27th May 2020, 17:52 | #1021 | Link |
@Janusz: nOCR training + ,.- should be improved here: https://github.com/SubtitleEdit/subt...leEditBeta.zip
@tormento: SE already runs 64-bit if you have a 64-bit OS. Normally 64-bit programs run a little slower... Latest beta now does fallback to "Latin.nocr" (nOCR) from "Binary image compare" db "Latin.db". Included large (auto-trained) "Latin.nocr" db in beta. |
28th May 2020, 01:14 | #1022 | Link | |
nOCR Training works much better. In the sentence: "The quick brown fox jumps over the Iazy do*." there are only 2 errors. "l" was read as "I" and no "g". It is poor with punctuation marks. In testing the same files that I sent, I am unable to determine the source of the character swap compared to beta 145. In any case, beta 168 compared to beta 145 recognizes characters created in the new nOCR training much better.
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 28th May 2020 at 09:50. |
28th May 2020, 09:33 | #1023 | Link |
Acid fr0g
The only x64 part I can see is the Hunspell spell checker. Main exe is x86, tesseract (both) are x86. What part of your app runs in x64?
That is a very questionable statement. All the x64 programs I use are definitely faster.
@turment on Telegram |
28th May 2020, 14:23 | #1025 | Link |
I'm guessing you talk about .srt subtitles?
Subtitle Edit Code:
Tool -> Batch convert -> Change framerate https://www.videohelp.com/software/S...merate-changer It's no longer developed so I have no idea if it works for you. Tried a few subtitles and it seems to work... Best regards varekai |
28th May 2020, 15:52 | #1026 | Link | |
Also can Batch convert be used to add delays? Last edited by ACKR; 29th May 2020 at 10:17. |
30th May 2020, 14:53 | #1029 | Link |
@tormento: SubtitleEdit.exe (all the C# code) runs 64-bit on 64-bit OS (check task manager, there should be no "(32-bit)" after the name). I've not actually tested SE 32-bit vs SE 64-bit performance... at least you have more memory with 64-bit programs.
Tesseract exe runs 32-bit (the 32-bit tesseract is faster than the 64-bit tesseract - well tested) @18fps: >When correcting capitalization of all caps subtitles, it would be of great help if the program could read the names of characters from the imdb page of the film (the user would give the http addresss) Actually not a bad idea... but there seems to a lot of "Cute Girl" and "Prison Guard" which I guess would make this hard. Ideas? @Janusz: The nOCR (line ocr) works best with larger subtitles, like from bluray sup files, so go for "Binary image compare" with small subtitles or even Tesseract 5. nOCR is still missing a lot of work - latest beta has added "fallback to nOCR" from "Binary image compare" which I think will work nicely. Also added a "Max bad pixels" for nOCR (based on not matching pixels from lines). The nOCR auto-training now calculates correct top margin (I hope) which was also missing in the normal OCR run (so all existing nOCR dbs will work less well). Also fixed in training: quote + percentage sign. Missing in training: combined letters like "ff" and "rt" are not working. Many changes has been made regarding OCR (mostly nOCR): https://github.com/SubtitleEdit/subt...leEditBeta.zip Last edited by Nikse555; 30th May 2020 at 19:43. |
30th May 2020, 20:57 | #1030 | Link | |
Attempt on _index.html file with "Batman Begins". The character base created only for the first two lines for each new unrecognized character consists of 17 characters: ! , ? a c e h k l o p P R s t z ż OCR was stopped at "n" on the third line. As you can see, a small "z" instead of "Z" appeared in the third line. We can repeatedly start OCR from the first line, each time OCR will stop at "n". Character Database content does not change. However, if, for example, on the first line we call "Inspect nocr matches for ..." the "nOCR inspekt" window opens and click in the "Inspect items" box, then select OK or Cancel to close the window without any changes. Reopening this window will show us that "ż" was assigned to "Ż" although we did not. These changes are now saved permanently. Another OCR will show us that "ż" on lines 1 and 2 has been replaced with "Ż" and "z" on "Z" on line 3. The re-OCR is again calling for "ż". If you need pictures I can attach. ----- Beta 145 doesn't have this problem. It started with beta 161. I could check this version. I wrote about beta 168 earlier, but at that time I didn't know where to look for the cause.
