Old 18th August 2018, 13:08   #381  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
It is from the single precision mvtools in vapoursynth, which is based on dubhater's mvtools port.
The new block sizes: 2x2, 64x64, 64x32, 128x128, 128x64, 256x256, 256x128 is added in r6.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 18th August 2018, 13:33   #382  |  Link
StainlessS
StainlessS's Avatar
Thanks Wolfberry.
I sometimes post sober.
Old 18th August 2018, 14:47   #383  |  Link
Selur
Selur's Avatar
Ah okay, wasn't aware that the values for SAD differed
Old 29th December 2018, 20:34   #384  |  Link
Revan654
Revan654's Avatar
Not sure if anyone can help but I was wonder if what everyone uses for there values with this filter. I having some issue with it on Vapoursynth side(Avisynth always had issues and could never get it to work correctly)
With either avisynth or VapourSynth anyone what are good values to use without destroying the text/font in the picture. My issue currently with mclean it fixes the picture very nicely however warps the text(Like if the picture has a logo or something like that), it looks like it oversharpens it(Even if I set sharpen to 0).
Revan654 is offline   Reply With Quote
Old 12th May 2021, 22:10   #385  |  Link
creeve4
I am using mClean as a plugin with Staxrip. When using Avisynth+ and 4k video, I am getting the following error:
Script Error
Resize: Planar destination height must be a multiple of 2.
(C:\StaxRip-v2.5.0-x64\Apps\Plugins\AVS\mClean\mClean.avsi, line 100)
I am not resizing the videos and the dimensions of the videos are all divisible by 2.
creeve4 is offline   Reply With Quote
Old 12th May 2021, 22:41   #386  |  Link
StainlessS
StainlessS's Avatar
Problem causer
sc =  defH>2800 ? 8 : defH>1400 ? 4 : defH>720 ? 2 : 1
and this
super =  MSuper (BicubicResize(chroma ? defined(fvec1) ? fvec1 : c : defined(bvec1) ? bvec1 : cy, c.Width/sc, c.Height/sc),
            \  hpad=16/sc, vpad=16/sc, rfilter=4)
Maybe try mod [EDIT: Line 100]
super =  MSuper (BicubicResize(chroma ? defined(fvec1) ? fvec1 : c : defined(bvec1) ? bvec1 : cy, c.Width/(sc*2)*2, c.Height/(sc*2)*2),
EDIT: I have not tried it, it may work, or may not, Burfadel needs to look at it.
EDIT: if say your height is, defH>2800, then sc=8, and then your height has to be a multiple of (8 * 2), else error.
EDIT: Above fix probably will not work, sc is a bit more invloved later in script, author needs to fix it.
Old 13th May 2021, 01:28   #387  |  Link
creeve4
Thank you for digging into this!
I'll stick with Vaporsynth for now. It seems the the port of mClean for Vaporsynth does not have this bug.
Old 13th May 2021, 05:33   #388  |  Link
kedautinh12
Can you fix it now, Stainless?? I think development don't online now
Old 13th May 2021, 13:12   #389  |  Link
Frank62
You may also simply use:
addborders(0,0,0,2) (or 4, or 6)
filter
crop(0,0,-0,-2) (or -4 or -6)
Frank62 is offline   Reply With Quote
Old 13th May 2021, 15:32   #390  |  Link
StainlessS
StainlessS's Avatar
Suggest as Frank62 says above, but with slight mod.
function Padding(clip c, int left, int top, int right, int bottom) {
    # Didee: http://forum.doom9.org/showthread.php?p=1596804#post1596804
    # eg, Padding(32,32,0,0).Padding(0,0,32,32)
    w = c.width()
    h = c.height()
    c.pointresize( w+left+right, h+top+bottom, -left, -top, w+left+right, h+top+bottom )
c=Colorbars.convertToYV12
WMOD=(8*2) # substitute whatever for 8
HMOD=(8*2) #   Ditto
P_RGT=(c.Width  % WMOD == 0) ? 0 : (WMOD - (c.Width  % WMOD))
P_BOT=(c.Height % HMOD == 0) ? 0 : (HMOD - (c.Height % HMOD))
c=c.Padding(0,0,P_RGT,P_BOT)
#c=c.YourFilter
c=c.crop(0,0,-P_RGT,-P_BOT)
c
Better using Padding rather than black addborders, untested (other than not crash) but should be about right.
