Old 23rd March 2008, 02:14   #1001  |  Link
west
Why do you convert mkv with mkv2vob??????? Use m2ts from bluray structure instead. (I assume you have PS3). Log file should be in /Logs Directory
I am trying to stream to the ps3 via tversity... it does not recognize m2ts (from wut i kno) and when u do just change the container to say mpeg i get picture that pixelates and breakes up... and i also dont get the audio desired... the audio is in highdef and not compatible with the streaming capabilities of the ps3.. thus that is y i use mkv2vob... unless there is another option i have failed to acknowledge please fill me in... thanks for your help
heres the log i got for converting the m2ts to mkv:
C:\>"C:\Documents and Settings\xxx\Desktop\rb\tools\x264\x264.exe"
"C:\DOCUME~1\xxx~1\LOCALS~1\Temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 1024 --stats "C:\DOCUME~1\xxx~1\LOCALS~1\Temp\RipBot264temp\job1\job1.stats" --level 4.1 --sar 1:1 --aud --nal-hrd --vbv-bufsize 14000 --vbv-maxrate 25000 --filter 0,0 --bframes 3 --direct auto --subme 2 --analyse none --me dia --threads auto --thread-input --progress --no-psnr --no-ssim --output "C:\DOCUME~1\xxx~1\LOCALS~1\Temp\RipBot264temp\video.264"
avis [info]: 1920x1080 @ 23.98 fps (692 frames)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX MMXEXT SSE SSE2 Cache64
encoded frames: 1/692 (0.1%), 5.35 fps, eta 0:02:09
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
"C:\DOCUME~1\xxx~1\LOCALS~1\Temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 1024 --stats "C:\DOCUME~1\xxx~1\LOCALS~1\Temp\RipBot264temp\job1\job1.stats" --level 4.1 --sar 1:1 --aud --nal-hrd --vbv-bufsize 14000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-rdo --bime --weightb --direct auto --subme 6 --trellis 1 --analyse p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --output "C:\DOCUME~1\xxx~1\LOCALS~1\Temp\RipBot264temp\video.264"
x264 [error]: ratecontrol_init: can't open stats file
x264 [error]: x264_encoder_open failed
C:\>"C:\Documents and Settings\xxx\Desktop\rb\tools\mkvtoolnix\mkvmerge.exe" -o C:\Documents and Settings\xxx\My Documents\Downloads\xx\BDMV\STREAM\00020.mkv" --default-duration 0:23.976fps -d 0 -A -S "C:\DOCUME~1\xxx~1\LOCALS~1\Temp\RipBot264temp\video.264" --sync 0:0 -a 0 -D -S "C:\DOCUME~1\xxx~1\LOCALS~1\Temp\RipBot264temp\job1\job1.dga PID 1100 C+L+R+SL+SR 48 1536.dts" --track-order 0:0,1:0
mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:45:12
Error: The file 'C:\DOCUME~1\xxx~1\LOCALS~1\Temp\RipBot264temp\video.264' has unknown type. Please have a look at the supported file types ('mkvmerge --list-types') and contact the author Moritz Bunkus <moritz@bunkus.org> if your file type is supported but not recognized properly.
west is offline   Reply With Quote
Old 23rd March 2008, 03:01   #1002  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
Ok the latest and last installer for RipBot264 is up enjoy...
As my signature says I have gotten a developer position at my job so I wont be making installers anymore...
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 23rd March 2008, 03:58   #1003  |  Link
deets
aww thats bad news for us but good news for you
a quick Q regarding ripbot, can it make an mp4 that plays on both psp and ipod? someone asked me if they could use it to make just the one file for both devices and i have no clue
deets is offline   Reply With Quote
Old 23rd March 2008, 04:41   #1004  |  Link
~bT~
н∂-ƒαиαтι¢
^ yes it does. the iPod version should play in PSP too.
~bT~ is offline   Reply With Quote
Old 23rd March 2008, 07:32   #1005  |  Link
xaero
hello again Atak_Snajpera.
i ran into another problem.. im not good at this kinda stuff so please bear with me.. >.<
i tried to encode this file :
http://freetexthost.com/o43cnswtfv
but everytime i do so, mpc pops up and give me this :
DirectShowSource: couldn't open file E:\<titleofvideofile-h264.aac>.mkv:
No combination of filter could be found to render the stream.
(C:\DOCUME~1\Xaero\LOCAS~1\Temp\RipBot264temp\job1\getinfo.avs, line 1)
i tried to remux it with mmg but i got the same error...
xaero is offline   Reply With Quote
Old 23rd March 2008, 07:44   #1006  |  Link
Install/Reinstall FFDSHow and Haali Media Splitter
I noticed you are the creator of that nice little "MediaInfo" application. Great work! As you are the Author of this, I thought maybe you could do the following...
I'm not MediInfo author.
Old 23rd March 2008, 10:11   #1007  |  Link
IYG
I have a question.
When I reduce the resolution, with the same file size why doesn't the bit rate increase?
