Old 25th December 2011, 12:00   #1941  |  Link
Big Vern
Trying to ocnvert a few of my blu-ray to mkv rips back to DVD for my Daughters new TV with a built in DVD player.
AVSTODVD is aborting the process after 50% of first pass in HCenc. Says please check the log, I have look at log, there is no error message.
<25/12/2011 10:51:53>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 3999/4000 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: H:\DVD
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 384
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt (255,255,255)
Chapters Interval: 10
Use Source Chapters: 1
DVD Burning Drive: E: PIONEER DVD-RW DVR-116D 1.09
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 0
<25/12/2011 10:51:54>
TITLE 1 SOURCE FILES
Video: D:\WDTV Box\Anuvahood.mkv
Info: AVC - 2817 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:28:50 hours - 127794 frames
Audio 1: D:\WDTV Box\Anuvahood.mkv
Info: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 1:28:50 hours (0 ms delay) - Internal
[MediaInfoLib - v0.7.50]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("D:\WDTV Box\Anuvahood.mkv", CacheFolder="D:\AVS assets", FrameRate=23.976, VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("D:\WDTV Box\Anuvahood.mkv", CacheFolder="D:\AVS assets")
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.Spline64Resize(720,480)
AudioDub(Video, Audio)
Encoding Profile: HCenc VBR 1-pass
Target Video FileSize: 3675.7 MB
HCenc Parameters: -ini "D:\AVS assets\DVD_0_Anuvahood.HCenc.ini"
HCenc ini file:
*INFILE D:\AVS assets\DVD_0_Anuvahood_1.avs
*AVSRELOAD
*OUTFILE D:\AVS assets\DVD_0_Anuvahood.m2v
*LOGFILE D:\AVS assets\DVD_0_Anuvahood.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 5785
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<25/12/2011 10:54:21>
CHECK LOG FILE <H:\DVD\DVD_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.4.2
Any ideas please?
Big Vern is offline   Reply With Quote
Old 4th January 2012, 00:47   #1942  |  Link
Sjakko
Hi MrC,
I have a bunch of MPEG2 files with 160kbps mp2 audio I'd like to put on DVD losslessly. But AVStoDVD insists on doing a full audio encode instead of a Direct Stream Copy. I think the DVD specification supports 160kbps audio. Would you think about adding 160kbps audio Direct Stream Copy support?
Thanks,
Sjakko
Sjakko is offline   Reply With Quote
Old 11th January 2012, 02:37   #1943  |  Link
dado023
*.vob files?
can it open *.vob files?
Intel Core i7-3720QM, Samsung DD3 8GB 1600 MHz, Intel HM77 (Panther Point), GeForce GT 650M 2GB DDR5 384pipelines :ETA, end of May.
dado023 is offline   Reply With Quote
Old 11th January 2012, 23:15   #1944  |  Link
Taurus
Taurus's Avatar
Yes we can!
Reading the ? Help and search for "vob" in the Help will give you some hints.
But better practice: Open the coresponding ifo file to avoid lags and other trouble with your vobs.
And of course: They must be copyrightprotectedfree
And why don't you try to open your vobs with AVStoDVD?
Is there an error message?
Old 12th January 2012, 00:17   #1945  |  Link
dado023
got it,... drag and drop for *.vob wont work, but Add tittle works fine
thanks for the response Taurus
Old 13th January 2012, 00:27   #1946  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Can I request a feature for some sort of bit allocation for the opening/end credits?
Or is there a custom AVS function I can add in manually?
An average of 2-2.5mbps would suffice for credits.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
Sparktank is offline   Reply With Quote
Old 13th January 2012, 01:35   #1947  |  Link
abyss616
@MrC: When you tell the program to encode a 720x480 file in 16:9 format, why does it crop 36 pixels off the top and bottom? In the Avisynth tab, it resizes it (720,480,0,-36,0,36 - something to that effect, going off memory).
abyss616 is offline   Reply With Quote
Old 13th January 2012, 10:56   #1948  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Big Vern
some trials:
- uninstall and reinstall AviSynth
- uninstall every kind of codecs pack and use only ffdshow stable releases
- use QuEnc CBR 1-pass encoding profile
@Sjakko
will do
@dado023
that's strange: from my side drag and drop works with vobs
@Sparktank
please elaborate a little bit more your request
@abyss616
there's no general rule: it depends on the input file width, height and DAR.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 13th January 2012, 23:08   #1949  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
@Sparktank
I remember using an old, dated program, AutoGK.
It had a function in the hidden options to change the bitrate for the end credits to allow the rest of the video to have a little bit more bit allocation.
Basically, tell the program to encode a certain section at a lower bitrate.
