Old 31st January 2017, 03:10   #2941  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Thanks. Is there an updated version of SMDegrain script that uses the new MVTools or not yet?
MysteryX is offline
Old 31st January 2017, 03:14   #2942  |  Link
Reel.Deel
Don't know, ask Dogway on VideoHelp. If you want the hacks-upon-hacks-mod-of-a-mod version check with real.finder .
Reel.Deel is offline
Old 31st January 2017, 03:43   #2943  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I have this line of code for which I want to add 16-bit support with Y16, YUV420P16, YUV444P16, RGB48 and RGB64.
sourceFormat = FormatOut != "" ? FormatOut : IsY8 ? "Y8" : IsYV12 ? "YV12" : IsYV24 ? "YV24" : IsRGB24 ? "RGB24" : IsRGB32 ? "RGB32" : ""
How can I know whether the clip is 8 bit or 16 bit from the script? Is there a way to write it in a way that will still work under AviSynth 2.6?
MysteryX is offline
Old 31st January 2017, 04:16   #2944  |  Link
real.finder
my mod work and use last mvtools, but all prefilter not yet work with > 8 bit, with tv_range=false and prefilter=-1 or prefilter=external clip it should work now
See My Avisynth Stuff
real.finder is offline
Old 31st January 2017, 04:26   #2945  |  Link
real.finder
most hack done in YUY2 and that nothing to do with new color format
all filter that needed in SMDegrain work with yv16 now, so there is no need for YUY2 in avs 2.6 (Except for contrasharp > 0.0 cuz it use LSFmod), smart users will covert to yv16 if they have YUY2 source
Old 31st January 2017, 05:05   #2946  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Oups what I wanted to ask is "that uses native 16-bit in/out instead of Stack16"
MysteryX is offline
Old 31st January 2017, 05:29   #2947  |  Link
real.finder
in most cases, script functions support depends on plugins supports, lsb is still there in new mvtools, you can use what you want whether old lsb hack or native (but not both), native > 8 support incompatible with lsb things, there are functions in new avs+ that convert native > 8 from/to lsb but I don't want to did this hack in SMDegrain, but anyone can use these functions like this
10 bit source
prefilter=ConvertBits(16).ConvertToStacked().SMDegrain_prefilters(prefilter=3,lsb_in=true).ConvertFromStacked(16).ConvertBits(10) #or prefilter=4
SMDegrain(tv_range=false, prefilter=prefilter) #don't use contrasharp cuz there is no native > 8 support
Old 31st January 2017, 06:09   #2948  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I'm not interested in 10-bit sources... just looking at whether I can drop LSB stuff and use native 16-bit instead. Question is: the filters used by SMDegrain that were using LSB, do they now support native 16-bit? MVTools does.
MysteryX is offline
Old 31st January 2017, 06:19   #2949  |  Link
real.finder
then
prefilter=ConvertToStacked().SMDegrain_prefilters(prefilter=3,lsb_in=true).ConvertFromStacked(16) #or prefilter=4
in this case, as I already said, you can't use prefilter or tv_range=true or contrasharp cuz there is no native 16 bit for all plugins that used in SMDegrain
Old 31st January 2017, 07:00   #2950  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Native 16-bit will provide great performance improvement over LSB, especially for a heavy script like SMDegrain. However, it's kind of pointless until enough plugins support 16-bit to actually use it.
How about producing a list of filters supporting LSB that don't support the new native formats? Since they already work with high-bit-depth, I'm supposing it wouldn't be too hard to update those.
MysteryX is offline
Old 31st January 2017, 09:07   #2951  |  Link
pinterf
Originally Posted by ajp_anton View Post
Using "averageluma", 128 is converted to 0.501961 (128/255).
Using "yplanemax"/"-min", 128 is converted to 32896 (is this a bug? should be a float number, not a 16bit int)
Yes, it was fixed recently, perhaps after v2397. MinMax-like conditional functions (Min, Max, MinMaxDifference and Median) were done at the very beginning and could not decide that the return value should be the old integer or can be float (always the compatibility in mind). Then recently it was changed to float.
