Old 21st August 2007, 23:26   #101  |  Link
dansus
I tried with the build you recommended, but wmv still not playable.
Also with this build, target size is off in Xvid. wanted 700mb, got 500mb.
Using 17a.
[wmv1 @ 00CAACE0]warning, clipping 1 dct coefficients to -255..2551946:128]
[wmv1 @ 00CAACE0]warning, clipping 1 dct coefficients to -255..2551947:128]
[wmv1 @ 00CAACE0]warning, clipping 1 dct coefficients to -255..2551950:128]
[wmv1 @ 00CAACE0]warning, clipping 1 dct coefficients to -255..2551951:128]
[wmv1 @ 00CAACE0]warning, clipping 1 dct coefficients to -255..2551953:128]
[wmv1 @ 00CAACE0]warning, clipping 1 dct coefficients to -255..2551954:127]
[wmv1 @ 00CAACE0]warning, clipping 1 dct coefficients to -255..2551884:127]
Pos: 642.3s  16062f (23%) 38.47fps Trem:  22min 663mb  A-V:0.025 [1885:127]
dansus is offline   Reply With Quote
Old 22nd August 2007, 00:32   #102  |  Link
TheRyuu
warpsharpened
It's normal.
Taken from the divx "why do I get undersized file" sticky (same applied to xvid though).
Once you get a file that is more than say 50MB under your target filesize, there's a very big chance the movie is 'maxed out'. This means that the codec has used every bit you gave it and has produced a file that is at the maximum quality, and therefor maximum filesize, and it just can't make it any bigger.
Sorry, I can't help you with your other problems though.
TheRyuu is offline   Reply With Quote
Old 22nd August 2007, 08:34   #103  |  Link
buzzqw
HDConvertToX author
@dansus
i tested the OSS build of mencoder with your dvr-ms files and IS broken
while on standard mpeg is working...
btw i have done an update http://www.64k.it/andres/data/a/AutoMen17b.exe
added possibility to add audio to huffy export
compatible with recent mencoder build, for wmv and flv removed "-lavfopts i_certify_that_my_video_stream_does_not_use_b_frames" options
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 22nd August 2007, 21:26   #104  |  Link
dansus
I gave 17b a go with mpeg, but the cmd box crashes instantly with OSS build.
With this build, it encodes but isnt playable.
Old 22nd August 2007, 21:42   #105  |  Link
buzzqw
HDConvertToX author
i suppose to wait for a more stable mencoder build
btw i am seriusly thinking about an FFmpeg gui.. but there are a lots of options..
don't know is better to add only the "most inportant" or all... and how handle over 500 switch in a gui...
BHH
Old 23rd August 2007, 01:19   #106  |  Link
dansus
Yeah, FF drives me nuts with all the settings.
Sometimes you just want a simple way, so maybe a gui with only the most important options would be the way to go. You can always add more later.
If wmv is working for you, it must be a prob my end. I will try to pin it down and let you know.
Would it be possible to get a 60sec mpeg clip that worked for you?
Old 30th August 2007, 08:23   #107  |  Link
blizard
Hi, Buzz!
Something doesn't work as it should when I use AutoMen. It breaks when I want to keep original size on capture I transcode from MPEG2 to AVC+AAC (MP4). It just write mp4.bat and stop.
It have worked to some degree before with autocrop 656, but then mp4create.exe doesn't work to re-mux into mp4 container. I took those part that I could use and put into YAMB instead and then let it create a new MP4 with both sound and video. That worked until now.
So I have two problem. Why doesn't mp4create.exe work as it should to demux and remux into container and why doesn't it work to keep original size work without any other action then to transcode work?
Bat file show every part for autocrop and re-size to be zero, so it must have to be something that doesn't respond well to keep those setting.
blizard is offline   Reply With Quote
Old 13th September 2007, 00:22   #108  |  Link
dansus
Buzz, ive got a C2Q now. Any chance i could get an 4 thread version on Xvid?
thanks.
Old 16th September 2007, 10:01   #109  |  Link
buzzqw
HDConvertToX author
@ALL
please update to latest mencoder build (OSS build) link in first post, is a lot more stable!
also the 1.7b is already multithread optimized, just check Thread
BHH
Old 18th September 2007, 20:56   #110  |  Link
EEPROM
EEPROM's Avatar
Hi Buzz',
with precedent build of mencoder; the cpu(Intel E6600) worked at 70 - 75 %; but with latest mencoder build (OSS build) the cpu worked as single core(50%).
In both cases, i've used AutoMen 1.7b
What happens?
Thanks for your job!!! and continuous development
sorry for my bad english
EEPROM is offline   Reply With Quote
Old 19th September 2007, 07:26   #111  |  Link
buzzqw
HDConvertToX author
autmen is just a gui that create and launch bat (make simplified...).
Is mencoder that do the hard work and use the cpu. I am sure that mp4 (x264) is multithreaded, but avi (xvid) not so much...
if you want more speed and cpu use i suggest to search and use a mencoder build optimized for speed and for your processor
the build of mencoder linked is not the fastest but the more stable
BHH
Old 19th September 2007, 12:08   #112  |  Link
EEPROM
EEPROM's Avatar
Ah, ok, thanks for the explanation.
But i don't see a specific build for Core2Duo, but only for P4 or another site for Pentium-M
Where i find a specific buid for my configuration?
Thanks a lot
Old 19th September 2007, 15:58   #113  |  Link
buzzqw
HDConvertToX author
well.. p4 build should be enough.. but if i found a c2d build.. i will tell you
BHH
Old 19th September 2007, 16:25   #114  |  Link
EEPROM
EEPROM's Avatar
no word, only "Grazie"....
Old 5th October 2007, 16:23   #115  |  Link
EEPROM
EEPROM's Avatar
a bug ?
I think i have found a bug:
When i set the resolution to:"Original Size" and press start, all the settings are respected to the final movie, but if i want to convert multiple files(QueueIT -> Start all Jobs!)strangely all files converted have as resolution 656 width.
It's a bug o what?
Thanks for future interesting!
P.S.
Core: 1.7b
Input File: .vob (single)
Codec: XviD
VidQuality: More Quality (10) = Less Speed 2Pass
AudQuality: Lame 128
Old 6th October 2007, 13:35   #116  |  Link
buzzqw
HDConvertToX author
thanks for the bug!
fixed!
http://www.64k.it/andres/data/a/AutoMen18.exe
BHH
Old 6th October 2007, 16:24   #117  |  Link
EEPROM
EEPROM's Avatar
Thanks to you!
Old 11th October 2007, 13:40   #118  |  Link
buzzqw
HDConvertToX author
added a full new package with latest mencoder (and mplayer)
AND working on multicore!
link in first post!
BHH
Old 11th October 2007, 18:05   #119  |  Link
weaver4
buzzqw: Like the program. Since I keep my files on a media center I don't really care about filesize. I would rather tell the software I want a fair/good/great/fantastic picture, set the width and let it run. Any way to do that?
weaver4 is offline   Reply With Quote
Old 11th October 2007, 19:43   #120  |  Link
buzzqw
HDConvertToX author
@weaver4
actually not.. you must use both final size and video quality sliders
i can think 4 more quality tick that work on quantitizer ...
i will check
BHH
automen, ffmpeg, handbrake, mencoder, x264