Old 13th May 2021, 16:34   #391  |  Link
Frank62
More complicated but also more elegant.
Old 14th May 2021, 07:05   #392  |  Link
JKyle
App Digger
JKyle's Avatar
    w = c.width()
    h = c.height()
HMOD=(8*2) #   Ditto
#c=c.YourFilter
c
Thanks for the idea, @StainlessS.
Based on your suggestion, I modified the script source so that padX and padY should be based on mod 16, not mod 8 as in the original script.
And instead of using addborders, I adopted Padding and attached its definition at the bottom of the script source.
Here's the source.
# mClean spatio/temporal denoiser
# Version: 3.2 (01 March 2018)
# By burfadel
# Version: 3.2 mod J (2021-05-13)
# By JKyle
# Original idea by StainlessS
# https://forum.doom9.org/showthread.php?p=1942788#post1942788
# Replaced addborders with Padding
# Fixed the bug that source should be mod 16 if defH>2800
#  +++ Description +++
# Typical spatial filters work by removing large variations in the image on a small scale, reducing noise but also making the image less
# sharp or temporally stable. mClean removes noise whilst retaining as much detail as possible, as well as provide optional image enhancement
# mClean works primarily in the temporal domain, although there is some spatial limiting
# Chroma is processed a little differently to luma for optimal results
# Input must be 8-bit Planar type (YV12, YV16, YV24) or their equivalents in 10, 12, 14, or 16 bits
# Chroma processing can be disabled with chroma=false
#  +++ Artifacts +++
# Spatial picture artifacts may remain as removing them is a fine balance between removing the unwanted artifact whilst not removing detail
# Additional dering/dehalo/deblock filters may be required, but should ONLY be uses if required due the detail loss/artifact removal balance
#  +++ Sharpening +++
# Applies a modified unsharp mask to edges and major detected detail. Range of normal sharpening is 0-20, the default 10. There are 4 additional
# settings, 21-24 that provide 'overboost' sharpening. Overboost sharpening is only suitable typically for high definition, high quality sources.
# Actual sharpening calculation is scaled based on resolution.
# +++ ReNoise +++
# ReNoise adds back some of the removed luma noise. Re-adding original noise would be counterproductive, therefore ReNoise modifies this noise
# both spatially and temporally. The result of this modification is the noise becomes much nicer and it's impact on compressibility is greatly
# reduced. It is not applied on areas where the sharpening occurs as that would be counterproductive. Settings range from 1 to 20, default
# value is 14. The strength of renoise is affected by the the amount of original noise removed and how this noise varies between frames. It's
# main purpose is to reduce the 'flatness' that occurs with any form of effective denoising.
# +++ Deband +++
# This will perceptibly improve the quality of the image by reducing banding effect and adding a small amount of temporally stabilised grain to
# both luma and chroma. The settings are not adjustable as the default settings are suitable for most cases without having a large effect on
# compressibility. Auto balance uses Autoadjust, it calculates statistics of the clip, stabilises temporally and adjusts luminance gain & colour
# balance of the noise reduced clip.
# 0=disabled, 1=deband only, 2=auto balance only, 3=both deband and auto balance, 4=deband and veed, 5=all
# +++ Depth +++
# This applies a modified warp sharpening on the image that may be useful for certain things, and can improve the perception of image depth. Default
# is 0 (disabled), and ranges up to 5. This function will distort the image, for animation a setting of 1 or 2 can be beneficial to improve lines. The
# effect
# +++ Strength +++
# The strength of the denoising effect can be adjusted using this parameter. It ranges from 20 percent denoising effect with strength 1, up to the
# 100 percent of the denoising with strength 20 (default). This function works by blending a scaled percentage of the original image with the processed
# image.
# +++ Outbits +++
# Specifies the bits per component (bpc) for the output for processing by additional filters. It will also be the bpc that mClean will process.
