Old 19th January 2019, 20:22   #28321  |  Link
Lathe
Lathe's Avatar
Originally Posted by AmigaFuture View Post
Moving on.. I think it's good for JD to refocus in some other ways for a bit.
That B@stard!!!
Imagine... food for his family...???!
... and here we sit...
Old 24th January 2019, 04:30   #28322  |  Link
MrVideo
MrVideo's Avatar
Enhancement request
Add an option to ignore delay values that BDRB finds via mediainfo.
Too many times I've run into an issue where BDRB screws with the video/audio delay on files that have no issues when played, but end up having issues after being run through BDRB.
The latest example is where the first five frames of the video were removed, resulting in the audio appearing to be delayed by said amount. All 12 episode files were affected. The special feature files had 125ms issues. All source files were MKV wrapped h.264 23.976 videos.
Mediainfo showed that both the video AND audio had the same delay, which to me means the delay should cancel out.
Thanks for considering this.
Old 24th January 2019, 23:11   #28323  |  Link
Rich86
Rich86's Avatar
BDRB 60.04 - convert BD to DVD-5
BDRB 60.04 is unable to convert a BD to DVD in movie only mode. It immediately fails after extracting the contents of the source video file. This problem began with version 60.02.
My test was with "Alpha".
MultiAvcHD handled converting Alpha from BD to DVD just fine.
BDRB is able to process the source material to make a movie only BD of Alpha just fine.
Rich86 is offline   Reply With Quote
Old 25th January 2019, 09:06   #28324  |  Link
omegaman7
omegaman7's Avatar
You probably just came across the problem I had. (HERE)
Replace HCENCODER with another version.
I don't believe JDobbs has replaced the supplied version on page one. Since the update was in october, and our conversation was in November.
Old 25th January 2019, 21:42   #28325  |  Link
Rich86
Rich86's Avatar
Thanks. I had described this problem a while ago on a different title:
https://forum.doom9.org/showthread.p...47#post1856347
but never noticed JDobbs post about the cause.
Old 25th January 2019, 22:42   #28326  |  Link
omegaman7
omegaman7's Avatar
You bet.
Not often I can contribute to the thread lol
Old 26th January 2019, 22:56   #28327  |  Link
sidneysides
It's been a number of years since I used BD Rebuilder so please forgive me if I ask something that has already been covered in the thousands of preceding pages..
I decided to have a go at converting a full UHD to a 4K 25gb (keeping structure, resolution etc.). It appeared to work, but the menu stuttered and there were sync issues in the movie. Is this what JDobbs is seeing at the moment in the UHD issues?
sidneysides is offline   Reply With Quote
Old 27th January 2019, 01:48   #28328  |  Link
Lathe
Lathe's Avatar
Well, actually, he's taking time to feed his family, if you can believe that...
But... maybe when he's done being sidetracked, he just MIGHT remember that we are all hanging here!
Old 28th January 2019, 12:55   #28329  |  Link
Sidneymack
Does anyone know if its possible to create a quick play blu ray without having a menu? Say i wanted to add 10 episodes of (insert tv show here) but just wanted them to play one after the other without having to select from the menu each time.
I've looked in hidden options but couldn't see anything.
Sidneymack is offline   Reply With Quote
Old 28th January 2019, 14:43   #28330  |  Link
MrVideo
MrVideo's Avatar
It's not in the hidden. Have you tried setting MENU_PLAY_SEQUENTIAL=1
Old 28th January 2019, 15:44   #28331  |  Link
musiclover
Look at Import/Quick-play settings and check 'play items sequentially'
Old 28th January 2019, 16:06   #28332  |  Link
Yes. That will still create a menu -- but it won't go back to the menu between episodes, it will advance to the next episode instead.
Old 28th January 2019, 16:15   #28333  |  Link
Sidneymack
Great, thanks for the info guys.
Found the option in the Quickplay settings and see that it changed MENU_PLAY_SEQUENTIAL to 1 in the ini file. Can't believe I've missed it.
Will test this out tonight.
Would an option to not include a menu be on the cards for the future?
Old 28th January 2019, 17:05   #28334  |  Link
Not likely. That would just be the same thing as combining all the episodes together as one big video file.
Old 28th January 2019, 21:12   #28335  |  Link
AmigaFuture
AmigaFuture's Avatar
You bet.
Good to see you! Even if you're forgetful and call people by the name "lol". Anyway, I know the feeling; about helping. It's a time difference and Instant Email Notification and Read thing...which I'm not into. In part, I jest.
I always replace the HCencoder with HCEncoder025. Don't have any problems...and it's slightly quicker.
Old 29th January 2019, 10:38   #28336  |  Link
musiclover
That version is already in jdobbs' distribution
Old 29th January 2019, 23:09   #28337  |  Link
...since 2014, I believe.
Old 1st February 2019, 18:34   #28338  |  Link
sandrino3867
When you release next BDR ?
sandrino3867 is offline   Reply With Quote
Old 2nd February 2019, 01:32   #28339  |  Link
Ch3vr0n
When he and it's ready to do that, not a moment sooner.
Verstuurd vanaf mijn Nexus 6P met Tapatalk
Old 2nd February 2019, 02:13   #28340  |  Link
Blurayhd
Hi all hi Jdobbs last week I use BD rebuilder for encoding some backups to BD25 and burn to Bluray disc, I need to verify that disc and other disc that I burn months ago, I really want to, I mean verify the disc estructure so I can see if any disc have some bad sectors? just like DVDisaster does but some another similar graphical tool that you can recommend?
I tried with IMGburn but with one device burner IMGburn in some sectors just slow the read speed but do the job I mean IMGbung create the ISO anyway
When I tried the same but with other device burner IMGburn just canŽt read that sectors and get me an error
For that if you just could recomend some tool for see that sectors IŽll appreciate
