Old 14th December 2016, 13:59   #41481  |  Link
Knight77
I am not sure what the "kill my card" is about but in their newer drivers Nvidia changed the default power management mode from "adaptive" to "optimal power". Optimal power clocks too low for madVR though so you need to change back to adaptive, after I do this I don't get any dropped frames with the newest madVR at ~85% GPU usage.
Asmodian can you clarify something to me?
I do not have any dropped frame or particular problem but looks like is suggested to change from the default optimail power to maximum or at least adaptive, but how? I mean... in the setting page below or you let the application manage the settings or you decide but then there are many other settings to check not only the one about power usage. Am I missing something? If not...what else should I choose or select other then the power settings?
Hope you can help.
Knight77 is offline   Reply With Quote
Old 14th December 2016, 14:09   #41482  |  Link
just leave the rest of the settings at default and change power management to adaptive.
Old 14th December 2016, 14:49   #41483  |  Link
adhara
Originally Posted by adhara View Post
I'm a problem about the video quality when using a video projector.
I set up MadVr using Warner306 recommandations available here
With my 60" 4K TV, the video quality is awesome. When using the same configuration on a 4K video projector (3,5m so 138"), image is not so detailed/sharp and a simple BD player offer a better quality.
What is the problem ?
Regards
what projector?
VP is EPSON 9300
Another question about graphic card.
I want to outptut all my videos to 4k(24-60) - full RGB - 10 bits
What is the best between Nvidia GTX 1060 and AMD RX 480 ?
No issue with the new AMD cards (like 10 bits dithering) ? I always owned Nvidia till now...
I want to be able to run:
2160p video
Chroma: NGU high quality
Image: Jinc3 + AR
Image doubling: Off
Upscaling refinement: Off
Artifact removal - Debanding: Medium/High
Artifact removal - Deringing: Off
Image enhancements: crispen edges (0.5) + AR
Dithering: Error Diffusion 2
1080p video
Image: Jinc3 + AR
Double Luma: 2.0x or greater - NGU high quality
Double Chroma: Off
Upscaling refinement: soften edges (1)
Image enhancements: Off
adhara is offline   Reply With Quote
Old 14th December 2016, 15:07   #41484  |  Link
Mistery 73
The nvidia in full RGB do not support 10-bit but only 8 bits
Mistery 73 is offline   Reply With Quote
Old 14th December 2016, 15:09   #41485  |  Link
adhara
Nvidia 10x supports 10 bits only at 30Hz and lower (when outputting to 4k).
Is it different with RX480 (Polaris) ?
Old 14th December 2016, 15:09   #41486  |  Link
plasma
VP is EPSON 9300
2160p video
Image: Jinc3 + AR
Image doubling: Off
1080p video
Image: Jinc3 + AR
Double Chroma: Off
no card ca output 4:4:4@2160p@60hz@10bit via hdmi 2.0. It is an limitations of said interface
plasma is offline   Reply With Quote
Old 14th December 2016, 15:22   #41487  |  Link
adhara
Ok so Nvidia GTX 1060 or AMD RX 480 ?
And what about the problem with an EPSON 9300 (4k,10bits, HDCP 2.2, .. compliant) ?
Old 14th December 2016, 16:15   #41488  |  Link
iopq
I can't adjust any settings with the newest version, it only has "create profile" group button that shows me a menu for what to create a profile group for.
Except when I select something and hit OK, now the button is disabled and I still don't have any settings I can change. Any idea how to fix this?
iopq is offline   Reply With Quote
Old 14th December 2016, 17:22   #41489  |  Link
the projector is 1080p it only supports UHD input. for best quality it is most likely better to stick to 1080p
try reset to defaults. but this sounds strange did you update madVR while it was still running?
Old 14th December 2016, 18:34   #41490  |  Link
anta777
Rx470 50VT50
Сomparison algorithms chroma upscaling:
nguveryhighsr4 0.0024
nguhighsr4 0.0026
nguveryhigh 0.0028
ngumedsr4 0.0030
nguhigh 0.0032
sxbr150arsr4 0.0032
nnedi128sr4 0.0033
ngumed 0.0034
sxbr75arsr4 0.0036
sxbr100arsr4 0.0037
ngulow 0.0039
sxbr150ar 0.0048
reconsharp 0.0050
reconsharpar 0.0050
reconplacebo 0.0051
reconplaceboar 0.0052
nnedi128 0.0054
nnedi64 0.0057
sxbr100ar 0.0057
bilatoldsr4 0.0058
nnedi32 0.0059
bilatsoftsr4 0.0060
bicubic75ar 0.0064
sxbr75ar 0.0064
reconsoftsr4 0.0071
bilatold 0.0110
reconsoft 0.0117
bilatsharp 0.0134
bilatsoft 0.0135
I use dssim and brownfox.
anta777 is offline   Reply With Quote
Old 14th December 2016, 18:44   #41491  |  Link
Warner306
Regards
Try disabling soften edges in upscaling refinement if you find the image too soft.
I wonder if I should recommend soften edges for any profile. I am still undecided on its value.
Old 14th December 2016, 18:58   #41492  |  Link
Asmodian
Hope you can help.
It is in the advanced settings page, not adjust with preview. As huhn said, leave the other options at their defaults.
madVR options explained
Old 14th December 2016, 19:31   #41493  |  Link
iopq
Already tried, didn't help. I did update madVR while it was running, but it didn't let me replace the files so I couldn't do it. I replaced the files again and I think I found the problem:
the settings are dropdowns, you need to click on the little < for them to actually show something
I have another issue:
When I launch Brood War (which has a resolution of 640x480 so it changes screen resolution) and alt tab back out, MPC says
madVR reports:
- creating Direct3D device failed (80070005)
Old 14th December 2016, 19:39   #41494  |  Link
well doubling clicking works too just to let you know.
Old 14th December 2016, 20:06   #41495  |  Link
Asmodian
madVR reports:
This is normal, the game destroys the Direct3D device when it changes the resolution so madVR fails.
You cannot do anything like this with madVR running, e.g. sleeping the computer has a similar result.
Old 14th December 2016, 21:47   #41496  |  Link
Use the batch file in the installation directory and reset madVR to default settings.
Old 15th December 2016, 00:43   #41497  |  Link
iopq
It might be normal, but it's undesirable that MadVR doesn't handle this gracefully.
Old 15th December 2016, 01:04   #41498  |  Link
well maybe this is the place to add this: http://bugs.madshi.net/view_all_bug_...d=4&dummy=bla/
it is just me saying that but i don't think this is a high priority issue
Old 15th December 2016, 01:47   #41499  |  Link
XTrojan
New windows beta build supports HDR and native rec2020 colorspace, Madshi might wanna take a look?
XTrojan is offline   Reply With Quote
Old 15th December 2016, 01:57   #41500  |  Link
clsid
https://msdn.microsoft.com/en-us/lib...(v=vs.85).aspx
