Old 14th June 2018, 21:01   #81  |  Link
WorBry
Yes, that hits a nice balance. I got a bit preoccupied trying to get a browner tone to the coloration on the shell, but at that depth it's probably more how you've got it...you were there after all. I could swing it more to that tone, and had it there at one point in my tweakings, but agree, I think we're done with "toupe turtle".
Would you mind uploading the Vdub project for that one also - I'd like to see how you got there - presumably all color balancing done with the '6-axis corrector' ?
I am looking at the other clips btw and will post some results when I'm happy with them, again with a view to replicating whatever I can come up with in Resolve using VDub and hopefully AVISynth, ideally avoiding the need for qualifier masks and the like.
@Tormento, if you are still looking in, hope you are trying some of these techniques. I could post the channel mixes I used, but really there's no substitute for getting in there and pushing the colors around. As one Colorist famously said "I just bang the knobs until it doesn't suck anymore".
Edit: btw Shekh, would I be right in concluding that the Trigger Fish in the two clips have different colorations. The one in GOPR0304 definitely matches with a 'Titan' Trigger Fish':
https://previews.123rf.com/images/vi...in-red-sea.jpg
On the other fish (in G0PR1596) the patch above the mouth appears more yellow, the patch under the mouth looks paler (whitish) and the tail stripe is tan colored, not orange. The matrix pattern on body of the GOPR0304 fish also has a deeper yellowish/green (iridescent) tone to it.
Seems unlikely that it's just the way the light affects the colours and how they appear after correction. Just don't want to beat myself up trying to get them to match when they are different fish.
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 15th June 2018, 11:43   #82  |  Link
shekh
https://gist.github.com/shekh/bfa7d5...70-1-vdproject
In this setup I used a new plugin (hqdn3d), currently you can get it here: https://sourceforge.net/projects/vdf...d/version%201/
(Btw how does hqdn3d compare to smdegrain?)
The fish: can't tell really. I think same species.
VirtualDub2
Old 16th June 2018, 05:00   #83  |  Link
WorBry
I haven't used hqdn3d for years, but at one point it was my routine denoiser for cleaning up DV video. Great to have it available for VDub2.
As for the Trigger Fish. Here are my Resolve corrected results. Again, just channel mixer, levels, contrast, mid-tone detail and a little sharpening.
Clip GOPR1596:
Original:
Corrected:
Pre-denoised and corrected:
Clip GOPR0304:
Original:
Corrected:
See what I mean about the difference in coloration though?
I've seen some images of 'Titan' Trigger Fish where the coloration is more like the one in GOPR1596 where the stripe on the tail is
https://i.pinimg.com/originals/e1/4c...67b27bfc44.jpg
So maybe it's just the way the light picks-up/accentuates the colors, or maybe there are variants within that species with different degrees of pigmentation. I'm pretty confident though that both corrected clips are balanced to neutral or close to it. There's no way I could shift the balance to get the colors of one of the fish closer to the other without throwing the global balance out of whack. Maybe possible using multiple qualifier masks but that's somewhat artificial.
I'll see how well I can replicate those results with VDub2.
Old 16th June 2018, 09:44   #84  |  Link
tormento
Acid fr0g
tormento's Avatar
Sirs... your efforts are great but we are going slightly off topic.
The original question was a hopefully automatic way to recover red missing video files with AVISYNTH
Can I lead your great work to something we can replicate in that environment? GamMac and FredAverage, perhaps?
@turment on Telegram
Old 16th June 2018, 10:52   #85  |  Link
StainlessS
StainlessS's Avatar
I would not expect GamMac to be able to ever do anything for your supplied clips.
I sometimes post sober.
Old 17th June 2018, 00:36   #86  |  Link
shekh
tormento,
Asymptotically I'm interested in the automated process and this discussion helps to understand what transforms are required to get some decent result (whether automated or not).
Also it helps to know how to solve the problem manually, because it gives some reference to compare with.
VirtualDub2
Old 17th June 2018, 15:17   #87  |  Link
shekh
Split thread: https://forum.doom9.org/showthread.php?t=175536
Old 18th June 2018, 01:57   #88  |  Link
WorBry
By way of closure on my part - here's a go at correcting your sample video manually with AVISynth using only Channel Mixer for the color balancing.
I deliberated whether to apply the levels/contrast adjustments in RGB space or after conversion back to YV12. I opted for RGB using RGBAdapt which offers centre-relative contrast.
DGSource("{Path}\2018_0525_135958_020.dgi",fieldop=0)
#Denoise:
SMDegrain(tr=1, thSAD=400, truemotion=false, contrasharp=true)
ConvertToRGB(matrix="rec709", interlaced=false)
#Correct color balance:
ChannelMixer(RR=97.5, RG=129.2, RB=-21.5,
\                   GR=23.0, GG=102.0, GB=0.0,
\                   BR=113.0, BG=-13.8, BB=82.0)
#Levels & contrast adjustment:
RGBADapt(R_Cont=1.1,G_Cont=1.1,B_Cont=1.1,
\       R_Bias=15.0,G_Bias=15.0,B_Bias=15.0,
\       R_Gain=1.1,G_Gain=1.1,B_Gain=1.1)
ConvertToYV12(matrix="rec709")
#Sharpen with filter of choice:
LSFMod(smode=3,strength=200)
I don't think I can bring anything else to the table in this context, other than more examples of the same.
Cheers.
Edit: BTW, in that correction I did with Resolve I used a qualifier to treat some vibrant magenta that was coming through on the edges of the anemone and diver outline also:
Originally Posted by WorBry View Post
Edit: Noticed feint magenta tinge to the blues after posting. This one, a bit less:
….opted for reconstructing the red channel (as best) with the RGB Channel mixer. Then just one qualifier to deal with some vibrant magenta coloration on the tips/edges of the anemone tentacles that stood out....
Realized subsequently that that can be treated with a little positive shift in the G-R sub-channel.
Old 20th June 2018, 11:44   #89  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks for your and everybody invaluable contributions to a niche area.
To complete discussion: is there any avisynth filter that can render optical filter output? I mean: red shallow water, red deep water, magenta green ones etc.
