.now", 1) Set HelpNew = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%help.new", 1) IF (HelpNow.ReadLine <> HelpNew.ReadLine) then str1=str Do While (HelpNow.AtEndOfStream <> True) and (str1=str) and (HelpNew.AtEndOfStream <> True) str = HelpNow.ReadLine str=replace(str," ","") str=replace(str,"-","") str=replace(str,".","") str=replace(str,":","") str=replace(str,",","") str=replace(str," ","") str1 = HelpNew.ReadLine str1=replace(str1," ","") str1=replace(str1,"-","") str1=replace(str1,".","") str1=replace(str1,":","") str1=replace(str1,",","") str1=replace(str1," ","") Loop If (HelpNow.AtEndOfStream = True) and (HelpNew.AtEndOfStream = True) and (str1=str) then o.run "%COMSPEC% /c COPY /V /Y %application:x264% %application:x264%.old",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%new\x264.exe %application:x264%",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%help.now %application_dir:x264%help.old",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%help.new %application_dir:x264%help.now",0,true End If END IF HelpNow.close HelpNew.close (tools->event commands) Code:
Dim o, HelpNow,HelpNew Set o = createobject("WScript.Shell") Set HelpNow = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%help.now", 1) Set HelpNew = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%help.new", 1) IF (HelpNow.ReadLine <> HelpNew.ReadLine) then if msgbox ("Update available - will see?",4+32,"Staxrip update: x264") = vbYes then o.run "%application_dir:x264%..\Winmerge\WinmergeU.exe %application_dir:x264%help.now %application_dir:x264%help.new",3,true if msgbox (" Update?",4+32,"Staxrip update: x264") = vbYes then o.run "%COMSPEC% /c COPY /V /Y %application:x264% %application:x264%.old",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%new\x264.exe %application:x264%",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%help.now %application_dir:x264%help.old",0,true o.run "%COMSPEC% /c COPY /V /Y %application_dir:x264%help.new %application_dir:x264%help.now",0,true end if end if END IF HelpNow.close HelpNew.close (tools->edit menu) Code:
Dim o, HelpNow,HelpNew Set o = createobject("WScript.Shell") Set HelpNow = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%help.now", 1) Set HelpNew = CreateObject("Scripting.FileSystemObject").OpenTextFile("%application_dir:x264%help.new", 1) IF (HelpNow.ReadLine <> HelpNew.ReadLine) then o.run "%application_dir:x264%..\Winmerge\WinmergeU.exe %application_dir:x264%help.now %application_dir:x264%help.new",3,true ELSE o.run "%application_dir:x264%..\Winmerge\WinmergeU.exe %application_dir:x264%help.old %application_dir:x264%help.now",3,true End if Last edited by PopovN; 12th December 2010 at 23:59. |
13th December 2010, 20:40 | #4031 | Link | |
Change x264 version
Will the "Config Codec" tabs be always fully functional? Thank a lot for this wonderful tool. |
27th December 2010, 00:05 | #4032 | Link | |
27th December 2010, 05:05 | #4033 | Link |
been using Xvid4PSP, and i have noticed that it uses Xvid Encraw, it gives a cpu (3 core AMD) utilization of 70-80%, where as Staxrip (Xvidcore.dll) gives only 35-45%,
i also noticed that Xvid4PSP sets a thread of 5 not 3, maybe by setting more threads it makes up for the huge inefficiencies of Xvid multi-threading which is well known, 1 Core to 1 thread is well known not to scale well with Xvid, Xvid just doesn't have good SMP in place, questions, 1a. Could staxrip ever use Xvd Encraw, 1b. Is Xvid Encraw more efficient than XvidCore.dll (like x264VFW and X264 CLI) 2. Is it possible to set Xvid Thread count in staxrip rip, i want to try and set the thread count to 5, and see what happens? 3. i noticed that Xvid Encraw seems to get developed still in places, minor granted, but developed none the less, question is..... is Xvid Craw superior to it's .dll cousin? have a wonderful new year, and a well deserved break, |
6th January 2011, 08:28 | #4034 | Link |
Practising Schemer
Is there an option in settings or via macro to use "original" audio channel detection when encoding. So by default whatever the audio source channels are detected as that's what they are encoded as?
6th January 2011, 10:56 | #4035 | Link |
Practising Schemer
Pulp catalyst i have xvid_encraw working with staxrip. Not sure if performance is better as I don't really use xvid very much. Anyhow.
I had an installation of Buzzqw's HDC which uses xvid encraw, so I removed the xvid file from my staxrip folder. I copied the xvid_encraw and xivdcore.dll to the staxrip folder(where the xvid encoder was). Start staxrip go tools applications. Press F11, go to your staxrip folder(or wherever you have your xivdencraw exe) and select that file, you may need to select all files to see it and then okay. Then press F12 and remove 1.2.2 and type xvid_encraw. now Staxrip should run xvid encraw. |
7th January 2011, 12:05 | #4036 | Link |
If I understand you correctly you would like to have the original audio unchanged in the encoded file? Just set the audio streams to "just mux" and the audio will be unchanged. If you want to have that automatically create a template where "just mux" is already chosen.
8th January 2011, 17:04 | #4038 | Link |
Might just be me, but when you perform Cutting (within preview), this gets added to bottom of the filters list. If you move this up in the filters list (in my case above my Fade entries), then right click on Cutting Filter and select Play, this works fine.
If however you do all that, but insterad of right click, you go back into Preview and then play with External (MPC-HC in my case), this puts Cutting back to bottom of filter list and you don't get the cut version of the video in the external preview or indeed in the final encoded file if you don't move it within filter list. I'm probably not explaining it all that well, but basically Cutting seems to not always "stick" when encoding unless you make sure you've clicked Play so that the AVS is re-written before then going ahead with the encode. |
8th January 2011, 20:59 | #4039 | Link |
thanks flebber,
another issue which has caused me many of headaches lately, for Xmas, i got a Box-set Startrek TNG & DS9 been converting TNG over to x264 using Staxrip, just started DS9, but the DVD structure is different, I.E. VTS_02_1.VOB - VTS_02_8.VOB in those files are 4 Episodes, but Staxrip doesn't read the IFO files, which is causing me a headache, because after the encode i have to split (i use mkvmerge), this was ok, and a trade off i accepted, but then came disk 6, this disk has all the extras for season one, 20 different clips all combined in the VOB files, if there anyway of forcing Staxrip to read the IFO files, and get the relevant information needed to process the individual files on these types of disks? if not, then can i hereby put in a request for IFO processing for the future, because i can't continue to use Staxrip now, splitting over 20 clips, is too much, ALSO more importantly, the clips have different aspect ratio's and should be processed individually so the correct calculations can be made, if all the VOB files are treated as one, then Staxrip will only make the one AutoCrop, which has caused problems, some of the clips have different bars in different places, and Autocrop needs to be done on each Chain, in fact been messing around with staxrip, if staxrip can't access the IFO files, then staxrip is really more tailored for Film DVD's and not EPISODE DVD's, hopefully when Stax returns, he can introduce IFO processing as an option, EDIT someone mentioned in another forum to use a DVDRipper that puts the files in separate VOB files, but that is a nightmare, and not really an option, i spent nearly 3 days ripping my DVD box-sets to my two Harddrives, to hell doing that all over again, LOL, |
8th January 2011, 22:15 | #4040 | Link |
Hi Stax,
Any idea if (and perhaps when) we could see some kind of life in StaxRip development please ? Please don't take this as a negative comment, I just start to miss the regular bugfixes and improvements, and kind of start to prefer MeGUI lately for just that reason. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