# By default, mClean processes as 12 bits if the input is 8 bit, and converts back to 8 bit. If the input is 10 bits or higher no conversion is
# done unless outbits is specified and is different to the input bpc. If you output at a higher bpc keep in mind that there may be limitations
# to what subsequent filters and the encoder may support.
#  +++ Required plugins +++
# Latest RGTools, MVTools2, Masktools2, f3kdb, Modplus, AutoAdjust
# Refer to https://forum.doom9.org/showpost.php?p=1834698&postcount=334
function mClean(clip c, int "thSAD", bool "chroma", int "sharp", int "rn", int "deband", int "depth", float "strength", int "outbits")
    defH        = Max (C.Height, C.Width/4*3)   # Resolution calculation for auto blksize settings
    thSAD       = Default (thSAD, 400)   # Denoising threshold
    chroma      = Default (chroma, true)   # Process chroma
    sharp       = Default (sharp, 10)   # Sharp multiplier
    rn          = Default (rn, 14)   # Luma ReNoise strength from 0 (disabled) to 20
    deband      = Default (deband, 4)   # Apply deband/veed and/or auto balance
    depth       = Default (depth, 0)   # Depth enhancement
    strength    = Default (strength, 20)   # Strength of denoising.
    outbits     = Default (outbits, BitsPerComponent(c))   # Output bits, default input depth
    calcbits    = BitsPerComponent(c) == 8 ? 12 : outbits
    Assert(isYUV(c)==true, """mClean: Supports only YUV formats (YV12, YV16, YV24)""")
    Assert(isYUY2(c)==false, """mClean: Supports only YUV formats (YV12, YV16, YV24)""")
    Assert(isYV411(c)==false, """mClean: Supports only YUV formats (YV12, YV16, YV24)""")
    Assert(sharp>=0 && sharp<=24, """mClean: "sharp" ranges from 0 to 24""")
    Assert(rn>=0 && rn<=20, """mClean: "rn" ranges from 0 to 20""")
    Assert(deband>=0 && deband<=5, """mClean: deband options 0 (disabled) to 5. Refer to description""")
    Assert(depth>=0 && depth<=5, """mClean: depth ranges from 0 (disabled) to 5""")
    Assert(strength>0 && depth<=20, """mClean: strength ranges from 1 (20%) to 20 (100%, default)""")
    Assert(outbits>=8 && outbits<=16, """mClean: "outbits" ranges from 8 to 16""")
# padX, padY modified to be based on mod 16, not mod 8 as in the original script
# modified by JKyle
padX       =  c.width%16 == 0 ? 0 : (16 - c.width%16)
padY       =  c.height%16 == 0 ? 0 : (16 - c.height%16)
c          =  padX+padY<>0 ? c.Padding(0, 0, padX, padY) : c
cy         =  ExtractY(c)
blksize    =  sc==8 ? 8 : ((defH/sc)/360)>1.5 ? 16 : ((defH/sc)/360)>0.8 ? 12 : 8
overlap    =  blksize>=12 ? 6 : 2
lambda     =  775*(blksize*blksize)/64
sharp      =  sharp>20 ? sharp+30 : DefH<=2600 ? 16+round(defH*(34/2600)*sharp/20) : 50
depth      =  depth*2
depth2     =  -(depth+(depth/2))
# Denoise preparation
c           =  chroma ? Median (c, yy=false, uu=true, vv=true) : c
# Temporal luma noise filter
fvec1       =  bitspercomponent(c)>8 ? convertbits(c, 8) : undefined()
bvec1       =  bitspercomponent(cy)>8 ? convertbits(cy, 8) : undefined()
super2      =  MSuper (chroma ? defined(fvec1) ? fvec1 : c : defined(bvec1) ? bvec1 : cy, hpad=16, vpad=16, levels=1)
# --> Analysis
bvec4       =  MRecalculate(super2, MscaleVect (MAnalyse (super, isb = true, delta = 4, blksize=blksize, overlap=overlap), sc),
            \  blksize=blksize, overlap=overlap, lambda=lambda, thSAD=180)
bvec3       =  MRecalculate(super2, MscaleVect (MAnalyse (super, isb = true, delta = 3, blksize=blksize, overlap=overlap), sc),
bvec2       =  MRecalculate(super2, MscaleVect (MAnalyse (super, isb = true, delta = 2, blksize=blksize, overlap=overlap,
