27th September 2007, 22:09 | #61 | Link | |
The -2 was indeed a typo, it should have been -1.
28th September 2007, 18:53 | #62 | Link |
I made a small test on a DV source and I said: WOW!
Reasons: Original: Nnedi: Original (the camera was moving left-right or right-left): Nnedi: Cedocida encode & Nnedi: Original (the camera was moving left-right or right-left and up-and-down): Nnedi: Cedocida encode & Nnedi: enjoy, Mtz Last edited by Mtz; 28th September 2007 at 23:26. |
28th September 2007, 23:23 | #64 | Link |
I used:
AVISource("I:\MiniDV\My Video-04\InterlacedSonyDCRHC96__DV.avi") AssumeBFF() nnedi() The sample is at the bottom of this page. enjoy, Mtz Last edited by Mtz; 29th September 2007 at 00:04. |
4th October 2007, 19:19 | #65 | Link | |
Pig on the wing
4th October 2007, 22:42 | #69 | Link |
*Space Reserved*
What kind of problem? It runs just fine here.
Make sure you have all the prerequisites. I didn't include any of them for either scripts since that's only what boulder asked for. Last edited by Terranigma; 4th October 2007 at 22:44. |
5th October 2007, 11:45 | #70 | Link |
I've finally jumped in with this.
NNEDI seems to have different strengths from EEDI2 - another useful tool - thank you tritical! However, I'm having problems with mcbob downloaded from Terranigma's link. The "old" EEDI2 MCBob_v03c works beautifully, but MCBob_v03u isn't right. It doesn't crash, and I get sensible output, but the deinterlacing is bad - on every second field (so bottom field on TFF content) moving diagonals look close to plain old bob() - much worse than v03c, and worse than NNEDI on its own. On the frame generated from top fields, it's not horrible, but not great – those bobbles on diagonals that nnedi reportedly avoided are present, whereas they aren't there with v03c. What have I broken? I assume all plug-ins are OK since mcbob v03c works beautifully. I can post samples and screen shots if it's not an obvious/known error. Cheers, David. |
5th October 2007, 13:53 | #72 | Link |
Well, the problem is about correct usage of NNEDI, so it does fit here somehow.
Wrong: Code:
Function nnEDIbob(clip Input) { [...] GetParity(Input) ? Input.SeparateFields().nnEDI(dh=true,Field = 1) : Input.SeparateFields().nnEDI(dh=true,Field = 0) AssumeFrameBased() GetParity(Input) ? AssumeTFF() : AssumeBFF() } Correct: Code:
Function nnEDIbob(clip Input) { [...] Input.SeparateFields() GetParity(Input) ? Interleave( SelectEven().nnEDI(dh=true,Field = 1), SelectOdd().nnEDI(dh=true,Field = 0) ) \ : Interleave( SelectEven().nnEDI(dh=true,Field = 0), SelectOdd().nnEDI(dh=true,Field = 1) ) AssumeFrameBased() GetParity(Input) ? AssumeTFF() : AssumeBFF() }
- We´re at the beginning of the end of mankind´s childhood - My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!) Last edited by Didée; 5th October 2007 at 13:56. |
5th October 2007, 15:04 | #73 | Link | ||
*Space Reserved*
--- Link Updated. |
5th October 2007, 20:13 | #74 | Link | |
Function nnEDIbob(clip Input) { Input.SeparateFields() GetParity(Input) ? Interleave( SelectEven().nnEDI(dh=true,Field = 1), SelectOdd().nnEDI(dh=true,Field = 0) ) \ : Interleave( SelectEven().nnEDI(dh=true,Field = 0), SelectOdd().nnEDI(dh=true,Field = 1) ) AssumeFrameBased() GetParity(Input) ? AssumeTFF() : AssumeBFF() } Code:
Function nnEDIbob(clip Input) { Input.nnedi(field=-2) } Quote:
EEDIbob() could be simplified as well: Code:
Function EEDIbob(clip Input, int "maxd") { GetParity(Input) ? Input.SeparateFields().EEDI2(Field = 3, maxd = maxd) : Input.SeparateFields().EEDI2(Field = 2, maxd = maxd) AssumeFrameBased() GetParity(Input) ? AssumeTFF() : AssumeBFF() } Code:
Function EEDIbob(clip Input, int "maxd") { Input.SeparateFields().EEDI2(Field = -2, maxd = maxd) } Last edited by tritical; 5th October 2007 at 20:32. |
6th October 2007, 00:32 | #75 | Link |
*Space Reserved*
Thanks tritical for making things simpler and faster
I updated the bobbers once again, hopefully this'll be the last time :P With mcbob, I switched the default interpolater with nnedi, changed mtnmode to 1, renamed Vinverse to VinverseD (D = Didée. Seriously Didée, I hope you're ok with this), and included triticals' much faster vinverse dynamic library file. Grab it here or from the link above. |
16th October 2007, 10:14 | #76 | Link |
I've always wondered with EEDI2, and this may apply even more to NNEDI...
When I use it to re-size, I call NNEDI twice, with turnright and turnleft after each call. Sometimes I do the whole process twice (so calling NNEDI four times - twice for each dimension). Would it be possible / better if NNEDI worked in 2-D to start with, so it doubled in each dimension in one pass? I'm not worried about speed, but worried that the current two-pass method forces NNEDI to interpolate from what's already 50% interpolated data. I'm guessing that if it interpolated in 2-D in one pass, it would use only "real" data as a source for interpolation in both dimensions. Second (easier?) question: with or without the above modification, could it be told to interpolate more than one pixel in a given dimension? I know for interlaced content, it's always 1-in-2 pixels "missing". However, when I process other things, sometimes it's 2-in-3 pixels missing (meaning I only have 1-in-3 pixels available). For now, I just call NNEDI twice, but it would be neater (and avoid interpolating from interpolation again!) if I could call it with a parameter to do 2x (like now), or 3x, or 4x etc interpolation. I'm not asking or expecting you to do this tritical (I know you're busy), but if either part is easy/possible and you're updating NNEDI at any time anyway, please think about it. It might make it an even more interesting academic project! Cheers, David. |
16th October 2007, 10:38 | #77 | Link |
Avisynth Developer
Yes, TurnLeft/Right by the nature of the algorithm are slow. They violate the "never look down" rule for fast processing. You either read the src across and write the dest down or vide versa.
16th October 2007, 13:14 | #78 | Link |
Slow is a relative term, on a modern computer it shouldn't take more than a msec to transpose a SD yv12 frame from cache even with the naive C implementation in Avisynth (on mine it takes nearly 2, but that stuff ain't modern). Just a drop in the bucket really.
A bigger problem to me seems that processing U/V planes without data from the Y plane is a bit dodgy. Last edited by MfA; 16th October 2007 at 14:41. |
16th October 2007, 13:27 | #79 | Link |
It's not speed I'm worried about (though if it makes it faster, great!) - it's accuracy. With turnright turnleft NNEDI is being given it's own output to work from - surely it would be better if we could avoid this?
Cheers, David. |
16th October 2007, 14:39 | #80 | Link | |
ffdshow/AviSynth wrangler
Also, NNEDI is designed (or rather, trained) to interpolate between image's odd or even lines (which is about the same as doubling the height) - scaling in both directions would need a total rewrite and probably a lot more training.
now playing: [artist] - [track] ([album]) |
deinterlace, nnedi |
