Old 26th February 2018, 20:42   #401  |  Link
sneaker_ger
ffms2 added AviSynth+ high bitdepth support in version 2.23.1 (Oct 2016).
Old 26th February 2018, 20:51   #402  |  Link
Gser
Well the ffms2 script works fine when I play it in mpc but fails to load in MeGui. *sigh*
FFVideoSource("file.ts", fpsnum=60000, fpsden=1001, threads=8, colorspace = "YUV420P10")
Error parsing media file video.avs: ConvertToRGB24: conversion is allowed only from 8 bit colorspace
Gser is offline   Reply With Quote
Old 26th February 2018, 20:58   #403  |  Link
sneaker_ger
That's a MeGUI problem, not ffms2.
Old 26th February 2018, 20:59   #404  |  Link
Gser
Yeah I figured as much, seems it doesn't support 16-bit either. I'll just resort to converting everything to stacked format at the end of scripts.
Old 2nd March 2018, 18:03   #405  |  Link
Carpo
Carpo's Avatar
Anyone having the issue that when you press Queue it starts the encode, not queuing it?
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline   Reply With Quote
Old 3rd March 2018, 12:07   #406  |  Link
Zathor
Do you have by any chance enabled the "start new jobs in queue immediately" option?
Sadly true, the AVS wrapper cannot handle > 8 bit.
Old 3rd March 2018, 12:09   #407  |  Link
Carpo
Carpo's Avatar
D'oh!!!!! Forgot about that setting, I have it off in 32bit version, all good now
Old 15th March 2018, 09:11   #408  |  Link
robojock
Presets not working with latest version of Megui
I don't know what the issue is, i import these profiles and if i try to edit them i get this error. Also when i do a conversion I get files less than 100mb.
robojock is offline   Reply With Quote
Old 15th March 2018, 11:18   #409  |  Link
sneaker_ger
Did you read the red warning at the top? Those profiles are deprecated.
Old 15th March 2018, 11:45   #410  |  Link
robojock
No i did not read the warning on top. I have now, the last post edit was in 2012. I still used Megui last year (2017) with those profiles. With version 2828 if i start from fresh those profiles don't work, they give the error as shown in my previous post. If i go back to the previous version of megui 2808 and import the profiles then they work. Updating from 2808 to 2828 with the profiles imported then they work with 2828
Old 15th March 2018, 12:27   #411  |  Link
marcus100868
MeGUI
Hi to all,
I have got a problem when using HD Streams Extractor all of a sudden no ticking options in stream(s) can't choose subs,audio,chapters,video.
https://gyazo.com/56323deda8c92519e9e3db01a4240113
This all happened when new updates where available.
No matter if i use older version or the latest no ticking options.
Some help would be much appriciated.
marcus100868 is offline   Reply With Quote
Old 16th March 2018, 19:26   #412  |  Link
Zathor
Please post a log - especially I would need the "Versions" part.
Old 16th March 2018, 23:10   #413  |  Link
marcus100868
MeGUI
Hi Zathor,
Let me know if this is the right Log?
[Information] Log
-[Information] Versions
--[Information] MeGUI: 2828 x86
--[Information] Update Check: Disabled
--[Information] System Information
---[Information] Operating System: Windows Server 2016 Standard 1607 x64 (10.0.14393.2125)
---[Information] .NET Framework: 4.0 (4.0.0.0)
---[Information] .NET Framework: 4.6.x (4.6.01586)
---[Information] DPI: 150% (144/144)
---[Information] Monitor 1
----[Information] Resolution: 3840x2160
----[Information] Primary Screen: True
--[Information] Component Information
---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
---[Information] Haali DSS2: (14-04-2013)
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
---[Information] MediaInfo: 17.12.0.0 (21-12-2017)
---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
---[Information] 7z: 9.20 (18-11-2010)
--[Information] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2721.0
----[Information] Date: 29-04-2017
----[Information] Interface: 3
----[Information] File Version: 2.6.0.6
----[Information] Date: 31-03-2015
----[Information] Name: Avisynth 2.6
----[Information] Version: AviSynth 2.60, build:Mar 31 2015 [16:38:54]
----[Information] AviSynth+: false
----[Information] MT: false
----[Information] Status: inactive
---[Information] AviSynth portable
----[Information] File Version: 0.1
----[Information] Date: 27-12-2017
----[Information] Name: AviSynth+ 0.1 (r2580, MT, i386)
----[Information] Status: active
Old 16th March 2018, 23:24   #414  |  Link
marcus100868
MeGUI
This only happens on my server with the home PC it's fine don't know if this helps.
Old 25th March 2018, 16:01   #415  |  Link
Zathor
Please extract this file into your MeGUI directory on the server (replace the existing file) and report back.
EDIT: update to MeGUI 2829
Old 27th March 2018, 18:56   #416  |  Link
tormento
Acid fr0g
tormento's Avatar
@Zathor
I am currently having problems processing eac3 files with integrated audio encoder. It stays on indexing without doing absolutely nothing.
I have replaced it with command line transcoding, such as
ffmpeg.exe -i in.eac3 -acodec ac3 -ab 640k -af dynaudnorm out.ac3
and it is ok for 5.1 to 5.1 transcoding. I have absolutely no idea of what channel to mix for a 7.1 to 5.1 transcoding, with proper levels.
Can you please tell me which is the ffmpeg profile used from MeGUI when transcoding with ffmpeg from 7.1 to 5.1 or, much better, fix eac3 problem?
@turment on Telegram
Old 27th March 2018, 20:24   #417  |  Link
Zathor
It "should" work. Could you upload please a small test sample?
Old 27th March 2018, 21:28   #418  |  Link
tormento
Acid fr0g
tormento's Avatar
If you tell me how to "cut" eac3, otherwise I need to upload the whole track. If you have a ftp or private cloud much better because of size.
Anyway, in the mean time, can you please tell me the mixing levels you apply in MeGUI when transcoding to inferior number of channels?
Old 27th March 2018, 21:30   #419  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by tormento View Post
...and it is ok for 5.1 to 5.1 transcoding. I have absolutely no idea of what channel to mix for a 7.1 to 5.1 transcoding, with proper levels.
ffmpeg don't downmix eac3 7.1 because can't decode it to 7.1 channels.
ffmpeg only decode 5.1 channels from eac3 7.1, the extra surround channels (in added substreams) are ignored.
Old 27th March 2018, 21:35   #420  |  Link
tebasuna51
tebasuna51's Avatar
...can you please tell me the mixing levels you apply in MeGUI when transcoding to inferior number of channels?
Check the log.
You can see the avs scripts with the downmix levels.
