12th June 2014, 18:47 | #163 | Link |
@von Suppé: I think I found the bug - a threading issue that could cause two different bitmaps to write to same header... which is of course very very bad!
C# source code change is here: https://github.com/SubtitleEdit/subtitleedit/commit/61ebdd92ea28cb959d1fc8582e5c23c1fc09b50e Test version here: http://www.nikse.dk/SubtitleEdit.zip (.net 4, current source, portable version) @mood: You can use ssa/ass for boxes in the main window |
13th June 2014, 16:40 | #166 | Link |
Greetings.
The subtitle duration change tool seems to limit the amount to 1sec. Is there a way to get around this? If not, would anyone be kind enough suggest alternatives? Something simple for srt subs would suffice. Thank you and best regards. |
13th June 2014, 17:33 | #167 | Link |
@Music Fan: Sorry, I never got around to it...
@marianer: I've added a few more values: http://www.nikse.dk/SubtitleEdit.zip (portable version, beta), or you could use percent or re-calculate durations using chars per sec |
14th June 2014, 14:53 | #168 | Link | |
It would be great if you could also include +10. Many thanks for providing this extremely useful tool. |
16th June 2014, 18:51 | #170 | Link |
The latest testversion from http://www.nikse.dk/SubtitleEdit.zip gives the following error when being run on Windows 7 32bit.
--> Screenshot I forgot to make a backup of the previous testversion, anyone know of a working recent testversion please ? Last edited by Betsy25; 16th June 2014 at 18:59. |
16th June 2014, 20:01 | #171 | Link |
@mariner: np, added here: http://www.nikse.dk/SubtitleEdit.zip
@Music Fan: I don't have any sample files - but it's probably not something that's very easy to add, but I don't mind taking a look if you think it will be useful (this format is probably dead, right?) @Betsy25: Ups yes, try the above version. |
18th June 2014, 13:23 | #172 | Link | |
Having a little trouble with BD sup creation. It seems PotPlayer/PDVD only displays the sup created using Simple Rendering, while MPC-BE doesn't not have such issue. Appreciate if you could look into it. Finally, how does one play with the Alpha setting? Many thanks and best regards. |
23rd June 2014, 20:23 | #173 | Link | |
You can now change alpha in the color picker dialog |
24th June 2014, 06:17 | #174 | Link | |
1. It appears "normally rendered" sups only work with PotPlayer if Shadow Width is set to 0. Alpha setting doesn't seem to have any effect. Another interesting observation: if fed into BDSup2Sub and saved without any changes, the new sup works. 2. The 3.3.15 seems to have problem retaining "960x540" video resolution setting. The XML output shows "640x272". 3. Is there a way for SubEdit to transform the following timecoed format into proper srt sub with a fixed duration? Code:
00:00:02.000 aaaa bbbb . . Many thanks and best regards. |
24th June 2014, 07:11 | #175 | Link |
1) I'm pretty sure it's an alpha setting thing... and I'm also pretty sure that next version of PotPlayer will be able to play bdsup files with partly transparent shadow or box
2) What and how exactly? 3) Post or email a more complete file and I'll take a look. |
24th June 2014, 07:51 | #176 | Link |
Just a side remark - test the software against hardware players, otherwise you may end with a product that is custom-taylored to a player (in this case PotPlayer) that tomorrow may change.
Born in the USB (not USA) |
24th June 2014, 12:07 | #177 | Link | |||
0.sup has 0 shadow width and works with PorPlayer, 1.sup has SW=1 Alpha=255, and does not work, 1_exp.sup is processed by BDSup2Sub and works. sup.zip Quote:
<?xml version="1.0" encoding="UTF-8"?> <BDN Version="0.93" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="BD-03-006-0093b BDN File Format.xsd"> <Description><Name Title="subtitle_exp" Content="" /><Language Code="eng" /> <Format VideoFormat="640x272" FrameRate="25" DropFrame="False" /> <Events Type="Graphic" FirstEventInTC="00:00:02:00" LastEventOutTC="00:10:01:13" NumberofEvents="4" /> </Description><Events><Event InTC="00:00:02:00" OutTC="00:00:12:00" Forced="False"> <Graphic Width="470" Height="260" X="245" Y="260">0001.png</Graphic> </Event> <Event InTC="00:04:41:12" OutTC="00:04:51:12" Forced="False"> <Graphic Width="470" Height="194" X="245" Y="326">0002.png</Graphic> </Event> <Event InTC="00:05:55:00" OutTC="00:06:05:00" Forced="False"> <Graphic Width="438" Height="194" X="261" Y="326">0003.png</Graphic> </Event> <Event InTC="00:09:51:13" OutTC="00:10:01:13" Forced="False"> <Graphic Width="437" Height="194" X="261" Y="326">0004.png</Graphic> </Event> </Events></BDN> Quote:
00:00:02.000 Junior Semifinal, part 1 Aidiba Talamunuer, Berezan Bogdan Voloshin, Yaroslavl Alexandr Doronin, Almaty 00:04:41.480 G. Zhubanova «Kui» Aidiba Talamunuer, Berezan 00:05:55.000 N. Mendigaliev «Steppe» Bogdan Voloshin, Yaroslavl 00:09:51.520 A. Lokshin «Dance» Alexandr Doronin, Almaty Last edited by mariner; 24th June 2014 at 12:10. |
24th June 2014, 12:14 | #178 | Link | |
SE has the unique ability to create sups with non standard video resolution. Want to make sure everything is in order. |
25th June 2014, 19:16 | #180 | Link |
@mariner: Could you test this version: http://www.nikse.dk/SubtitleEdit.zip (beta, portable version) - does the file format work + resolution? (if not, how to you get to the export bdn xml window?)
Notice that both "border" and "shadow" can have alpha adjusted. @Music Fan: OK, I'll use my time for preparing SE 3.4 instead |