            \  badSAD=1100, lsad=1120), sc), searchparam=3, blksize=blksize, overlap=overlap, lambda=lambda, thSAD=180)
bvec1       =  MRecalculate(super2, MscaleVect (MAnalyse (super, isb = true, delta = 1, blksize=blksize, overlap=overlap, badSAD=1500, badrange=27,
            \  search=5, lsad=980), sc), blksize=blksize, overlap=overlap, search=5, searchparam=3, lambda=lambda, thSAD=180)
fvec1       =  MRecalculate(super2, MscaleVect (MAnalyse (super, isb = false, delta = 1, blksize=blksize, overlap=overlap, badSAD=1500, badrange=27,
fvec2       =  MRecalculate(super2, MscaleVect (MAnalyse (super, isb = false, delta = 2, blksize=blksize, overlap=overlap,
fvec3       =  MRecalculate(super2, MscaleVect (MAnalyse (super, isb = false, delta = 3, blksize=blksize, overlap=overlap), sc),
fvec4       =  MRecalculate(super2, MscaleVect (MAnalyse (super, isb = false, delta = 4, blksize=blksize, overlap=overlap), sc),
# --> Bit depth conversion
c           =  chroma ? calcbits != BitsPerComponent(c) ? ConvertBits(c, calcbits) : c : c
super2      =  calcbits != BitsPerComponent(super2) ? ConvertBits(super2, calcbits) : super2
cy          =  calcbits != BitsPerComponent(cy) ? ConvertBits(cy, calcbits) : cy
# --> Applying cleaning
clean       =  MDegrain4(chroma ? c : cy, super2, bvec1, fvec1, bvec2, fvec2, bvec3, fvec3, bvec4, fvec4, thSAD=thSAD)
u           =  chroma ? ExtractU(clean) : nop ()
v           =  chroma ? ExtractV(clean) : nop ()
filt_chroma =  chroma ? CombinePlanes(c, mt_adddiff(u, clense(mt_makediff(ExtractU(c), u), reduceflicker=true)), mt_adddiff(v,
            \  clense(mt_makediff(ExtractV(c), v), reduceflicker=true)), planes="yuv", source_planes="yyy", sample_clip=c) : c
clean       =  chroma ? ExtractY(clean) : clean
# Post clean, pre-process deband
filt_chroma_bits =  BitsPerComponent(filt_chroma)
clean2           =  deband==0 ? nop() : ConvertBits(clean, 8)
noise_diff       =  deband==0 ? nop() : BitsPerComponent(c)==8 ? nop() : mt_makediff(convertbits(clean2, calcbits), clean)
depth_calc       =  deband==0 ? nop() : CombinePlanes (clean2, filt_chroma_bits>8 ? ConvertBits(filt_chroma, 8) : filt_chroma, planes="YUV",
                 \  source_planes="YUV", pixel_type="YV12")
depth_calc       =  deband==0 ? nop() : deband>1 ? deband==4 ? depth_calc : AutoAdjust (depth_calc, auto_gain=true, bright_limit=1.09, dark_limit=1.11,
                 \  gamma_limit=1.045, auto_balance=true, chroma_limit=1.13, chroma_process=115, balance_str=0.85) : depth_calc
depth_calc       =  deband==0 ? undefined() : deband<>2 ? f3kdb (depth_calc, preset=chroma?"high":"luma", range=16, grainY=38*(defH/540),
                 \  grainC=chroma?37*(defH/540):0) :depth_calc
clean            =  deband==0 ? clean : BitsPerComponent(c)==8 ? ExtractY (depth_calc) : mt_adddiff(ConvertBits(ExtractY
                 \  (depth_calc), calcbits), noise_diff)
depth_calc       =  deband==0 ? nop() : BitsPerComponent(depth_calc)<>filt_chroma_bits ? ConvertBits(depth_calc, filt_chroma_bits) : depth_calc
filt_chroma      =  deband==0 ? filt_chroma : deband>4 ? veed(depth_calc) : depth_calc
# Spatial luma denoising
clean2      =  removegrain(clean, 18)
# Unsharp filter for spatial detail enhancement
clsharp     =  sharp>0 ? sharp>=51<=54 ? mt_makediff(clean, gblur(clean2, (sharp-50), sd=3)) :
            \  mt_makediff(clean, blur(clean2, 1.58*(0.03+(0.97/50)*sharp))) : nop()
clsharp     =  mt_adddiff(clean2, repair(clense(clsharp), clsharp, 12))
