27th November 2014, 01:08 | #27641 | Link | |
I can do 64 neurons with most stuff around 720 and 128 neurons under 480. And if I unlocked it's power constraints I could get a lot more, but I'm happy with how quiet it is and it's performance. |
27th November 2014, 07:05 | #27643 | Link |
Unlikely. And as I've said earlier it's almost pointless (barring text) to upscale 1280x720 using NNEDI, such a waste of processing for such a marginal improvement, but it'll depend on your content. I'd recommend enabling it and taking screenshots to see if you find the difference worth justifying the purchase of a graphics card hefty enough to do it.
27th November 2014, 10:21 | #27644 | Link |
I have a very strange issue: Madvr is causing sound distortion when i put on my headphones. Before you call me crazy... i spent an hour isolating the problem. I put MPC-HC at default setting and the sound was fine. Then i tried the stuff that i use one by one (LAV, etc.). The sound distortion only happened when i switched the renderer to Madvr.
Anyone have a clue as to why this would occur? I'm baffled. |
27th November 2014, 10:33 | #27645 | Link | |
HD7850 level AMD gpu can do it, which is cheaper than a 750ti. |
27th November 2014, 10:40 | #27646 | Link |
gpus on load can put some power on the case that effects onboard and none "high end" sound cards(not that rare have a PC that does this too). in my experience it affect the front speaker connector more than the one at the back panel.
27th November 2014, 10:49 | #27647 | Link | |
a sharper image is not a better one the downscaler adds aliasing and ringing nothing I like to see. |
27th November 2014, 14:17 | #27651 | Link |
yeah it's true that nnedi3 can works like a AA filter but that's not my point.
this only works for aliased source. my point is the downscaler that adds artefacts on top of the nnedi3 upscale (which are very very little). things like lanczos add more than a upsacler like jincs. lanczos is know for it aliasing and ringing of cause way more for its ringing. |
27th November 2014, 15:27 | #27652 | Link | |
Seems that you don't actually use NNEDI3 because everything you're saying is wrong. Jinc is not as good as NNEDI3 for sharpness or aliasing, and even madshi would tell you that. You don't have to use Lanczos for downscaling, obviously. Last edited by StinDaWg; 27th November 2014 at 15:37. |
27th November 2014, 15:40 | #27653 | Link | ||
Kid for Today
My 1Ghz factory overclocked 7850 can't do 720p60@1080p with NNEDI3 & monostatic ED1.
When Jinc showed up in mVR, even madshi agreed that it looked "analog" and this would also match my experience as live action movies look far more natural than with any other scaler. madshi also said that grass and trees looked weird sometimes with NNEDI3, there's no free lunch I'm afraid. Of course YMMV if you are using a >50" screen or a videoprojector with poor sharpness. Quote:
27th November 2014, 16:45 | #27654 | Link | |
27th November 2014, 17:32 | #27655 | Link |
I couldn't live without NNEDI3 on my 1440p display anymore. I use it to watch stuff like the news in 720p etc.
4k will be even more cruel, luckily a 970 OC is fast enough for 1080p image doubling with 32 neurons. 720p30 can be quadrupled to 1440p with 64 neurons, with 720p60 I have to go down to 32 neurons. Btw: Did you know that CUDA/OpenCL forces a Geforce to P2 powerstate? In it, memory clock won't go any higher than 3Ghz with GM204 GPUs. You have to use the tool Nvidia Inspector to overclock memory in P2 state to the default 3.5Ghz of P0 state. Mine even seems to overclock stable to 3.9Ghz (Samsung memory on MSI Gaming 970) which is 30% more bandwidth than P2 state default. May improve performance a little with bandwidth intensive compute stuff. I use ordered dithering as well, I've never encountered any benefit of ED. |
27th November 2014, 22:14 | #27656 | Link | |
but you have to use a downscaler that affects most of the work of nnedi3. 720p source with nnedi3 on 1440p screen is a hole different story. and the real question is. is it really worth to put so much power in it for the difference? you have to answer this question for your self. seeing a difference is not justifying the use for everyone. |
28th November 2014, 07:09 | #27657 | Link | |||
I did a much closer inspection at the pixel level and although what I did see looked nicer.. but it's impact for imperceivable change (on my screen) makes it not worth enabling. If your display's backlighting is affected when it's not disabled then there's a good reason for enabling it otherwise I'd recommend using ordered it really is almost as good, unless you just want "the best" and are willing to take the hit. I'd rather save the power for faster rendering or some extra neurons. Quote:
Simply saying "I watch a lot of sports so it's affect on graphics and text make it worthwhile" does not fly in the face of what I said at all. Now that I think about it, sports scenes where smaller objects are moving a lot could benefit more from NNEDI more perhaps, is this your experience? Perhaps the effect is more pronounced with higher fps also. Last edited by ryrynz; 28th November 2014 at 07:30. |
28th November 2014, 13:00 | #27658 | Link | |
The power argument is funny to me. Even using 32 neurons it's only taxing my gpu at about 35%, vs. 15% for Jinc3. So what, 20 or 30 watts more than Jinc? If I cared that much about saving power I would have never bought a plasma, which can use 200-250 watts during bright scenes. @ryrynz, I was responding to huhn when he said 720p->1080p was pointless. |
28th November 2014, 19:43 | #27659 | Link | ||
and feel free to show the differences. |
29th November 2014, 06:40 | #27660 | Link | |
Minuscule differences really don't interest me and I have yet to see a comparison (with normal movie content) which shows it to be worthwhile given the processing power required. |
