Old 11th September 2010, 18:37   #181  |  Link
blubberbirne
I need Another Update Server.
Fresh Install of MeGui x64
Trying server: http://megui.org/auto/stable/
Retrieving update file from server...
Error: Couldn't connect to server.
Trying server: http://megui.xvidvideo.ru/auto/stable/
Error: Could not download XML file
Loading update data...
Error: Invalid XML file. Aborting.
EDIT: found the developer dir in setting.
blubberbirne is offline   Reply With Quote
Old 12th September 2010, 14:29   #182  |  Link
GRKNGLR
Originally Posted by Sharktooth View Post
no. except the fact all 32 bit apps have a 2 GB memory barrier.
some times, when using heavy filtering and/or HD sources avisynth may require more than 2 GB and that obviously makes avisynth 32 crash.
Thanks Sharktooth.
GRKNGLR is offline   Reply With Quote
Old 12th September 2010, 17:33   #183  |  Link
Whimick
Hello All,
I been having a play with MeGUI x64 and I get this error when I try to create a script:
Please see my Log below:
[Error] Log
-[Information] Versions
--[Information] MeGUI Version : 0.3.5.11 x64
--[Information] OS : Windows Vista Premium Edition x64 SP2 (6.0.131072.6002)
--[Information] Latest .Net Framework installed : 4.0 (4.0.30319)
--[Information] Avisynth Version : 2.5.8.5
-[Information] Log for job1 (idx, Sample.ts -> Sample.ts.d2v)
--[Information] [12/09/2010 17:22:28] Started handling job
--[Information] [12/09/2010 17:22:28] Preprocessing
--[Information] Job commandline: "C:\Program Files\MEGUI 64\tools\dgindex\dgindex.exe" -SD=< -AIF=<C:\TEMP\Sample.ts< -OF=<C:\Users\Michael\Videos\MeGUI\Sample.ts< -FO=0 -exit -hide -OM=1 -TN=0
--[Information] [12/09/2010 17:22:28] Indexing started
--[Information] Standard output stream
--[Information] Standard error stream
--[Information] [12/09/2010 17:22:48] Running auto force film
---[Information] Film percentage: -1
--[Information] [12/09/2010 17:22:48] Postprocessing
---[Information] Deleting intermediate files
----[Information] [12/09/2010 17:22:49] Successfully deleted C:\TEMP\Sample.ts.log
--[Information] [12/09/2010 17:22:49] Job completed
-[Error] Unhandled error
--[Information] Exception message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
--[Information] Stacktrace
---[NoImage] at MeGUI.AviSynthClip.dimzon_avs_getvframe(IntPtr avs, IntPtr buf, Int32 stride, Int32 frm)
---[NoImage] at MeGUI.AviSynthClip.ReadFrame(IntPtr addr, Int32 stride, Int32 frame)
---[NoImage] at MeGUI.AvsFile.AvsVideoReader.ReadFrameBitmap(Int32 position)
---[NoImage] at MeGUI.VideoPlayer.positionSlider_Scroll(Object sender, EventArgs e)
---[NoImage] at MeGUI.VideoPlayer.resize(Int32 targetWidth, Boolean PAR)
---[NoImage] at MeGUI.core.gui.StandardAndCustomComboBox.get_SelectedSCItem()
---[NoImage] at MeGUI.core.gui.StandardAndCustomComboBox.get_SelectedObject()
---[NoImage] at MeGUI.core.gui.ARChooser.get_Value()
---[NoImage] at MeGUI.VideoPlayer.get_DAR()
---[NoImage] at MeGUI.VideoEncodingComponent.player_Closed(Object sender, EventArgs e)
---[NoImage] at System.Windows.Forms.Form.OnClosed(EventArgs e)
---[NoImage] at System.Windows.Forms.Form.WmClose(Message& m)
---[NoImage] at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
---[NoImage] at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
--[Information] Inner exception: null
Can any one offer any advice.
Many Thanks
Whimick
Whimick is offline   Reply With Quote
Old 12th September 2010, 18:14   #184  |  Link
Zathor
Can you open the avs file in other tools like VirtualDub or MPC-HC?
Old 12th September 2010, 19:01   #185  |  Link
JoeH
How did you solve this? I am getting the same error.
JoeH is offline   Reply With Quote
Old 12th September 2010, 21:26   #186  |  Link
Zathor
In the settings (extra config\auto update) you have to switch to the development server. MeGUI x64 is not available as stable build because a lot of external tools/filters are missing/unstable.
