Old 9th January 2017, 22:41   #21  |  Link
kolak
It should work with standard build.
Old 26th October 2017, 12:23   #22  |  Link
Malow
In bytes we trust
Malow's Avatar
Cineform is now open-source:
https://gopro.com/news/gopro-open-so...cineform-codec
https://gopro.github.io/cineform-sdk/
https://github.com/gopro/cineform-sdk/releases
Malow is offline   Reply With Quote
Old 26th October 2017, 15:21   #23  |  Link
kolak
Great news!
Old 29th October 2017, 06:02   #24  |  Link
WorBry
Thought that would never happen ! What do you think the prospects are then of seeing a Cineform encoder in ffmpeg any time soon?
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 29th October 2017, 13:03   #25  |  Link
kolak
I hope it will happen. ffmepg decoder is not very well optimised. "Original" code is few times faster and has all features, so I hope someone will port it.
Clineform due to its wavelet nature is quite unique and fact that you can now edit 4K streams at 1/2 resolution on i5 laptop in Premiere is amazing. No need for any proxy or optimised media.
Old 17th November 2017, 06:10   #26  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Assuming the answer from Paul B Mahol is to be taken seriously...
Old 23rd November 2017, 05:18   #27  |  Link
WorBry
What an oddly worded reply from Paul B Mahol. I'm not a programmer, but if the quality of the coding is of "astonishing quality" (implying high level), surely that's a good thing - or is it just that he personally finds it too complex to tackle ? So is his the final word on the matter or do we hope for some other FFMPEG developer able and willing to step up to the plate ?
Old 23rd November 2017, 13:59   #28  |  Link
kolak
Yes, I was thinking about the same.
I'm not a programmer either, so don't understand what it's involved, but surely this is SDK, so you just plug into it. Don't have to re-write core.
Old 23rd November 2017, 19:58   #29  |  Link
Rumbah
I think it's irony (bad code quality and not well documented).
x264 full help - x264 --fullhelp r2345
Cuttermaran HCEnc provider - Support for HCEnc in Cuttermaran
DualDVDRB - Dual core support for DVD-RB free
Rumbah is offline   Reply With Quote
Old 23rd November 2017, 21:24   #30  |  Link
kolak
I couldn't decide if it's irony or not.
So it means ffmpeg code is total rubbish as it's few times slower for decoding
Old 23rd November 2017, 22:52   #31  |  Link
Speed doesn't relate to code quality. But instead of wise-cracking here, maybe contribute improvements to ffmpeg?
Old 23rd November 2017, 23:18   #32  |  Link
kolak
Not directly, I understand this.
ffmepg code is written by many people and overlooked to have "fixed structure".
Cineform SDK was written by 1 (or 2) guys. You do write it very different in such a case. I know this from writing Python scripts.
This still doesn't change fact that Cineform SDK is few times faster than ffmpeg and I assume it can be speed up even further.
This just shows that ffmpeg code may have nice structure but it's far from being optimal. This applies to many parts of ffmpeg code.
I would help, but I'm not far good enough.
Old 24th November 2017, 07:20   #33  |  Link
Rumbah
Actually it was meant the other way round. The code for integrating the SDK has to be maintained in ffmpeg. And if the SDK's code quality and documentation is not very good (and that is very likely in a 1-2 man project) then maintaining is nearly impossible.
Old 24th November 2017, 14:08   #34  |  Link
shekh
To anyone. What do you think about the Active Metadata? Good/bad? Do you imagine it in FFMpeg? It is very weird part of the sdk...
Old 24th November 2017, 18:44   #35  |  Link
kolak
It's quite cool. Industry is so legacy and lazy. Those sort of things should be already "present" years ago.
There was FirstLight (I think) programme which made a use of it. You could open video with it, do adjustment and if you had this file loaded in some player or NLE change were visible straight away.
Matada or rather active metadata is something very underestimated in my opinion. We still can't even pass properly simple things like color space etc properly, so maybe active meted is just to much
David's (guy who wrote Cineform) ideas were just to much ahead of the time and lacked support+money from bigger company. Even so he did manage to make it SMPTE standard.
Old 1st December 2017, 19:15   #36  |  Link
WorBry
So if Paul B Mahol was being ironic/sarcastic/snobbish and that actually is the case then, are all hopes of integrating the SDK in ffmpeg dashed ?
DaVinci Resolve 14.1 has now incorporated the Cineform SDK and I believe Lightworks Pro 14.1 beta and Hitfilm Express 2017 have also. There is this expectation that it is just a matter of time before FFMPEG incorporates full Cineform support.
https://hitfilm.com/forum/discussion...ly-open-source
If that is not to be, it would be helpful to get an unambiguous statement from FFMPEG on that.
Old 1st December 2017, 19:35   #37  |  Link
shekh
VDFM is also in the list. I think the FFMpeg statement was right there: "patch welcome"
Old 1st December 2017, 20:01   #38  |  Link
It all depends on the contributions of volunteers. Like already said above, contribute! Thats all the statement you'll ever get. FFmpeg already has a cineform decoder, so maybe someone will improve that based on the knowledge gained from the SDK, and maybe someone will clean up the encoder for integration, but until someone does, we won't know.
On that note, the code quality of the Cineform SDK and the fact that it doesn't present a clear and usable interface for clean integration (basically, its not meant to be a re-usable library) mean that any such attempts would require a *significant* effort to meet the FFmpeg guidelines.
Old 1st December 2017, 21:48   #39  |  Link
WorBry
I would, but I'm not a programmer. Thanks for the explanation anyway.
Old 2nd December 2017, 01:24   #40  |  Link
WorBry
A comment from David Newman, who wrote the Cineform code:
http://www.dvinfo.net/forum/cineform...ml#post1939158
