Old 16th October 2020, 17:03   #881  |  Link
bruno321
Another one similar to the two ones that I brought up above... but neither srestore nor Exblend (with or without PAL mode activated) are giving good results:
https://fex.net/s/tpytxl3
Is there anything I can do to get rid of those blends?
bruno321 is offline   Reply With Quote
Old 5th June 2021, 09:01   #882  |  Link
Metal-HTPC
hello,
I'm having a PAL VHS which runs in NTSC speed but is a NTSC->PAL conversion with field blending.
Am I able to apply a fix blend for both the interlaced and deinterlaced version (I don't have the hq interlaced versions for all clips for some I only have the low resolution ones which appear to be already deinterlaced)
so they could match with my NTSC hard telecined film which I would IVTC with TFM().TDecimate() ?
https://workupload.com/file/nmUpb9S3DD9
I'm also getting a script error with Srestore "expected ')' . In The line 63: avs26=!(VersionNumber() 2.6)
Line 60-65
function Srestore(clip sourceo, float "frate", "omode", float "speed", float "blocks", int "mode", float "thresh", int "cache", clip "dclip")
avs26=!(VersionNumber() < 2.6)
Which doesn't make any sense to me since I already use all the required plugins.
thanks in advance for your help
Metal-HTPC is offline   Reply With Quote
Old 5th June 2021, 09:30   #883  |  Link
real.finder
make sure you have last update from https://github.com/realfinder/AVS-St.../Srestore.avsi and https://github.com/realfinder/AVS-St...RF_Shared.avsi
See My Avisynth Stuff
Old 5th June 2021, 14:08   #884  |  Link
Metal-HTPC
ok it's working. I tried all the different options of srestore but can't seem to get it to the same frames as the dvd source and that is the interlaced I'm not at the progressive yet. So if anyone wants to check out the samples any help would be greatly appreciated. thanks a lot
Old 23rd August 2021, 11:01   #885  |  Link
rjansen1
Remco Jansen
FYI: After installing AVS+ 3.70 Srestore gave an "expected )" error. I found I needed to change the position from which to extract the version number in the AvsPlusVersionNumber function for it to start working again:
function IsAvsPlus()
FindStr(VersionString, "AviSynth+") != 0
function AvsPlusVersionNumber()
# IsAvsPlus ? eval(MidStr(VersionString(),17,4)) : 0
# adjusted search position for new AVS+ 3.70
IsAvsPlus ? eval(MidStr(VersionString(),19,4)) : 0
rjansen1 is offline   Reply With Quote
Old 23rd August 2021, 14:43   #886  |  Link
StainlessS
StainlessS's Avatar
From recent [maybe latest] Real.Finder Zs_RF_Shared.avsi,
#### some of StainlessS AvsVersion.avsi https://forum.doom9.org/showpost.php?p=1897680&postcount=5103
Function IsAvsNeo()               { FindStr(VersionString," Neo")!=0}
Function IsAvsPlus()              { FindStr(VersionString,"AviSynth+")!=0||IsAvsNeo}
Function AvsPlusVersionNumber()   { V=VersionString Off=(!IsAvsPlus)?0:FindStr(V,"(r") return (Off==0)?0:V.MidStr(Off+2).Value.Int } # Avs+ & Neo, (More than 4 digits, Max 24 bit, ~16M)
I personally ignore the Neo thing now.
I sometimes post sober.
Old 6th February 2022, 14:18   #887  |  Link
malze
I was wandering if there is a 64-bit verison of Srestore plugin or similar plugin of this.
malze is offline   Reply With Quote
Old 6th February 2022, 14:21   #888  |  Link
Boulder
Pig on the wing
Boulder's Avatar
real.finder has kept the function up-to-date.
https://forum.doom9.org/showthread.php?t=174121
Old 2nd August 2022, 13:31   #889  |  Link
Tlen
I have a double blended PAL DVD, that is blended on the semi-frame.
My idea was to try to remove the double blending doing a
SeparateFields
srestore
Then a Weave to reunite the deblended semi-frames.
But i'm not able to end up with a pure 50fps de-blended result.
Srestore seems just not kicking in.
Is that workflow possible?
Tlen is offline   Reply With Quote
Old 7th August 2022, 02:21   #890  |  Link
manono
Originally Posted by Tlen View Post
SeparateFields
srestore
Doesn't that by itself give you 23.976fps for a PAL source? If so, then SRestore is 'kicking in'. Why would you want 50fps?
manono is offline   Reply With Quote
Old 7th August 2022, 15:42   #891  |  Link
Tlen
Honestly, i was looping on the fact that i wanted to maintain the original 25.00 fps,
and srestore wasnt't giving me results (or i was not able to make it function in that way),
but thinking about it, the original frate it's not a strict requirement, so i can try with the 23.976 path too.
Thank you for the reply.
Old 28th September 2023, 22:52   #892  |  Link
tormento
Acid fr0g
tormento's Avatar
Perhaps I should have posted here this.
Long story short: 59.98i to 23.976p, one video badly resized and perhaps telecined, the other simply interlaced.
Can you find some good use for srestore in that case scenario?
@turment on Telegram
Old 11th October 2023, 03:24   #893  |  Link
fabioseixal
For the 1st clip, is this ok?
I had to resize because I have an old PC...
fabioseixal is offline   Reply With Quote
Old 11th October 2023, 04:02   #894  |  Link
kedautinh12
It's still dancy text
mrestore, srestore