EDIT: I updated the link in the first posting to point to a recent x64 build. This build will automatically switch to the development server for a new instalation.
Old 14th September 2010, 15:25   #187  |  Link
tormento
Acid fr0g
tormento's Avatar
megui 0.3.5.12_x64 nice crash
There must be something gone wrong with latest update. If I open the following script:
PHP Code:
LoadPlugin("D:\eseguibili\media\dgdecnv\x64 binaries\DGDecodeNV.dll")
DGSource("E:\in\1_47 2 fast 2 furious\2fast.dgi"
Megui_x64 shows:
Tried same script in VirtualDub_x64 and works. Tried to replace AviSynth with older version.
Same script works with x86 version (obviously different dll).
Ideas?
@turment on Telegram
Old 14th September 2010, 22:35   #188  |  Link
zanuda
zanuda's Avatar
error when try to open .mkv in file indexer
[Error] Log
--[Information] MeGUI Version : 0.3.5.12 x64
--[Information] OS : Windows Seven Ultimate Edition x64 (6.1.0.7600)
--[Information] Exception message: Была сделана попытка загрузить программу, имеющую неверный формат. (Исключение из HRESULT: 0x8007000B)
---[NoImage] в MediaInfoWrapper.MediaInfo.MediaInfo_New()
---[NoImage] в MediaInfoWrapper.MediaInfo..ctor(String path)
---[NoImage] в MeGUI.MediaInfoFile..ctor(String file)
---[NoImage] в MeGUI.FileIndexerWindow.openVideo(String fileName)
---[NoImage] в MeGUI.FileIndexerWindow.input_FileSelected(FileBar sender, FileBarEventArgs args)
---[NoImage] в MeGUI.FileBar.triggerEvent()
---[NoImage] в MeGUI.FileBar.setFilename(String filename)
---[NoImage] в System.Windows.Forms.Control.OnClick(EventArgs e)
---[NoImage] в System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
---[NoImage] в System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
---[NoImage] в System.Windows.Forms.Control.WndProc(Message& m)
---[NoImage] в System.Windows.Forms.ButtonBase.WndProc(Message& m)
---[NoImage] в System.Windows.Forms.Button.WndProc(Message& m)
---[NoImage] в System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
---[NoImage] в System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
zanuda is offline   Reply With Quote
Old 14th September 2010, 23:16   #189  |  Link
Zathor
Thanks for the reports. Please run the auto update and the problem should be fixed.
Old 15th September 2010, 01:05   #190  |  Link
vitali5000
mediainfo_0_7_35-2_x64 buged
vitali5000 is offline   Reply With Quote
Old 15th September 2010, 06:20   #191  |  Link
tormento
Acid fr0g
tormento's Avatar
Not working, same error I reported before.
Old 15th September 2010, 09:36   #192  |  Link
zanuda
zanuda's Avatar
works fine for me
Old 15th September 2010, 10:07   #193  |  Link
Zathor
It is working for me with this dll, too. I think we have to wait for the official build of mediainfo. I will revert it back to 0.7.35.
Old 15th September 2010, 10:20   #194  |  Link
vitali5000
Please, upload old working version 0.7.35. Thanks.
Old 15th September 2010, 10:38   #195  |  Link
Zathor
Yes, as said before. But at the moment I have no access to the server. Should be done in a few hours.
EDIT: done
Old 15th September 2010, 13:42   #196  |  Link
vitali5000
Error again (((
With MeGUI - 32 bit works fine.
Old 15th September 2010, 14:28   #197  |  Link
Zathor
Close MeGUI and then replace mediainfo.dll with another one from here:
http://megui.org/auto (files beginning with mediainfo and ending with x64.zip)
Report back which one fixes the problem.
Old 15th September 2010, 15:10   #198  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
zathor, it could be a build problem since there 32bit version works as expected.
ill ask in the mediainfo thread.
Sharktooth is offline   Reply With Quote
Old 15th September 2010, 17:19   #199  |  Link
vitali5000
Originally Posted by vitali5000 View Post
Error again (((
It is a problem when I try to make resize with 1920x1080 to 720x400, there was no such problem earlier.
With 32 bit version resize to720x400 works fine.
Old 15th September 2010, 18:54   #200  |  Link
tormento
Acid fr0g
tormento's Avatar
Works ok for me now (x64, I mean).
Thanks..
