Old 1st May 2016, 18:22   #241  |  Link
gpower2
gMKVExtractGUI author
gpower2's Avatar
MKVToolNix hasn't run on XP since version 7.8.0, so that's what I'm using. gMKVExtractGUI 1.8.0 seems to be working fine. There's probably little chance I'll ever upgrade XP on this PC. Maybe when I've played around with it more I'll switch to Linux, but other than that it'll be XP till it dies.
The PC's old. The next one will run Win7 until I'm hopefully comfortable switching to Linux and dumping Windows completely.
XP compatibility of Mvktoolnix has been restored later.
I think that v8.8 works on XP, but I am not so sure if that's the case with newer versions.
Thanks to djcj valuable feedback, and Mosu's support, gMKVExtractGUI works on Linux too, so you wouldn't have to stop using it!
gpower2 is offline   Reply With Quote
Old 1st May 2016, 19:03   #242  |  Link
hello_hello
Thanks for the info. I stopped paying attention to MKVToolNix after it stopped working on XP, so I had no idea that had changed again. I just gave MKVToolNix 9.1.0 a spin and it seems fine. Aside from the way it displays directories. ie "E:/video.mkv" rather than "E:\video.mkv". Is that an XP thing or is it normal?
Cheers.
Old 1st May 2016, 21:23   #243  |  Link
hubblec4
Matroska find' ich toll
... Aside from the way it displays directories. ie "E:/video.mkv" rather than "E:\video.mkv". Is that an XP thing or is it normal?
Cheers.
Thats normal.
Old 2nd May 2016, 06:55   #244  |  Link
bin_ch
Originally Posted by gpower2 View Post
Well, I changed the minimum size to 400x400 now, but I have to warn you that the layout of the "Actions" panel will be broken and I can't do much about it.
With this change, all new gMKVExtractGUI users will see a broken UI upon start. That's not making a good first impression IMO.
Users requiring such a small size shouldn't be the majority after all. Most users have to enlarge the window size which they probably don't need to previously.
Is it possible to make the initial size for the first run bigger than the minimum? I think it will create better user experience with this approach.
bin_ch is offline   Reply With Quote
Old 4th May 2016, 14:01   #245  |  Link
bin_ch
A small bug:
If job mode is enabled, as soon as 'Add job' is pressed, the status text in the main window immediately shows 'Extraction completed!'
This bug was introduced in 1.7.0
Old 4th May 2016, 17:48   #246  |  Link
gpower2
gpower2's Avatar
Thanks for the feedback bin_ch! Both bugs are fixed in trunk!
Old 5th May 2016, 07:08   #247  |  Link
magsoud
magsoud's Avatar
Add this:
1) Start main form's Auto fit Size!
2) Saved Setting! (last Window Size and ticked in Action item,...)
magsoud is offline   Reply With Quote
Old 19th May 2016, 23:47   #248  |  Link
alfixdvd
Since release 9.1.0 of mkvtoolnix I have trouble with almost mkv files.
I start gmkvextractgui, I browse and choose an mkv file and nothing happens. Panel is empty of information and gmkvextractgu hangs, mkvinfo don't retrieve any information.
With version 9.0.1 of mkvtoolnix all's fine
alfixdvd is offline   Reply With Quote
Old 20th May 2016, 00:13   #249  |  Link
Wildfire
No problems here - it must be a system-specific issue.
Wildfire is offline   Reply With Quote
Old 20th May 2016, 07:08   #250  |  Link
alfixdvd
I don't think. MKVcleaver works fine with both versions of mkvtoolnix.
Old 20th May 2016, 08:39   #251  |  Link
bin_ch
No problems for me, too.
Are you using Non-English Windows?
If so, you might want to give the pre builds of MKVToolNix a try.
Old 20th May 2016, 10:07   #252  |  Link
Wildfire
My Windows is non-English too (Dutch, to be precise). No problems here.
Old 21st May 2016, 10:30   #253  |  Link
alfixdvd
I will use MKVcleaver because it works fine with both versions of mkvtoolnix
Old 21st May 2016, 14:12   #254  |  Link
bin_ch
So have you tried the pre-builds?
I was suggesting the pre-builds of mkvtoolnix because version 9.1.0 introduced a bug in the output of mkvmerge identification, which gMKVExtractGUI relies on to get file info.
The bug has been fixed in pre-builds 01201 and higher.
If it's still no good with the pre-builds, then you might have indeed found a bug in gMKVExtractGUI.
In that case, you'll need to provide more detailed information for the author to investigate, for example, manually execute mkvmerge.exe --ui-language en --identify-verbose file.mkv and post the output.
Old 22nd May 2016, 15:22   #255  |  Link
alfixdvd
I installed 9.1.0 final over 9.0.1 final without de-install, and now works fine.
I don't understand what happens.
If I have another issue I will try : mkvmerge.exe --ui-language en --identify-verbose file.mkv to try to identfy the problem.
thanks
Old 22nd May 2016, 20:02   #256  |  Link
gpower2
gpower2's Avatar
Sorry for the delayed response alfixdvd...
In gMKVExtractGUI v1.8 & MKVToolNix 9.1.0 the identification process relies solely on mkvmerge.exe and not on mkvinfo.exe like it used to.
Perhaps something happened with your installation with MKVToolNix and that caused the problems you were having.
As the other users suggested, if you happen to run again into problems with gMKVExtractGUI, you could try to run the command "mkvmerge.exe --ui-language en --identify-verbose file.mkv" manually, and post the output here.
Thanks for your feedback!
Old 23rd May 2016, 13:01   #257  |  Link
hello_hello
I generally download the portable MKVToolNix and unzip it to an appropriately named folder, after renaming the old MKVToolNix folder to something like "MKVToolNix_old". If you copy the ini file from the old MKVToolNix folder to the new one it'll retain the previous settings.
That way it's fairly easy to change the version of MKVToolNix gMKVExtractGUI is using, without having to uninstall/install it.
Old 20th November 2016, 15:03   #258  |  Link
Perenista
I am having this problem here:
Extraction of track ID 1 with the CodecID 'A_MS/ACM' is not supported.
Tried to do this:
Perenista is offline   Reply With Quote
Old 20th November 2016, 21:14   #259  |  Link
gpower2
gpower2's Avatar
You are posting a screenshot of another application (MKVExtractGUI2) and not of gMKVExtractGUI, so I can't help you.
Old 21st November 2016, 12:33   #260  |  Link
Perenista
This error I reported is happening with this app, gMKVExtractGUI. Here's the screenshot from gMKVExtractGUI:
And only affects this PCM 5.1 track:
In case you are wondering, this is not the only app that isn't capable of extracting this PCM 5.1 track.
As I reported on Doom9, these can't do the same, too:
- MKVCleaver
- MKVExtractGUI (see previous post)
So, that means this track is stuck inside my MKV (extracted from a Blu-ray - it's lossless).
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui
