Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 31st May 2020, 15:08   #421  |  Link
Klownicle
Not good to put your e mail out in the open like that
Hope you don't get spammed that much
Doing it from my phone, couldn't easily post a screenshot of the email. But I planned on removing it. Thanks for the care!
Klownicle is offline   Reply With Quote
Old 22nd June 2020, 18:17   #422  |  Link
arrgh
download link for the latest MVC test build not working
arrgh is offline   Reply With Quote
Old 22nd June 2020, 18:53   #423  |  Link
videoh
Useful n00b
Fixed. Thank you.
Old 22nd June 2020, 23:00   #424  |  Link
arrgh
...ok, first of all, I’m happy that there is progress in respect of 3D! after all, nowadays it is not so “cool” anymore, as it was a few years ago…
…a quick test...:
the demuxing seems to work ok; I get a *.264 and a *.mvc stream; the *.264 is playable.
Tsmuxer (the version I have) is unfortunately not able to create a (in MPC-BE) correct working m2ts file : I get blocking;
But an Iso seems to work…
The trouble is that MKVToolnix can’t read MVC files. So, no direct muxing into mkv…
It would be super, if the video streams would be output in a way which mkvmerge.exe can read directly (without the need to create an m2ts or iso), like it is the case with MakeMKV files…
Thanks!
Old 6th July 2020, 10:06   #425  |  Link
ChaosKing
I just noticed that "episode demuxing" is already implemented
Tested with DGDemux 1.0.0.30
First test looks good. Video and audio are split correctly per episode.
Chapters have some issues: The chapter file of episode 1-2 contains chapters of every episode (ep 1-3). For EP 3 all chapters are just 00:00:00.000
You can see it with the sample BD I send you before.
(One ep has a duration of ~23min )
Just in case, here is a bdinfo report https://pastebin.com/raw/XH4DxiaC
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 23rd July 2020, 17:06   #426  |  Link
videoh
Useful n00b
Please try slipstream 33. Chapters for episode demuxing should be fixed.
Old 20th August 2020, 10:50   #427  |  Link
tebasuna51
tebasuna51's Avatar
Deleted a few off topic posts.
Old 20th August 2020, 11:16   #428  |  Link
ChaosKing
Somehow I missed that post.
I tried 38 but it looks like Episode demuxing does not work at all in this version. Nothing is split and it looks like the program can't decide if its done or not. The progressbar animation does not stop. Demux button is disabled, no finish sound.
It's the same BD that worked before.
Old 20th August 2020, 11:20   #429  |  Link
videoh
Useful n00b
I'll check it. Recent changes to other things may have had an adverse effect on it. Thank you for the report. I'll report back later today.
Old 20th August 2020, 11:52   #430  |  Link
videoh
Useful n00b
Yeah I broke it when I changed the name prefix for the demuxed files. I'll fix it today and notify you here.
Old 20th August 2020, 13:54   #431  |  Link
videoh
Useful n00b
Please re-download and test build 38.
Old 20th August 2020, 14:46   #432  |  Link
ChaosKing
Tested multiple BDs, all good now. Chapters are also ok. Great work as always!
Old 20th August 2020, 15:16   #433  |  Link
videoh
Useful n00b
Great to hear and thank you for your testing, ChaosKing! There was a further update to fix a SUP regression, so you may need to re-download 38 one more time.
Old 23rd August 2020, 23:28   #434  |  Link
arrgh
two small errors in the newes version of .38:
I'm not using the GUI, therefore I realized this late. There is an error in the cli-command-creation which crashes the process:
the second one is in the creation of the tag-file with 3D-discs which holds the 3D-plane:
in the very first line it should be "utf-8" instead of "utf - 8"; the second provokes some warnings by mkvtoolnix...:
<?xml version="1.0" encoding="utf-8"?>
not
<?xml version="1.0" encoding="utf - 8"?>
best Regards
Old 24th August 2020, 15:13   #435  |  Link
videoh
Useful n00b
Fixed in slipstream 39. Thank you for your report.
Old 28th August 2020, 07:37   #436  |  Link
von Suppé
von Suppé's Avatar
@ videoh,
Would it be possible if short playlists can be imported also? I have this demonstration disc with (short) Dolby Atmos trailers I wanna throw at DGDemux.
Old 28th August 2020, 09:39   #437  |  Link
tebasuna51
tebasuna51's Avatar
@von Suppé
You always can use the command line DgDemux.exe to extract the desired *.mpls, like is documented in DGDemux.txt:
DGDemux.exe -i "H:\Rips\CARS 2\BDMV\PLAYLIST\00800.mpls" -o "d:\tmp\CARS 2\00800"
Old 28th August 2020, 14:00   #438  |  Link
videoh
Useful n00b
How short is it time-wise?
Old 29th August 2020, 02:18   #439  |  Link
videoh
Useful n00b
OK, I'll add a "show all MPLS files" option for the GUI.
Old 29th August 2020, 06:34   #440  |  Link
von Suppé
von Suppé's Avatar
Thanks both tebasuna51 and videoh.
Shortest clip is like 32 seconds.