For example, if the end credits start at 1:26:21 and ends at the end of the file (let's say 1:29:01) and you want to that window of time to be encoded at a CBR of 2mbps, this would allow the rest of the movie to allow more room for bit peaks.
End credits are, normally, white text on black background. Unless they're they're fancy like in Star Trek (2009) or have credits scrolling by on one side and outtakes/bloopers on the opposing side (like most Jackie Chan movies).
Usually I notice that frames with large sections of text require more bit allocation. (While watching the movie on Cyberlink's PowerDVD and on-screen "Information" enabled, it shows the bitrate fluctuating as the movie plays; or even playing a movie back with FFDshow set as the default decoder and OSD enabled with bitrate showing).
If we make the entire end credits (based on start time and end time of the credits) a CBR, or even lower it to an average bit rate, this would help a little bit for movies that are closer or beyond 2 hours.
Cinema Craft Encoder has similar bit rate allocation as AutoGK, but more advanced, of course.
I hope that helps a little more.
I can look up some documentation on "bit rare allocation" if that helps.
Old 16th January 2012, 22:02   #1950  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Sparktank
ok, got it. That sounds interesting.
Solution 1
Two different encoding parts (m2v), to be joined by Muxman during the authoring step.
Solution 2
Use the *ZONE command from HCenc. You can already use it by "Edit encoder command parameters at runtime".
Let me think about it and verify the result of encoding @2mbps a standard credit footage.
Thanks for the suggestion
Bye
MrC
AVStoDVD Homepage
Old 16th January 2012, 22:25   #1951  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
@MrC
That'd be wonderful!
Looking forward to results.
If I can think of anything, I'll update.
Old 19th January 2012, 03:36   #1952  |  Link
abyss616
@abyss616
Every 720x480 file that I set to encode at 16:9 gets the following line added to the avisynth tab:
Video = Video.Spline64Resize(720,480,0,36,0,-36)
That cuts off the top and bottom 36 pixels. I manually edit each file so that it says Video = Video.Spline64Resize(720,480).
Old 20th January 2012, 12:55   #1953  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
There are multiple cases for 720x480 resolution:
Input file DAR 4:3
Video = Video.Spline64Resize(720,480,0,66,0,-66)
Input file DAR 16:9
*no resizing*
Input file DAR 1:1
If you take a DAR 1:1 input file and set the flag to 16:9, that is what you are actually doing, your output will be horizontally streched. Is that what you really want?
Bye
MrC
AVStoDVD Homepage
Old 20th January 2012, 16:52   #1954  |  Link
abyss616
If it means that the top and bottom 36 pixels are cut off, I guess that I do. Maybe I'll stop resizing the 16:9 input files in my avisynth script down to 720x480 and leave them as is. Everything I had read said to make them 720x480 resolution.
Old 26th January 2012, 14:25   #1955  |  Link
ThaDraGun
Having a problem creating a DVD. I have been using this program for a while now and havent changed any of the settings.
I'm getting an error after a could seconds:
'unsupported compression method'
Somthing get changed some how? I installed another dvd creator program so that maybe is why Im having problems now? I installed Aimersoft DVD Creator.
LOG:
<26/01/2012 8:44:05 AM>
START PROCESS
PROJECT SETTINGS
DVD Size: 4449/4450 MB (100%)
DVD Label: DVD
DVD Menu: No Menu
Output Folder: F:\DVDs
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
Video Resolution: 1
Video BitRate Level 1: 8500
Video Profile Level 2: 8500
AC3 Audio Encoder: 1
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliant Audio: 0
Normalize Audio: 0
Auto Delay Audio: 1
DVD Subs Font: Bell MT 9pt (255,255,255)
Chapters Interval: 5
DVD Burning Drive: H: TSSTcorp CDDVDW SH-S223C SB06
Save Log file: 1
Video: E:\Movies\New folder\Movie.mkv
Info: AVC - 5174 kbps - 1280x536 - DAR 2.388 - 23.976 fps (CFR) - Progressive - 1:57:08 hours - 168504 frames
Audio 1: E:\Movies\New folder\Movie.mkv
Info: DTS - 1536 kbps - CBR - 6 ch - 48000 Hz - 24 bit - 1:57:08 hours (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("E:\Movies\New folder\Movie.mkv", CacheFolder="C:\Users\MARCEL~1\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("E:\Movies\New folder\Movie.mkv", CacheFolder="C:\Users\MARCEL~1\AppData\Local\Temp")
Video = Video.AddBorders(0,92,0,92)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 3964.5 MB
HCenc Parameters: -ini "C:\Users\MARCEL~1\AppData\Local\Temp\DVD_0_Movie.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\MARCEL~1\AppData\Local\Temp\DVD_0_Movie_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Marcel & Julia\Videos\DVD_0_Movie.m2v
*LOGFILE C:\Users\MARCEL~1\AppData\Local\Temp\DVD_0_Movie.HCenc.log
*MAXBITRATE 9000
*BITRATE 4732
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
ThaDraGun is offline   Reply With Quote
Old 26th January 2012, 17:47   #1956  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Looks like a splitter/codecs issue. Try to remove the software you have recently installed and restore Haali Media Splitter and ffdshow (or whatever directshow codecs you were using).
