Old 11th April 2019, 14:10   #21  |  Link
Asilurr
A couple of tests on video content generated from still images.
#1 Lenna (preview: wikipedia.org/wiki/File:Lenna_(test_image).png; download: lenna.org), 512x512 RBG24 converted to 8-bit 4:4:4.
x264vs || relative filesize 100.0%
x265vs || 104.7%
#2 M87* (preview: wikipedia.org/wiki/File:Black_hole_-_Messier_87.jpg; download: eso.org/public/archives/images/original/eso1907a.tif), 7416x4320 RGB48 converted to 3708x2160 10-bit 4:4:4. Do note that the original TIFF is a gargantuan 183 MB file.
x264vs || 100.0%
x264f || 100.8%
x265vs || 103.2%
x265f || 104.2%
Asilurr is offline   Reply With Quote
Old 12th April 2019, 09:10   #22  |  Link
gdgsdg123
HEVC in particular has intraframe prediction and other advanced tools that should squeeze even more bits out.
They aren’t all on even in —preset placebo, though! Using —cu-lossless and —tskip can help improve efficiency and quality of near-lossless encoding. Cu-lossless allows any given CTU to use lossless mode if it is more efficient; real lossless is just using that for the whole frame.
The docs give somewhat different opinion.
About --tskip:
Lossless — x265 documentation
Transform Skip
A somewhat related feature, --tskip tells the encoder to evaluate transform-skip (bypass DCT but with quantization still enabled) when coding small 4x4 transform blocks. This feature is intended to improve the coding efficiency of screen content (aka: text on a screen) and is not really intended for lossless coding. This feature should only be enabled if the content has a lot of very sharp edges in it, and is mostly unrelated to lossless coding.
About --cu-lossless:
Command Line Options — x265 documentation
--cu-lossless, --no-cu-lossless
For each CU, evaluate lossless (transform and quant bypass) encode of the best non-lossless mode option as a potential rate distortion optimization. If the global option --lossless has been specified, all CUs will be encoded as lossless unconditionally regardless of whether this option was enabled. Default disabled.
Only effective at RD levels 3 and above, which perform RDO mode decisions.
And 1 thing I must emphasize... near-lossless = lossy.
gdgsdg123 is offline   Reply With Quote
Old 14th April 2019, 12:10   #23  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Heavily filtered video might sometimes benefit from tskip, but natural video never will. And since x265 doesn't even implement the screen coding range extensions, the actual capabilities of tskip and other screen coding tunings are very nerfed.
Old 20th April 2019, 07:25   #24  |  Link
pookpooi
pookpooi's Avatar
The rumored Sony's new video codec XEVC which is based on HEVC version 2 claims 240Mbps peak bitrate lossless compressing 1920 x 1080, 12 bit depth, 24fps. I did a calculation and get 1:7.12 ratio.
source: https://www.eoshd.com/2018/12/sonys-...aw-at-240mbit/
pookpooi is offline   Reply With Quote
Old 22nd April 2019, 23:53   #25  |  Link
benwaggoner
Visually lossless at that rate is certainly feasible, but mathematically lossless is impossible unless they're doing some sort of prefiltering.
Ben Waggoner
My Compression Book
Old 16th July 2019, 13:00   #26  |  Link
gdgsdg123
Originally Posted by poisondeathray View Post
FFV1 (in interframe mode)...
Hmm?..
FFV1 Video Codec Specification
The FFV1 video codec is a simple and efficient lossless intra-frame only codec.
If source has identical content, duplicate frames, then lagarith can be better (null frame option)
I doubt it.
As Lagarith is sort of an old outdated codec... And more advanced codecs (like x264, x265) should have implemented similar capabilities in the algorithms.
Old 1st August 2019, 01:49   #27  |  Link
gdgsdg123
You might be correct... See this.
Old 1st August 2019, 02:15   #28  |  Link
poisondeathray
Originally Posted by gdgsdg123 View Post
Hmm?..
Scroll down
4.8.17 intra
intra indicates the relationship between frames. Inferred to be 0 if not present.
value relationship
0 frames are independent or dependent (keyframes and non keyframes)
1 frames are independent (keyframes only)
Other reserved for future use
https://trac.ffmpeg.org/wiki/Encode/FFV1
GOP size -g integer >= 1 For archival use, GOP-size should be "1".
I doubt it.
Yes, but null frames is a special case with pure duplicates . And it's an intra codec, usually compression is worse on typical content
eg.
blankclip(length=1000, width=1280,height=720, pixel_type="YV12")
ie. 1001 blank frames, 1280x720 , 24fps, YUV 4:2:0
x264 --qp 0 mp4 container => 49.2kb
x264 --qp 0 --keyint 1001 mp4 container => 48.6kb
lagarith with null frames, avi container => 31.4kb
I have no idea what you're trying to say there
Maybe try google translate
Old 1st August 2019, 04:10   #29  |  Link
gdgsdg123
Hmm?..
Scroll down
4.8.17 intra
valuerelationship
I doubt such behavior matches the definition of intra-frame only...
Another time then...
Hint: Those numbers are file sizes in Bytes.
Old 2nd August 2019, 00:27   #30  |  Link
benwaggoner
Although skip frames in the elementary stream are also possible in H.265 and HEVC. I'm not sure if x265 will use those with IDR-only encoding. It could be a useful option to add.
Ben Waggoner
My Compression Book
Old 2nd August 2019, 02:13   #31  |  Link
gdgsdg123
Merging such duplicates would be almost the most obvious way in exploiting redundancy.
And for people who came up with: general compression, motion estimation, psycho-visual optimization... such state-of-the-art stuffs. There's no possibility that they ain't aware of this.
So?..
On x264's Handling regards Consecutive Duplicate Frames
Conclusion
Absurd, isn't it?
Bewildered too at first... But then soon sort of understood its design language behind this seeming absurdity.
(To be continued...)
Old 6th August 2019, 17:15   #32  |  Link
benwaggoner
Oh, I'm sure they do. But one advantage of a true skip frame is that it needed rest the maximum GOP duration encoder. So a 150 frame GOP could potentially encapsulate hundreds of playback frames in anime, for example.
Ben Waggoner
My Compression Book
lossless, x264, x265
