#242 | Link |
Update:
Instead of mrestore, Cdeblend, FixBlendIVTC and DupHq there is only one function now: srestore. The detection has been improved, the memory usage has been decreased and the usage should be a bit easier. Just test this function. Important: - mrestore 2.31 has a big bug and has been removed from the R_pack - AviSynth 2.5.8 change the calculation of changefps (round to floor). I will adapt srestore when the new AviSynth version gets final. So, if you have problems with mrestore 2.31 or AviSynth 2.5.8 then test srestore with 2.5.7 @thetoof Not sure what you really want. I could add a parameter for an alternative clip that is allways used if a blend is detected. or do it this way: line 123: output.trim(0,1) ++ output.trim(2+current,0) to something like this: current==0 ? output : output.loop(3,0,0).trim(2+current,0).YourFilter(YourSettings) Would be the same for srestore. If I wasnīt clear enough just ask. Edit: @Amrit I used srestore with default settings on your source and donīt get any dups that aren`t in the source. @vwpassion Same here: Use your favourit bobber and srestore with default settings. @all If your problem is still not solved, please post it again. I donīt know anymore what problems are left. Last edited by MOmonster; 21st September 2008 at 19:54. |
#244 | Link |
Fighting spam with a fish
Yes!! Thanks for your hard work MOmonster!!! Your script is really pretty amazing, and I use it too often. (grrr, bad sources = pure evil). This new single script will sure streamline alot of things, and I am sure it will make thetoof's life easier as well (as I use his script a bit as well).
#248 | Link |
@MOmonster: Thank you very much for this script! I've only just started using it but already getting very impressive results out of it. Well done! I think you've finally put ol' RePal out to pasture with this one.
#250 | Link |
Sleepy overworked fellow
Wow, great job!
Actually, after doing some thinking, my request has changed a bit: could you add an argument that'd make srestore output a bool instead of a clip? Something like bool "boolout" that would return true on blends and false on other frames (I'll use scriptclip). With this, I think I'll be able to get closer to what I'm trying to achieve.
AnimeIVTC() - v2.00 -http://boinc.berkeley.edu/- Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p) Last edited by thetoof; 2nd October 2008 at 16:16. Reason: typo |
#252 | Link |
Thanks!
Another way of doing it that'd be convenient: a separate boolean function isblended() in srestore.avs
AnimeIVTC() - v2.00 -http://boinc.berkeley.edu/- Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p) |
#253 | Link |
Update
I uploaded srestore v2.65. These are some of the changes: - AviSynth 2.58 kompatibility - light speed up - reduced code - new parameters: speed, thresh, pthresh, pclip - better dup functionality @thetoof I don`t like the idea of calling a function that use the frame evaluation inside scriptclip. You can use this function as base. Rename it and add your own code: Code:
function bcalc(clip source, float "speed", float "blocks", float "thresh", bool "chroma", int "cache", clip "dclip") { ###### parameters & other necessary vars ###### rad = isfloat(speed) && speed>=1 ? sqrt(speed)*16 : 48 cache = default(cache,-1) bsize = isfloat(blocks) && blocks>=1 ? sqrt(blocks)*4 : 16 global thrx = abs(default(thresh,22))*0.1 global bfacx = sqrt(bsize*0.25)*0.54 ###### lut & more ###### detx = default(dclip,source).killaudio().converttoyv12() detx = detx.pointresize(int(width(detx)/rad+1)*16, int(height(detx)/rad+1)*16) detx = default(chroma,false) ? stackvertical(stackhorizontal(detx.utoy(),detx.vtoy()),detx) : detx code = "x 128 == y 128 == | x y + 256 == | 0 x 128 - abs y 128 - abs < x 128 - abs x y + 256 - abs < & x 128 - abs 1 - " + \ "y 128 - abs x y + 256 - abs < y 128 - abs 1 - x y + 256 - abs 1 - ? ? 2.4 ^ x 128 - y 128 - * 0 > -0.6 0.6 ? * ? 128 +" diff = mt_makediff(detx,detx.trim(1,0),y=3,u=1,v=1) global bclpx = mt_lutxy(diff,diff.trim(1,0),expr=code,y=3,u=1,v=1).bilinearresize(round(width(detx)/bsize+4)*4,round(height(detx)/bsize+4)*4) ###### output preparation ###### global outb = blankclip(source) #do your filtering here, it will be faster and more stable global outc = source #if you do it outside the conditional enviroment ###### initialise variables ###### global lfrx = -100 ###### evaluation call & output calculation ###### scriptclip( source, """ ### preparation ### cfrx = current_frame jmpx = lfrx+1==cfrx lfrx = cfrx bx_v = 128-yplanemin(bclpx) bx_v = bx_v<0 ? 0 : bx_v * bfacx cx_v = yplanemax(bclpx)-128 cx_v = cx_v<0 ? 0 : cx_v * bfacx ## blend value shifting ## bxp = jmpx ? bxc : bx_v bxc = jmpx ? bxn : bx_v bxn = bx_v ## clear value shifting ## cxp = jmpx ? cxc : cx_v cxc = jmpx ? cxn : cx_v cxn = cx_v isblend = bxc+cxp>bxp+cxc+thrx && bxc+cxn>bxn+cxc+thrx #detects nearly every blend but also frames with very low motion isblendsave = isblend && bxc+cxp>bxp+(1+.2*thrx)*cxc && bxc+cxn>bxn+(1+.2*thrx)*cxc && bxc>(1+.2*thrx)*cxc #saver blenddetection ### output clip ### isblend ? outb : outc #call your filtered sources here #outc.subtitle(string(isblend)).subtitle(string(isblendsave),y=16) #to compare isblend and isblendsave """) ###### final decimation & caching ###### cache<0 ? last : last.RequestLinear(8, cache, 5, false, false) return last } |
#255 | Link |
Yes, thank you for the new version. I'm getting some really nice results on some analogue captures with:
mvdegrain3i(2,0,1) TDeint(order=1,field=1,mode=1,type=2,tryweave=true) crop(8,56,-8,-56) NNEDI(field=1,dh=true,threads=2) srestore() |
#256 | Link |
Thanks a bunch, this'll be very, very useful.
#260 | Link |
thnxs a lot ... tried srestore works gr8.
though I was running into problems last nite using MT around srestore with 2.5.7 rev of Avisynth. Is MT recommend to use around SRestore for 2.5.7? It was giving me error messages in the clip and can post SS for the same when I get back to my place. |
mrestore, srestore |