# If selected, combining ReNoise
noise_diff  =  mt_makediff (clean2, cy)
clean2      =  rn>0<=20 ? mt_merge(clean2, mergeluma (clean2, mt_adddiff(clean2, tweak(clense(noise_diff, reduceflicker=true), cont=1.008+(0.0032*(rn/20)))),
            \  0.3+(rn*0.035)), mt_lut (overlay(clean, invert(clean), mode="darken"), "x 32 scaleb < 0 x 45 scaleb > range_max 0 x 35 scaleb - range_max 32
            \  scaleb 65 scaleb - / * - ? ?")) : clean2
# Combining spatial detail enhancement with spatial noise reduction using prepared mask
noise_diff  =  mt_invert(mt_binarize(noise_diff))
clean2      =  sharp>0 ? mt_merge (clean2, clsharp, overlay(noise_diff, mt_edge(clean, "prewitt"), mode="lighten")) :
            \  mt_merge (clean2, clean, overlay(noise_diff, mt_edge(clean, "prewitt"), mode="lighten"))
# Converting bits per channel and luma format
filt_chroma =  outbits < BitsPerComponent(filt_chroma) ? ConvertBits(filt_chroma, outbits, dither=1) : ConvertBits(filt_chroma, outbits)
clean2      =  outbits < BitsPerComponent(clean2) ? ConvertBits(clean2, outbits, dither=1) : ConvertBits(clean2, outbits)
c           =  BitsPerComponent(c) <> BitsPerComponent(clean2) ? ConvertBits(c, BitsPerComponent(clean2)) : c
# Combining result of luma and chroma cleaning
output      =  CombinePlanes(clean2, filt_chroma, planes="YUV", source_planes="YUV", sample_clip=c)
output      =  strength<20 ? Merge(c, output, 0.2+(0.04*strength)) : output
depth_calc  =  depth>0 ? defh>640 ? bicubicresize(output, 720, 480) : output : nop()
output      =  depth>0 ? mt_adddiff(output, spline36resize(mt_makediff(awarpsharp2(depth_calc, depth=depth2, blur=3),
            \  awarpsharp2(depth_calc, depth=depth, blur=2)), output.width, output.height)) : output
output      =  padX+padY<>0 ? output.crop(0, 0, -padX, -padY) : output
return output
    # Didée: http://forum.doom9.org/showthread.php?p=1596804#post1596804
    w = c.width()
    h = c.height()
I think it has no problem with 4K inputs now.
JKyle is offline   Reply With Quote
Old 14th May 2021, 07:20   #393  |  Link
kedautinh12
Thanks, but need replace f3kdb to neo-f3kdb for speed and i think Vcmohan rename modplus to manyPlus
http://www.avisynth.nl/users/vcmohan.../manyPlus.html
Old 14th May 2021, 07:43   #394  |  Link
JKyle
App Digger
JKyle's Avatar
Thanks for the info.
Added as a note in the script.
# By burfadel
# By JKyle
# Fixed the bug that the source should be processed based on mod 16 if defH>2800
# Replaced f3kdb with neo_f3kdb
#  +++ Artifacts +++
# +++ ReNoise +++
# +++ Deband +++
# +++ Depth +++
# effect
# +++ Strength +++
# image.
# +++ Outbits +++
# Latest RGTools, MVTools2, Masktools2, neo_f3kdb, Modplus(renamed to manyPlus as it is merged with other plugins, 2021-04-21), AutoAdjust
# For neo_f3kdb, visit https://github.com/HomeOfAviSynthPlusEvolution/neo_f3kdb
# For Modplus(manyPlus), visit http://www.avisynth.nl/users/vcmohan/manyPlus/manyPlus.html (info by kedautinh12)
# modified by JKyle
cy         =  ExtractY(c)
depth      =  depth*2
# --> Analysis
depth_calc       =  deband==0 ? undefined() : deband<>2 ? neo_f3kdb (depth_calc, preset=chroma?"high":"luma", range=16, grainY=38*(defH/540),
return output
    w = c.width()
    h = c.height()
Old 14th May 2021, 07:50   #395  |  Link
kedautinh12
Old 14th May 2021, 11:43   #396  |  Link
JKyle
App Digger
JKyle's Avatar
Instead of using the original Padding function by Didée, I adopted sh_Padding (an MT version of Padding) in Zs_RF_Shared.avsi in order to improve the processing speed of the script when the source is not mod 16.
