Old 14th January 2019, 22:01   #761  |  Link
lansing
um, I couldn't reproduce the slow speed issue now, the "full processing mode" works normal again.
Old 17th January 2019, 14:52   #762  |  Link
How do I use VirtualDub2 to remultiplex a video (addition: with a different frame rate) from MKV to MP4?
I open an MKV with AVC (H.264) video stream only.
I select "Video - Direct stream copy".
(addition: I select a new frame rate via "Video - Frame Rate..." and "Source rate adjustment")
I use "File - Save as", select "MP4 (MPEG-4 Part 14) (*.mp4)"
VirtualDub Error
Direct stream copy cannot be used with this video stream.
You may want to select different Input Driver.
OK
Old 17th January 2019, 16:15   #763  |  Link
shekh
Some explanation https://sourceforge.net/p/vdfiltermod/wiki/direct_copy/
Input driver which works with mkv and direct stream copy is "fcchandler matroska" https://sourceforge.net/projects/fcc...oska%20plugin/
However I'm not sure the result can be saved to mp4 safely, try it.
VirtualDub2
Old 19th January 2019, 17:03   #764  |  Link
Yanak
Not using virtualdub for this but just in case... MP4box should achieve this simply :
MP4Box.exe -add video.h264:fps=60 -new Output.mp4
Once you have extracted the video stream from the mkv video (using mkvextract for example) just set the desired fps in the command line
Edit :
this command should do too:
MP4Box.exe -add video.h264 -fps 120 -new Output.mp4
Yanak is offline   Reply With Quote
Old 19th January 2019, 18:16   #765  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
I think it would also be most useful if VirtualDub2 could be configured to save a selected quantity of frames (between key or I-frames) into the same container as the source or as an elementary stream.
Old 19th January 2019, 23:41   #766  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
VirtualDub2 doesn't (for me) update the Audio Display when playing. It's fine when stepping with cursor keys, page up/down, or scrubbing on the timeline with the mouse, but hitting space to play just causes the currenty displayed waveforms to scroll off to the left with no new waveform data replacing it from the right. The frame numbers update, though.
Old 20th January 2019, 00:56   #767  |  Link
shekh
Are you playing avisynth script? Currently the waveform can update during playback only when using caching input driver.
This is because audio must be read concurrently on two threads, and most sources do not support this. I was thinking on possible solution, best I can imagine is to buffer a window long enough to satisfy both ends. This feels surprisingly complex.
VirtualDub2
Old 20th January 2019, 01:04   #768  |  Link
wonkey_monkey
Yes, sorry, I forgot to say: it was Avisynth colorbars.
Old 28th January 2019, 07:45   #769  |  Link
Milardo
Does virtualdub2 have a capture avi mode? I haven't tried it out yet. Also, can ffdshow be used as the video decoder for just preview/watching in virtualdub2 when in the capture avi mode?
Milardo is offline   Reply With Quote
Old 28th January 2019, 09:37   #770  |  Link
Yes, VirtualDub2 still contains the "File - Capture AVI..." menu entry of the original VirtualDub by Avery Lee (can't test its functionality due to a lack of source devices here).
I believe the capture mode is mainly based on VfW still, so it can probably use ffvfw as VfW decoder for captured video (no affirmative answer). Use the 32 bit application.
Old 28th January 2019, 17:30   #771  |  Link
Milardo
Ok, but can I just preview/watch through virtualdub and have ffdshow decode the video? I don't want capture/record anything.
Old 28th January 2019, 17:37   #772  |  Link
shekh
Duplicate thread https://forum.doom9.org/showthread.php?p=1864060
Old 31st January 2019, 17:54   #773  |  Link
wonkey_monkey
Feature request: when right clicking to change zoom, center (as much as possible) on the point which was initially right-clicked on, rather than whatever is currently in the center of the view.
Question: does VirtualDub2 cache frames differently depending on how long they take to be fetched? Like if a frame is fetched very quickly, is it less likely to cache the frame?
Old 4th February 2019, 19:00   #774  |  Link
rbauer
Hi.
is there any chances to make it portable?
Now it writes (a lot) to:
HKEY_USERS\S-1-5-21-95864766-2325389660-2471813846-1002\Software\VirtualDub.org\
HKEY_USERS\S-1-5-21-95864766-2325389660-2471813846-1002\Software\VirtualDub.org\Script Editor\
HKEY_USERS\S-1-5-21-95864766-2325389660-2471813846-1002\Software\VirtualDub.org\VirtualDub\
HKEY_USERS\S-1-5-21-95864766-2325389660-2471813846-1002\Software\VirtualDub.org\VirtualDub\External Encoders\
HKEY_USERS\S-1-5-21-95864766-2325389660-2471813846-1002\Software\VirtualDub.org\VirtualDub\MRU List\
HKEY_USERS\S-1-5-21-95864766-2325389660-2471813846-1002\Software\VirtualDub.org\VirtualDub\Persistence\
Many Thanks
rbauer is offline   Reply With Quote
Old 4th February 2019, 19:34   #775  |  Link
shekh
These are actually HKEY_CURRENT_USER
You can run once virtualdub.exe /portable and it will create VirtualDub.ini, or you can just create a blank file yourself.
All VirtualDub settings will go to ini file instead of registry.
But plugins will continue to use registry (e.g. Script Editor)
VirtualDub2
Old 4th February 2019, 21:13   #776  |  Link
nji
Bug in logo filter (only in 64 bit)
When adding a logo
(say logo image = unique color (255,0,255),
"Enable...", "Use gray",
secondary image a mask containing black and white)
in the resulting frame the logo is (254,0,254).
This in 64 bit (build 43073)
In 32 bit everything's fine.
nji is offline   Reply With Quote
Old 4th February 2019, 21:34   #777  |  Link
rbauer
I have tried again with VirtualDub2_43364 (no added external plugin), empty VirtualDub.ini and then double click on "VirtualDub64.exe" (I'm using win8.1pro 64bit on non admin account):
VirtualDub.ini is written but the program still writes to registry:
Old 4th February 2019, 21:39   #778  |  Link
Groucho2004
What do you think the files in the "plugins32" and "plugins64" directories are? The directory names should give you a hint.
Groucho's Avisynth Stuff
Old 4th February 2019, 22:00   #779  |  Link
rbauer
I don't get what you mean : I'm using VirtualDub64.exe 'cause I'm using a 64bit OS (i know plugins32 holds 32bit filters and the same with plugins64 and its filters).
Ok, get it, i'm gonna make a turbostudio version.
Old 4th February 2019, 23:57   #780  |  Link
shekh
Originally Posted by nji View Post
When adding a logo
This is terrible. I was about to offer another filter (fflayer) but it has similar issue.
for logo 32-bit code uses mmx inline asm; 64-bit code uses heavy bit-hackery. All this code looks throwaway.
VirtualDub2