Conditional runtime functions have 10-16 bit/float support for YUV, PlanarRGB and 16 bit packed RGB formats.
Since RGB is also available as a planar colorspace, the plane statistics functions logically were expanded.
New functions
• AverageR, AverageG AverageB like AverageLuma
• RDifference, GDifference, BDifference like LumaDifference(clip1, clip2)
• RDifferenceFromPrevious, GDifferenceFromPrevious, BDifferenceFromPrevious
• RDifferenceToNext, GDifferenceToNext, BDifferenceToNext
• RPlaneMin, GPlaneMin BPlaneMin like YPlaneMin(clip [, float threshold = 0, int offset = 0])
• RPlaneMax, GPlaneMax BPlaneMax like YPlaneMax(clip [, float threshold = 0, int offset = 0])
• RPlaneMinMaxDifference, GPlaneMinMaxDifference BPlaneMinMaxDifference like YPlaneMinMaxDifference(clip [, float threshold = 0, int offset = 0])
• RPlaneMedian, GPlaneMedian, BPlaneMedian like YPlaneMedian(clip [, int offset = 0])
For float colorspaces the Min, Max, MinMaxDifference and Median functions populate pixel counts for the internal statistics at a 16 bit resolution internally.
pinterf is offline
Old 31st January 2017, 16:23   #2952  |  Link
Khanattila
Khanattila's Avatar
Packed RGB
8 bits: RGB24, RGB32 (BGR and BGRA internally)
16 bits: RGB48, RGB64
Check: IsRGB ; note: IsRGB now true for planar RGB(A) color spaces.
Check2: IsRGB24, IsRGB32, IsRGB48, IsRGB64
I'm working on adding new formats to my program and I need a clarification.
Packed RGB64 is BGRA internally?
github.com
Khanattila is offline
Old 31st January 2017, 16:41   #2953  |  Link
pinterf
Originally Posted by Khanattila View Post
Packed RGB
Yes, same as RGB32 and the same upside down order.
pinterf is offline
Old 31st January 2017, 16:47   #2954  |  Link
Khanattila
Khanattila's Avatar
Perfect, I will not have problems.
github.com
Old 31st January 2017, 17:12   #2955  |  Link
poodle
The original blending formula is something like that, where an ideal mask is 0..1.0:
new_value = orig*(1-mask) + overlay*mask
This is equivalent to (only one multiplication, faster):
new_value = orig+(overlay-orig)*mask
As mask is coming from a clip, its value is 0..255
The approximation in overlay core:
new_value = ((orig * 256 + 128)+(overlay-orig)*mask) / 256
When orig=255, overlay=0, mask=255 (overlay is fully visible), we would expect 0 (=overlay)
Unfortunately the approximation above results in:
new_value = ((orig * 256 + 128)+(overlay-orig)*mask) / 256:
(255*256+128) + (0-255)*255) / 256 = 383/256 =
(65408 - 65025) / 256 =
383/256 = 1
which is obviously incorrect
For orig=0, overlay=255, mask=255 the result is 254 instead of 255.
Hi.
I encountered similar problem.
Chroma is offset signed value, then these asymmetric conversion brings to color shift.
In order to cope with this problem, I wrote the following codes.
u = _mm_sub_epi16(u, offsetUV);
sign = _mm_cmpgt_epi16(zero, u);
u = _mm_sub_epi16(_mm_xor_si128(u, sign), sign); // abs(u)
process U
u = _mm_sub_epi16(_mm_xor_si128(u, sign), sign); // if (sign) neg(u)
u = _mm_add_epi16(u, offsetUV);
It is complex than madd.
poodle is offline
Old 2nd February 2017, 16:50   #2956  |  Link
pinterf
I decided to make a release, I hope this version is much better than the previous one, it is quite a few months since v2294 was released. Sure, it has a wider feature set than the ROM routines of a ZX81, which I started programming on.