So you need to import Zs_RF_Shared.avsi along with other dependencies before calling this mClean script.
Here's the updated code:
# By burfadel
# Version: 3.2 mod J (2021-05-14)
# By JKyle
# Replaced addborders with sh_Padding in Zs_RF_Shared.avsi
#  +++ Artifacts +++
# +++ ReNoise +++
# +++ Deband +++
# +++ Depth +++
# effect
# +++ Strength +++
# image.
# +++ Outbits +++
# and Zs_RF_Shared.avsi
# For Zs_RF_Shared.avsi, visit https://github.com/realfinder/AVS-Stuff/blob/Community/avs%202.5%20and%20up/Zs_RF_Shared.avsi
# modified by JKyle
c          =  padX+padY<>0 ? c.sh_Padding(0, 0, padX, padY) : c
cy         =  ExtractY(c)
depth      =  depth*2
# --> Analysis
return output
Old 14th May 2021, 14:58   #397  |  Link
kedautinh12
Thanks for your hardwork
Old 15th May 2021, 01:10   #398  |  Link
JKyle
App Digger
JKyle's Avatar
I fixed another error that the script does not work when the source is YUV422 or YUV444.
I hope this will be the final version.
3.2 Jmod 4
# By burfadel
# Version: 3.2 Jmod 4 (2021-05-14)
# By JKyle
# Original idea by StainlessS (https://forum.doom9.org/showthread.php?p=1942788#post1942788)
# Fixed error when the source is 4K and cropped
# Replaced `f3kdb` with `neo_f3kdb`
# Replaced `addborders` with `sh_Padding` in `Zs_RF_Shared.avsi`
# Fixed error when the source is YUV422 or YUV444
#  +++ Artifacts +++
# +++ ReNoise +++
# +++ Deband +++
# +++ Depth +++
# effect
# +++ Strength +++
# image.
# +++ Outbits +++
# `padX`, `padY` modified to be based on mod 16, not mod 8 as in the original script (JKyle)
# Replaced `addborders` with `sh_Padding` in `Zs_RF_Shared.avsi` (JKyle)
cy         =  ExtractY(c)
depth      =  depth*2
# --> Analysis
# Different color formats are returned for `depth_calc` depending on the source chroma subsampling scheme (JKyle)
                 \  source_planes="YUV", pixel_type = Is420(c) ? "YV12" : Is422(c) ? "YV16" : "YV24")
# Replaced `f3kdb` with `neo_f3kdb` (JKyle)
return output
Old 18th September 2021, 17:25   #399  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I'm trying mClean on GoPro 5K footage.
clip = G41Fun.mClean(clip, thSAD=400, chroma=True, sharp=21, rn=14, deband=1, depth=0, strength=20)
In certain cases it's working well, especially on low-light footage with considerable noise.
When only certain parts of the video have noise, however, waterfall gets blurred, skin and beard gets blurred, and moving background gets blurred.
KNLMeansCL doesn't blurry those parts as much; but it does make the overall image softer (plus I've set GoPro's sharpening to Low to reduce sharpening of noise). I do like mClean's overboost sharpening (21).
How can I better process my GoPro footages? Since it's struggling with low-light situations, perhaps have dynamic "str" based on Luma? Any other ideas?
Here's a sample 20-frame 5K video clip. It has noise at the top and on the seat, moving background, and skin/beard texture to keep. Overall image could be denoised and then sharpened a bit. If you can get something to do a good job here, then it will work much better on all sources overall.
MysteryX is offline   Reply With Quote
Old 18th September 2021, 21:57   #400  |  Link
Dogway
You can try retinex, it's designed for low light. I will give the clip a whirl. That dynamic word gave an idea to run MDegrain in runtime with variable strength.
EDIT: sorry I can't really test, mClean hangs with this clip, also I saw it's not very dark?
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
cleaning, denoise, denoiser, mclean