IYG is offline   Reply With Quote
Old 23rd March 2008, 11:45   #1008  |  Link
Ryu77
Ryu77's Avatar
Yes, I just realised that you created a GUI for that app but Zenitram is the actual Author of that application.
I know that we can look at that MediaInfo application to see what encoding options are enabled in the h264 file. From there we can identify it's "true" level. It would be nice to have an application that could automate this though.
Something that could just scan a h264 file and state if it is Blu-ray stand alone/PS3 compatible or not.
Hmmm... I wish I knew how to create software. Atak, where can I start to learn about acquiring such a skill like yours?
Ryu77 is offline   Reply With Quote
Old 23rd March 2008, 13:48   #1009  |  Link
~bT~
н∂-ƒαиαтι¢
Originally Posted by IYG View Post
I have a question.
coz its not supposed to. that's not how things work.
Old 23rd March 2008, 13:50   #1010  |  Link
~bT~
н∂-ƒαиαтι¢
doesn't avinaptic work? and which gui did Atak make for Zenitram
Old 23rd March 2008, 16:00   #1011  |  Link
Ryu77
Ryu77's Avatar
What does avinaptic do? I am looking for a tool that scans a h264 file and even if it is tagged or encoded in the 5.1 level profile, it can identify if it can indeed be tagged as 4.1 and fit into that profile correctly?
In other words something that can identify the h264 streams true profile level by scanning the encoding options used, not something that simply reads the metadata.
For example... We can change the metadata to label a h264 stream as baseline profile, level 3.0 (or below) but that doesn't mean it will play on an iPod. Changing the metadata, doesn't "make" it fit into that profile.
Atak made a GUI for MediaInfo as I mentioned. Atak's GUI is labelled MediaInfoRaw...
http://forum.doom9.org/showthread.ph...68#post1097168
Old 23rd March 2008, 17:16   #1012  |  Link
survivant001
@Atak_Snajpera
another requests for you .. with theses you won't sleep soon
#1 - be able to add multiple audio track (was requested by me few days ago. I have a mkv in english and french. I want to create a bluray with the two audio track)
#2 - when you detect audio track in a mkv, if you found subtitles, extract them too and add a option in the main menu, not in the properties(now we have to extract them manually and import them manually)
#3 - support tsmuxer 1.6b (it had the split file .. yéééé)
#4 - be able to add multiple input in the same bluray output. Liek include job 1,job2,job3,job5 into one output (a new option in the jobs list screen). It will be really usefull for anime bluray.
#5 - add a feature in the .ini. Like Last avs script line. Like that you could add filters into the avs and it's only for advanced users
survivant001 is offline   Reply With Quote
Old 23rd March 2008, 23:18   #1013  |  Link
I've noticed that Roman is going to implement srt support in near future so this feature will get the highest priority.
This should be easy to implement.
I still see no reason for doing that. If you want to split file use TSMuxer directly.
Why do you need two audio tracks in HD rip?
Do not overestimate me I started my adventure with Delphi after high school. Before that I was playing in basic on my ancient C64 Good old days.
Old 24th March 2008, 00:06   #1014  |  Link
survivant001
it's really important for me. in tsmuxer 1.6b Roman had the feature that I requested. the 000001.m2ts can be split into smaller files. Really usefull when you want to copy the ouput on a FAT32 system. it's all done by tsmuxer, but you have to pass the parameters.
--split-size=4GB
why.. easy. I speak french. I almost always watch movies in there original release. English in english, french in french and jap in jap subtitle
but I'm not only here. so when I got a movie with dual audio track, I want to keep them both. Right now the only option is to burn 2 DVD, one with each track... ok with tsmuxer I can include them both, but that's mean I'll have to do job1 in english, after that job2 in french.. but kill the process just after the audio encoding. mux them manually..
Old 24th March 2008, 00:42   #1015  |  Link
--split-size=4GB
All right. --split-size=4GiB will be always added in next version.
survivant001 is offline Report Post Reply With Quote
This must wait because multi subtitles support is more important for me at the moment.
Old 24th March 2008, 00:59   #1016  |  Link
Ryu77
Ryu77's Avatar
LOL! Yes, me too. I remember playing around in basic on my good old Commodore 64, since then though I haven't learnt anything at all about Authoring/Programming/Developing (whichever is the best word). I wouldn't know where to start on a Windows PC... Is Delphi a good starting point?
Old 24th March 2008, 01:57   #1017  |  Link
survivant001
exactly.. I still can mux the few movies that I have manually
Old 24th March 2008, 19:16   #1018  |  Link
~bT~
н∂-ƒαиαтι¢
this you can already do. hit properties & just edit away unless you're talking about using the same line every time automatically.
Old 24th March 2008, 19:55   #1019  |  Link
ajamils
Yesterday, I converted Transformers 1080p to mp4. Original file was about 13Gb but after the conversion the mp4 file ended up being 1.5 GB only and when I played it on Ps3 it looked HORRIBLE with lots of microblocking and tearing.
What did I do wrong ?
ajamils is offline   Reply With Quote
Old 24th March 2008, 20:01   #1020  |  Link
You used default bitrate