Avisynth Plus v2420
Report bugs, regressions, wish-list as always.
!!! There is a long readme.txt in the packet which contains detailed informations on the new and changed functions, fixes and hints. Formatting is not that nice, but at least there is some doc (sort of).
Changelog since last dev release (v2397):
- CombinePlanes:
    When there is only one input clip, zero-cost BitBlt-less subframes are used, which is much faster.
    e.g.: casting YUV to RGB, shuffle RGBA to ABGR, U to Y, etc..
    Target planes that are not specified, preserve their content.
    Examples:
    CombinePlanes(clipRGBP, planes="RGB",source_planes="BGR") # swap R and B
    CombinePlanes(clipYUV, planes="GBRA",source_planes="YUVA",pixel_type="RGBAP8") # cast YUVA to planar RGBA
    CombinePlanes(clipYUV, planes="Y",source_planes="U",pixel_type="Y8") # extract U
- fix: SubframePlanarA (available in IScriptEnvironment2)
- faster: Difference-type conditional functions: Simd for 10-16 bits
- Fix: MinMax-type conditional functions (min, max, median): return float value for float clips
- ConvertToPlanarRGB(A):
    PlanarRGB <-> PlanarRGBA is now allowed
    YUY2 source is now allowed (through automatic ConvertToRGB proxy)
- faster: RemoveAlphaPlane (subframe instead of BitBlt copy)
- Overlay: "Blend" native greyscale mode: process y plane only w/o conversion
- Overlay: automatic use444=false for "blend"/"luma"/"chroma"
    for inputs: 420/422/444 and any RGB, lossless Planar RGB intermediate for PackedRGB
    Overlay/mask auto-follows input clip format.
    For compatibility: when greymask=true (default) and mask is RGB then mask source is the B channel
- faster: RGB48->RGB64 SSSE3 (1,6x), RGB64->RGB48 SSSE3 (1.5x speed)
- faster: RGB24,RGB48->PlanarRGB: uses RGB32/64 intermediate clip
- Histogram "levels": allow RGB24/32/48/64 input.
    Display R, G and B channels instead of Y, U and V
    Reminder 1: "levels" for Planar RGB was working already
    Reminder 2: Histogram "levels" and "Classic" allows bits=xx parameter, xx=8..12
                If "bits" is specified then Histogram is drawn with 9..12 bits precision. Get a wide monitor though :)
pinterf is offline
Old 2nd February 2017, 23:22   #2957  |  Link
ajp_anton
ajp_anton's Avatar
Small feature request: In histogram, add some parameter to show the histogram itself in a higher bitdepth. Even a histogram of an 8-bit video can benefit from being able to display the data more accurately. Probably has to convert the whole clip into a higher bitdepth in the process, unless you add another bool parameter (default false) to only return the histogram part and make it faster. Only returning the histogram would also help with those ultra-wide histograms that you can crop and stretch more easily, without having to crop away the video part first.
ajp_anton is offline
Old 3rd February 2017, 02:41   #2958  |  Link
real.finder
lsb in SMDegrain is not full 16 bit, it's done in MDegrain and some prefilters only, even MDegrain is not full cuz there are no lsb_in in MDegrain, dogway use some dither tools functions to do the lsb_in support in crooked ways
but anyway, since pinterf promise to work on masktools2 you can try port Dfttest, it's work in float internally too so I think it's not hard to you
Old 3rd February 2017, 09:54   #2959  |  Link
mp3dom
Regarding histogram levels, I don't know if there are already plugins that do that, but it could be helpful to have the min and max value of each channel written down. Sometimes there are videos with some levels off that needs to be "shifted" (especially the old ones) and having the min/max value can be useful to shift with more precision.
mp3dom is offline
Old 3rd February 2017, 10:26   #2960  |  Link
One may use WriteFile to log a CSV with strings concatenated from Color plane median, min, max, range function results.
LigH is offline
