1st May 2016, 05:38 | #37661 | Link | |
Normal black level = full range. |
1st May 2016, 05:57 | #37662 | Link | |
YCbCr to limited RGB and full range RGB is creating float point data. if you have an YCbCr stream with only Y information limited range would create less banding but that is more than unrealistic. so full range RGB wins because float to 0-255 has less precision loss than float to 16-235. still a very small difference. |
1st May 2016, 09:52 | #37665 | Link | ||
Maybe it's the result of the combination of the 2 devices, I don't know. The point is everyone should experiment to see what's the best option for him/herself. I personally vote for Full range.
1st May 2016, 13:18 | #37667 | Link | |
what so ever madVR is clipping WTW and BTB with default settings and this is correct. |
1st May 2016, 13:24 | #37668 | Link | |
Visual Novel Dev.
Even if your source does output limited range, and not full range, why would you want to output software limited range? Would not the clipping effect be better if you output anyways to full range, and let the destination clip, if it does?
1st May 2016, 17:25 | #37671 | Link | |
1st May 2016, 17:57 | #37672 | Link | ||
they are not removed but that doesn't the mean display will remove them. the TV need limited range setting and the GPU full range YCbCr or limited range RGB will not work. this setup crushes colors on the desktop. still the second best setup you can do with madVR. it all depends on your screen anyway. on a properly calibrated screen WTW and BTB aren't shown but a correct signal is still needed. Quote:
if you connect a sat receiver, a ps3, a BD player, a PC with madVR and what ever to this AVR. with this setup you can easily run in problem with full range because not all devices support full range. so your PC is not the only thing in this system and not all can use full range RGB but all send there signal in the same HDMI port on your TV (source -> AVR -TV) which is on 99 % of all screen either full range or limited range depending on the settings. using YCbCr or limited range RGB is a viable solution in this case. BTW. full range is the "clipped" signal. if you really like to know more about this make a new thread this has little to do with madVR. |
1st May 2016, 18:04 | #37673 | Link | |
1st May 2016, 18:06 | #37674 | Link |
Thanks for replying. I'd like to do that but i am kind of a noob , i do not know how to manually enter display refresh rate (i only got a way to detect it through Direct draw or direct 3D, but does not change a thing). Besides i get some pre-configured media speed adpatations but nothing that can bypass the problem. If i knew a way to enter manually my refresh rate OR really manually adjust media speed adapatation, i certainly could do something... is it possible?
Anyway, i guess the bug as nothing to do with MAdvr because if i manually select a 3D resolution and play a 2D file, Reclock do think 23 Hz is 24hz too (works perfectly in 2D modes besides). One workaround would be if MAdvr could let us choose the display refresh rate for 3D modes (23 or 24 Hz) so i could put 24 Hz and let reclock work normaly. I will certainly try to post to nvidia and reclock boards but i am pretty sure it as 0 chance to change anything (because nvidia do not care about things like that and reclock is pretty dead). |
1st May 2016, 18:09 | #37675 | Link | ||
1st May 2016, 18:19 | #37676 | Link |
Ideally you want to convert from YCbCr to RGB and expand RGB to 0-255 at the same time in one step since the color space conversion works with floating point math that can be mapped to any output range you want with minimal loss. That means either sending YCbCr to the display and letting the display do both steps at once (which isn't an option for PCs since they work in RGB space and can't output native YCbCr), or doing the YCbCr to 0-255 RGB conversion in the PC. Unfortunately, some people may have a display that won't accept RGB 0-255 which means they have to use a less than ideal setup and have to pick between option 2 and 3 that huhn lists based on what all you're trying to use the PC for.
1st May 2016, 18:39 | #37677 | Link | |
1st May 2016, 19:47 | #37678 | Link | |
1st May 2016, 20:35 | #37679 | Link | |
Windows 8.1 x64 Magically yours Raistlin |
1st May 2016, 21:35 | #37680 | Link |
Try to avoid allowing the GPU to do any range conversions. That is the most straightforward recommendation.
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 1st May 2016 at 23:55. |