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 30th May 2020 at 23:50. |
30th May 2020, 21:23 | #1031 | Link | |
Sent from my SM-G986U1 using Tapatalk |
30th May 2020, 21:49 | #1032 | Link | |
The program cannot change the image assignment to a character by itself. If you have once determined that "a" is "a", then where suddenly "a" is "A". ----- Please explain to me what "in the settings" setting causes such a change. The left side, although the subtitles look strange, is correct. Sup and nocr files to download. The first OCR call will be OK. Second and subsequent OCRs on the same file will replace. ----- Everything indicates that the problem concerns only the Polish language, so it went unnoticed by other users.
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 31st May 2020 at 09:37. |
31st May 2020, 10:31 | #1033 | Link | |
31st May 2020, 20:47 | #1034 | Link |
@Janusz: Yes, nOCR is not finished yet... in SE 3.5.15 it was probably about 60% done, and now it's about 85% done.
I was close to giving up on it, but after a few fixes in auto-traning it's actually working very well (besides words that are stuck together like "rw", "ff" etc... - it's on my todo list + also italic font might be a problem). I've fixed the OCR inspect in latest beta and also added some code for correcting casing Polish letters... do let me know how that works: https://github.com/SubtitleEdit/subt...leEditBeta.zip @18fps: OK, I might give it a try. |
1st June 2020, 09:28 | #1035 | Link |
@Nikse555:
It is certainly good for characters without accents: a b c ... A B C ... It is not bad for lowercase letters with an accent: é č ę ė š ž ü å ä ö ą ś ż ś ... Unfortunately, capital letters with accent: polish: Ś Ó Ż Ź Ć, spanish, portuguese, czech are recognized as two separate signs: accent and capital letter. This cannot be improved by "Add better match ...". This does not apply to German. Here Ü Ä Ö is recognized as one character. Until the problem with single characters is solved, you can forgive yourself "besides words that are stuck together like "rw","ff"etc .."
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 1st June 2020 at 10:56. |
1st June 2020, 11:09 | #1036 | Link | ||
https://github.com/SubtitleEdit/subt...leEditBeta.zip |
1st June 2020, 11:48 | #1037 | Link |
@Nikse
File to download: Because there was a problem with capital letters with accents, e.g. Ś, Ć, Ó, Ř, Í, Š, É etc. I prepared a text consisting of sentences containing all letters used in such languages: English, Polish, German, Spanish and Czech . If we compare the line marked in blue on the right side, we will notice that between upper case letters lower case letters hide, but not everywhere. There is "Ó" which has not been replaced with "ó" or "Ń" and several others. Other capital letters also contain substitutions of this type. The exception is English, for obvious reasons - there are no letters with accent. During the OCR I did not make any corrections, I did not add any characters manually. In both cases: beta 145 and beta 187, the text in the form we see has been fully read by the character base created by nOCR Training beta 187. Comparing pages line by line, you can see how much progress has been made since beta 145. ----- 02.06 Why some characters, e.g. Czech Ř, Ď, Á ... are remembered as one character, while others, e.g. Polish Ó, Ż, Ź as letters O, Z with an accent. WARNING! Characters memorized in the character database as "." "´", I think they can be edited, but they cannot be deleted in any way because deletion causes our character base to crash. Removal would be possible, but then all associated characters should also be removed from the database. ----- I will return to _index.html file with "Batman Begins" with the character base attached. If we start ORC with the [Draw missing text] option enabled, the program will ask for "." or "," in the middle or at the end of a sentence. We can add, it will be good. When in line 74 we are asked not to add "Ż" but to "." located above "Z" and we will add it - our character base will crash. From now on, all "-" in the dialogs at the beginning of the line will be replaced with "." If we run OCR from the beginning from the first line without recognizing new characters, it will turn out that all "-" at the beginning of the line will be changed to ".". An additional gift will be exchanging ś into Ś and vice versa, z into Z. Long to exchange. I don't know what it looks like in other languages with uppercase letters in indexes - I don't have the right files, but for single letters it works the same way. ----- I can already see good changes in beta 193. Keep it up. Good job. Thank you.
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 2nd June 2020 at 12:27. |
1st June 2020, 18:12 | #1038 | Link |
I received the message as below. My .nocr file is created from scratch.
https://i.imgur.com/4TJc4kQ.png |
2nd June 2020, 15:07 | #1039 | Link |
@Melan: Should hopefully be fixed in latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip
@Janusz: thx for the test file - good idea I see the problem with batman begins and "Ż" - but that's about line splitting (also happens in "Binary image compare") >deletion causes our character base to crash. Does this still happen? |