Bye
MrC
AVStoDVD Homepage
Old 1st February 2012, 16:11   #1957  |  Link
Cyber-Mav
doesnt work for me, says VB6 common controls not found.
Cyber-Mav is offline   Reply With Quote
Old 4th February 2012, 19:01   #1958  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Did you install them? They are included in AVStodVD Installer package, but NOT in NoInstall package (see ReadMe_NoInstall.txt).
Bye
MrC
AVStoDVD Homepage
Old 6th February 2012, 15:41   #1959  |  Link
Cyber-Mav
Bye
ahh i used the no install package,. let me try the other one.
Old 22nd February 2012, 17:44   #1960  |  Link
8ternity
8ternity's Avatar
Hi Mrc,
I had an issue with AVStoDVD. Audio encoding has failed, same over ffmpeg process.
Here what you need:
<2012-02-22 11:27:44>
START PROCESS
PROJECT SETTINGS
DVD Titles number: 4
DVD Size: 8099/8100 MB (100%)
DVD Label: Season 6
DVD Menu: Motion Menu
Output Folder: E:\DVD-TEMP
PREFERENCES
MultiThread: 1
AVS Source Filter: DirectShowSource
AVS UpSize/DownSize Filter: Spline36Resize/Spline36Resize
PAL SpeedUp: 0
Video Resolution: 0
AC3 Audio Encoder: 3
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 0
DVD Audio Language (Primary): FR - French
DVD Subs Language (Primary): FR - French
DVD Burning Drive: G: ATAPI iHAS124   B AL0S
Save Log file: 1
Video: D:\--= Complete =--\Dexter.S06E01.avi
Info: XviD - 1330 kbps - 624x352 - DAR 1.773 - 23.976 fps (CFR) - Progressive - 52:37 minutes - 75693 frames
Audio 1: D:\--= Complete =--\Dexter.S06E01.avi
Info: MPEG-1 Audio layer 3 - 32 kbps - CBR - 2 ch - 48000 Hz - 52:37 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = DirectShowSource("D:\--= Complete =--\Dexter.S06E01.avi", fps=23.976, audio=false)
Audio = DirectShowSource("D:\--= Complete =--\Dexter.S06E01.avi", video=false)
Video = Video.Spline36Resize(720,480,0,0,0,-0)
Target Video FileSize: 1799.7 MB
HCenc Parameters: -ini "E:\Temp\Season 6_1_Title_01_Épisode 1.HCenc.ini"
HCenc ini file:
*INFILE E:\Temp\Season 6_1_Title_01_Épisode 1_1.avs
*AVSRELOAD
*OUTFILE E:\Temp\AVStoDVD\Season 6_1_Title_01_Épisode 1.m2v
*LOGFILE E:\Temp\Season 6_1_Title_01_Épisode 1.HCenc.log
*MAXBITRATE 9000
*BITRATE 4782
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2012-02-22 11:40:58>
END VIDEO ENCODING OPERATIONS
Created File: E:\Temp\AVStoDVD\Season 6_1_Title_01_Épisode 1.m2v (1800.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 4817 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 52:36 minutes - 75691 frames
START AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -threads 6 -i "E:\Temp\Season 6_1_Title_01_Épisode 1_1.avs" -y -vn -acodec ac3 -sample_fmt flt -ac 2 -ar 48000 -ab 448k "E:\Temp\AVStoDVD\Season 6_1_Title_01_Épisode 1_1.ac3"
<2012-02-22 11:40:59>
PROCESS ABORTED DURING TITLE 1 AUDIO (TRACK 1) ENCODING OPERATIONS.
CHECK LOG FILE <E:\DVD-TEMP\SEASON 6_1.LOG> FOR MORE INFO.
mediainfo
General
Complete name : Dexter S06_ep1.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 561 MiB
Duration : 52mn 37s
Overall bit rate : 1 489 Kbps
Writing application : VirtualDubMod 1.5.10.3 Fr | www.virtualdub-fr.org || (build 2550/release)
Writing library : VirtualDubMod build 2550/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 52mn 37s
Bit rate : 1 330 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.253
Stream size : 501 MiB (89%)
Writing library : XviD 62
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 52mn 37s
Bit rate mode : Constant
Bit rate : 32.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 55.1 MiB (10%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 110 ms
Writing library : LAME3.97
can you help me with that please?
Thanks!
[IMG] code is Off
